Old 02-19-2012, 11:26 AM   #1
strokd 84
strokd 84's Avatar
Offset for 73 to 87 vs 88 to 98
I found a good price on a set of used wheels. They were on a 95 Chevy, so I know the bolt pattern is right. I'm wondering if, in general, the offset for the 73 to 87 is about the same as the 88 to 98.
Does anyone have experience with something like this?
Thanks in advance!
1984 Silverado SWB
Second Owner
Featured in Custom Classic Trucks May 2013
http://www.customclassictrucks.com/f...let_silverado/
strokd 84 is offline   Reply With Quote
Old 02-19-2012, 12:04 PM   #2
J Knight
J Knight's Avatar
Re: Offset for 73 to 87 vs 88 to 98
I can partially answer this. I used to have a 95 Chevy that I put 15x10 with 6in backspace with 295/50/15 tires and the inside clearance was about 1/4 in from the leaf spring and the outside still stuck out just barely. Same set up on my 82 with 5in backspace I have about 1in clearance from the inner wheelwell and 1/4 in clearance from the outer fender lip. BTW what are the specs of the wheels you found?
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 02-19-2012, 12:09 PM   #3
strokd 84
strokd 84's Avatar
On your set up, the clearance was a little bigger on the 82 than the 95, right?
I haven't seen the wheels yet. I asked the seller for the specs but am waiting on a reply.
Thanks for the quick reply!
1984 Silverado SWB
Second Owner
Old 02-19-2012, 12:11 PM   #4
J Knight
J Knight's Avatar
Yes the 73-87 has more room to play with than the 88-98.
John
Old 02-19-2012, 12:14 PM   #5
strokd 84
strokd 84's Avatar
So these will probably fit. If the wheels are too tucked in, I could buy spacers to get them to look right. I'll keep you posted!
1984 Silverado SWB
Second Owner
Old 02-19-2012, 12:20 PM   #6
J Knight
J Knight's Avatar
Most likely they will be fine, but we will know for sure when you get the specs.
John
Old 02-19-2012, 11:18 PM   #7
strokd 84
strokd 84's Avatar
The fronts have 5.25" bs and the backs 6.25". They tuck in a little more in the front than i would like but the price was right!
Thanks again for your help.
1984 Silverado SWB
Second Owner
Old 02-20-2012, 09:54 AM   #8
J Knight
J Knight's Avatar
Those must be 20s. You will probably need a .75in to 1.25in spacers for the rear 6.25 backspace.
John
