Old 04-30-2006, 12:11 PM   #1
vk_chevy
vk_chevy's Avatar
sbc #434 heads any good?
are there any flow rates or specs available for the the SBC #354434? Mortec says it't a 75-79...262/267/305...60cc chamber.
Any body got any more info?
72 Chevy C20 Longhorn
72 Chevy, K20 Custom Camper
67 Chevy, LWB, C20, 350/350, PS, PB,
65 Jag MKII
vk_chevy is offline   Reply With Quote
Old 04-30-2006, 03:27 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: sbc #434 heads any good?
Good heads on a 283/305/307, but a little small on the valves/runners on the larger sb mills..... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-30-2006, 05:21 PM   #3
dennislbrooks
dennislbrooks's Avatar
Are these the 74-76 262 monza heads-- I ran them on a 283 -- I believe it lowered compression on my 283 to around 9-1. They have the hardened valve seats for unleaded.
dennislbrooks is offline   Reply With Quote
Old 04-30-2006, 05:57 PM   #4
crazy longhorn
They should be the same comp ratio on a 283, as the old "520" casting was (60cc power pac head). the old 4 brl 283's didnt run too bad L
Old 04-30-2006, 10:06 PM   #5
vk_chevy
vk_chevy's Avatar
I was thinking about using them on a mild 350 but sounds like I should keep looking...
65 Jag MKII
Old 04-30-2006, 11:01 PM   #6
67_C-30
I have a radical idea!
67_C-30's Avatar
They actually work great on MILD 350, if that's what you want. I would avoid them with flat-top pistons though. You'll have a hard time running them with today's junk pump gas. I have built several 350's with 305 heads (#416 and #434 castings usually) and they are very torquey. They usually have 1.72 or 1.84 intake valves and 1.50 exhaust. This makes great low end throttle response, but hurts upper end RPM, if that's what you want. I put a set of '71 Impala for a customer recently with stock 4 bbl and headers and it made a ton of difference in how the car ran. The #478 heads that came off the engine are some of the best flowing open chamber heads there are (along with #441's), and flow much better than #416's I put on it, the but the 76cc chambers with dished pistons were killing it! Aerohead sells 305 heads with the combustion chambers cut to 64cc, with 1.94 or 2.02 valves ready to run for around $500. Here's their info if you are interested.
Aerohead Racing Components
Indianapolis, IN 46239
317-862-0223
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 05-01-2006, 01:38 AM   #7
ureckme
ureckmefixit2@cox.net
My 355ci sb crate engine came with #434 heads 194 160 with port work was 422@5600 rpm but there thin castings
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
