Old 08-31-2012, 04:11 PM   #26
roushinator
roushinator's Avatar
Re: Roushinator's 72 C10 Stepside Restore/Build
Originally Posted by Xeen View Post
Hi Roush;
Nice find, im glad to see another one of these beauties is going to get the respect it deserves.
If you have any questions about lowering one of these trucks dont hessitate to ask.
Just a heads up on the spindles you need to clean them up and see what they are, if they are stock or aftermarket, because you cant lower a c10 more than 2" in the front on stock spindles because the geometry will be unreconcilable if you do and you wont be able to properly align it, with the spring kit you ordered you need a 2" or if you want to go lower a 2.5" drop spindle to properly reconcile the alignment.
The problem with the fact that you already ordered the 4" drop spring is that since you have to order a minimum of a 2" drop spindle to make them work this will SLAM the front end of your truck and you may have trouble without some modifications.
You also need to see if the rear suspension already has a shock relocator kit on it for proper shock angle and also make sure it has short shocks on it or the rear suspension will suck because you wont get enough piston travel and the shocks will bottom out when you hit a bump.
Good luck!
The 4/6 ECE Drop kit i ordered comes with:
2.5" Drop Spindles, 1.5" Drop Front Coil Springs, 6" Rear Drop Coil Springs, 4 KYB Shock Absorbers, Super Track Bar Kit, Shock Mount Relocator Kit
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 08-31-2012, 05:22 PM   #27
Xeen
Xeen's Avatar
Excellent you got it handled then.
I always try to be as helpfull as possible and you had mentioned that chevy stuff was new to you, so I thought I would mention it just incase you werent quite sure.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-31-2012, 06:55 PM   #28
roushinator
I appreciate it. Feel free to post any time.
Ryan...
Old 08-31-2012, 11:24 PM   #29
roushinator
A little more progress today...
Ryan...
Old 09-01-2012, 04:36 PM   #30
Tinkermc
I agree looks like it will be a good project, on the hood I woulg guess it needed shrinking to make it tight in the middle and PO did not know how so just braced it instead.
Tinkermc is offline   Reply With Quote
Old 09-06-2012, 07:22 PM   #31
roushinator
New stuff came in today... Hedman Headers.
I am kind of thinking about doing something like this with the exhaust..
Ryan...
Old 09-06-2012, 07:32 PM   #32
Tinkermc
Some very nice partd turning up in you thread
Old 09-07-2012, 09:38 AM   #33
roushinator
Picked up a original bench last saturday. The foam and cover were gross so i tossed them. Ordering the covers below with new foam.
Ryan...
Old 09-17-2012, 01:22 PM   #34
roushinator
Tore into it some more yesterday... Had all kinds of leaf crap in the cowl area. Richard stopped by as well.
Found a repairable passenger fender, new door sill patch panels and SWB Fleetside bed that i am going to pick up. Getting the New/Used bed because i think it will be less work and more cost effective to use this bed that what i have on there already.
Ryan...
Old 09-17-2012, 01:46 PM   #35
outlawz916
[QUOTE=roushinator;5558964]My next question was how as this lowered? Was the lowering done by a kit or backyard modifications? Please excuse the dumb questions but Chevy stuff is new to me...
he used the rebar to reinforce the middle of the hood. I remember when I first bought my truck and drove it home the hood was basically flapping in and out as soon as i passed 20 mph.
outlawz916 is offline   Reply With Quote
Old 09-18-2012, 10:39 AM   #36
roushinator
Well after working on the truck yesterday decided to keep the stepside bed... Got a quote to Acid drip the Cab and it is $750 and then for them to dip it in primer was $725. Soda blasting $500. But someone offered to Soda blast the cab for $200 but i have to haul it to Alabama. So i dont know yet which way i am going to do.
Ryan...
Old 09-19-2012, 10:29 AM   #37
roushinator
What i got done last night.
There were a ton of leaves packed into the fan area.
Ryan...
Old 10-02-2012, 08:49 AM   #38
roushinator
Some more progress. The frame is in in good shape. Rust is minimal but it is caked with dirt.
Ryan...
Old 10-02-2012, 10:36 AM   #39
longbed67
longbed67's Avatar
I see a lot of potential and a lot of work! I was right where you are 1 year ago and now I am almost done! I will be following this one! Good Luck!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 11-06-2012, 09:16 AM   #40
roushinator
Have not made too much progress. Been working and going out of town but i have collected some parts.
Some patch panels, new steering kit and something for the motor :twisted:
Picked up a ECE crossmember and trailing arms. The cross member should be here next week it was on back order.
Ryan...
Old 11-06-2012, 12:54 PM   #41
67cheby
67cheby
67cheby's Avatar
making some great progress , keep it up !
67cheby is offline   Reply With Quote
Old 11-08-2012, 09:57 AM   #42
roushinator
This came in yesterday.... ECE cross member. It appears to be well built.
Bought a HD C Notch kit from CPP and it should be here next week. Also found a guy to blast the frame and prime it with and industrial primer. Going to bring it to him next week for that.
Ryan...
Old 11-11-2012, 09:29 PM   #43
roushinator
A friend stopped by this afternoon and we got some work done!
Ryan...
Old 11-26-2012, 10:51 AM   #44
roushinator
Had the whole week off. Got some work done.... With a little effort and the engine hoist got the cab off the frame by myself.
Ryan...
Old 11-26-2012, 10:51 AM   #45
roushinator
A friend came over a couple of days later and we got this done.
Ryan...
Old 11-26-2012, 10:52 AM   #46
roushinator
Finally used "marine clean" to De-Grease the frame. 40 years of grease, dirt and oil gone....
Ryan...
Old 11-26-2012, 10:53 AM   #47
roushinator
Here is my next step....
Cutting the frame to install the C-Notch....
Ryan...
Old 12-03-2012, 10:40 AM   #48
roushinator
Here is this weekend's work....
New parts waiting in the boxes....
This weekends victims.
Ryan...
Old 12-03-2012, 11:41 AM   #49
67cheby
67cheby
67cheby's Avatar
great progress !
Old 12-03-2012, 09:43 PM   #50
gdavis
gdavis's Avatar
wise idea about keeping the steep side. you will like it better i think..
gdavis is offline   Reply With Quote
