Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-16-2018, 01:09 PM   #1
Baketown Scotty
Junior Member
Baketown Scotty's Avatar
Front Turn Signal Problem
Trying to get all lights on 1966 GMC working to get it registered. All work except the front turn signals and parking lights. My test light lights up at the firewall, where the socket connects to the wiring and when I touch the metal sockets. It seems I have power the whole way but the bulbs won't light. I have new bulbs and have tried both 1157 and 1147. What am I missing?
1969 K5 Blazer
1964 Chevy Suburban 4x4
1966 GMC Suburban 4x4
Baketown Scotty is offline   Reply With Quote
Old 04-16-2018, 04:51 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Front Turn Signal Problem
you should have three wires to your lights. A purple one to both lights, a light blue one for the left turn signal and a dark blue one for the right turn signal.
If you have power on your wires then lack of ground could be your problem especially since the lights are in the hood. It may not be getting ground to the cab and back to the negative side of the battery. Try running a jumper wire from the battery negative battery terminal to one of the light sockets the with the parking lights on. If you get a light then the hood hinge is not grounding to the cab or the cab is not grounding to the battery.
You might test it with your test light by connecting the light socket and the negative battery terminal. If you light doesn't come on then there is no ground connection between the hood and the cab.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-17-2018, 02:31 PM   #3
Baketown Scotty
Junior Member
Thank you for your reply Sir. I will try that this weekend when I get home. I appreciate it.
1969 K5 Blazer
Old 04-25-2018, 07:25 PM   #4
Baketown Scotty
Junior Member
Not having a good ground was the issue. They all work well with the proper ground.
1969 K5 Blazer
Old 04-25-2018, 11:36 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
VetteVet
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
