Old 03-15-2016, 12:14 AM   #1
Thesilverfox
Thesilverfox's Avatar
1950 Chevy 3100 frame Dimensions
I am starting a 1950 chevy 3100 (1300) "Canadian version" restauration and have found that the frame is bent and cracked. Does anybody have factory frame dimensions for this truck?
Thesilverfox is offline   Reply With Quote
Old 03-15-2016, 12:17 AM   #2
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: 1950 Chevy 3100 frame Dimensions
https://www.gmheritagecenter.com/doc...olet-Truck.pdf
This PDF will have everything you need to know about your trucks frame dimensions
edit: page 52 shows frame dimensions
PS Welcome to the forums!
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 03-15-2016, 12:20 AM   #3
Thesilverfox
Thanks, I read this specs document carefully and could not find actual frame dimension just widths with running boards and fenders installed for example.
I am looking for the c frame diameters between front and rear engine mount crossmembers. Just wondering if the frame rails are supposed to be parallel with each other or not. That big farm bumper in the front has caused frame damage over the years.
Old 03-15-2016, 12:47 AM   #4
Thesilverfox
Oh ok, i'll read that page more carefully Am trying to edit my previous post but forum wont let me, sorry.
I am looking for the c frame diameter at the front crossmember and at the rear engine mount.
Old 03-15-2016, 01:04 AM   #5
yossarian19
If you are thinking about building a frame,
consider just putting the sheet metal onto an S10 pickup.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 03-15-2016, 01:52 AM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
You need an assembly manual for the frame Dims
Old 03-15-2016, 08:12 AM   #7
Thesilverfox
I just want to repair this one and bring the truck back to original. I can repair the crack but the front crosmember is kinked so i was jus looking for the diameter of the frame in the front half of the truck at a few key locations.
The s-10 conversion is very tempting but i'm not at that point yet, but could easily be convinced.
Old 03-16-2016, 09:14 AM   #8
whitedog76
Here you go.
http://chevy.oldcarmanualproject.com...resto/5070.htm
http://chevy.oldcarmanualproject.com...51ctsm0202.htm
I'll suggest buying one of these. http://www.classicindustries.com/pro...ts/tm1047.html
It's worth it. It has in depth dimensions on everything related to the 47-54 trucks. The Frame dimensions it has are for a 54/55 1st series, though. The only difference is the amount of kick above the rear axle.
Chris
whitedog76 is offline   Reply With Quote
Old 03-16-2016, 11:14 PM   #9
Thesilverfox
Wonderful, thanks
