Old 04-15-2018, 06:11 PM   #1
T and S
T and S's Avatar
Holley carb on 250 cyl. adjustment question
I have a 390 cfm holley on a 250 straight 6 engine, carb is new. Engine is fresh rebuild - 9.1 compression, mild comp cam, offy intake, 292 exhaust manifold(2.5 outlet), HEI distributor.
I have trouble with a stumble - letting the clutch out and taking off, it takes off ok, stumbles, then takes off again. I have checked and set float level, mixture screws are at 1.5 turns out, good idle.
It came with .025 accelerator pump nozzles. Have tried .031's and .035's, and have .037's on the way. Still has the stumble, maybe not quite as bad.
Anybody running the 390, have you had this problem, and what nozzles did you end up with ??
Kind of getting frustrated, even thought of trying an edelbrock carb.
Have heard it mentioned this could also be an distributor advance problem - any comment ?? Any help would be greatly appreciated. Thanks in advance !
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 04-15-2018, 07:14 PM   #2
geezer#99
geezer#99's Avatar
Re: Holley carb on 250 cyl. adjustment question
What is your timing curve like?
What’s initial set at?
Old 04-15-2018, 08:47 PM   #3
T and S
T and S's Avatar
to be honest, I haven't checked it. I usually borrow a timing light,(haven't needed one till now) but I am buying one tomorrow.........
Old 04-15-2018, 08:57 PM   #4
68gmsee
Active Member
68gmsee's Avatar
A timing light and a vacuum gauge are two tools I've used many times on these old trucks.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 04-15-2018, 09:10 PM   #5
geezer#99
geezer#99's Avatar
Put your initial at 12 degrees.
Make sure you plug off the vac advance when you set it.
Old 04-16-2018, 09:17 PM   #6
T and S
T and S's Avatar
Bought a timing light. Also got a hold of my engine builder, he is having me drive it to his shop Friday morning and is going to help me out with it. He may strap it to the roller dyno for test and tune, I hope ....... I will let you know how it goes.
Old 04-18-2018, 10:15 AM   #7
T and S
T and S's Avatar
Did some research. Found a really good article from Super Chevy about vacuum advance, how it works, and how to tune. About %99.99 sure this is my problem. The HEI distributor worked fine on a stock engine, but not so much on my modified motor. I for sure am no expert on this sort of thing, and I am sure my engine builder is - he builds race engines for a living. Going to his shop Friday ....... http://www.superchevy.com/how-to/eng...r-drivability/
Old Today, 12:11 AM   #8
mattfranklin
mattfranklin's Avatar
For me, as long as I can hear it if it knocks, I advance until I can hear a light knock at WOT and then back it off just a little.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
