Old 06-12-2018, 02:02 PM   #1
4oldcars
4oldcars's Avatar
Compressor "chirp"
I have Vintage Air on my truck with about 5k miles (in 5 years) on it. I rarely drive my truck. The compressor (Sanden model S6668) works but started "chirping". I can turn off the a/c and the chirp stops. I checked the belt. Any ideas on what to do other than drive it more?
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
All Chevys; 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 pick up
4oldcars is online now   Reply With Quote
Old 06-12-2018, 02:20 PM   #2
jessemthompson
Re: Compressor "chirp"
I had a similar issue with my ac belt chirping. I could not get it to stop. I did some reading and came upon a product called 303. I picked it up at advance. I conditioned my belt with it about a month ago and the chirp has not came back. It doesn’t gum up a belt like dressing and it will actually help the belt last much longer.
jessemthompson is offline   Reply With Quote
Old 06-12-2018, 03:08 PM   #3
weq92f
You could also use a bar of soap to dress the belt(s) as a test.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-14-2018, 09:03 AM   #4
4oldcars
4oldcars's Avatar
Thanx - sounds like an easy fix - how unlike what usually happens to me
4oldcars
Driving:
The ones I let go:
Old 06-14-2018, 06:21 PM   #5
cleszkie
cleszkie's Avatar
Are you running the correct width belt? If you run a belt that is too narrow, it will go all the way to the bottom of the pulley V-groove, and make contact with the flat bottom of the groove. No amount of tightening of the belt will get rid of the noise now that the belt tension is no longer controlled by the tapered side of the pulley groove on the side of the belt, but rather the flat bottom of belt against flat bottom of groove. I had this issue with a custom built alternator, and swore up and down that the alternator had a bad bearing. Put a wider belt on it that didn't touch the bottom of the pulley groove and it has been silent ever since.
cleszkie is offline   Reply With Quote
Old 06-14-2018, 07:08 PM   #6
dmjlambert
dmjlambert's Avatar
Hi, what is the manufacturer and part number of the belt that is wider you ended up buying?
Copyright ©2000 - 2019, vBulletin Solutions Inc.
