Old 06-13-2018, 12:13 PM   #1
72LB
72LB's Avatar
Pinion nut question
Had to replace the pinion seal in my 69 and can't find a nut locally anywhere so I have to re-use the nut. An old timer told me to use some loctite blue and don't over tighten. I need to get this truck back on the road, is there a torque spec I need to follow?
72LB is offline   Reply With Quote
Old 06-13-2018, 01:31 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Pinion nut question
did you already remove the nut and seal?
Old 06-13-2018, 01:32 PM   #3
72LB
72LB's Avatar
yes
Old 06-13-2018, 01:44 PM   #4
Grumpy old man
Before you remove them you have to mark the position of the nut then on reassembly you have to replace it back to the original position as closely as possible to try to match the original preload it had before . just tightening it back down can change pinion depth and thrash your rear, it's not as simple as remove and replace.
Old 06-13-2018, 02:26 PM   #5
Rich69shortfleet
I was in the same situation a while back. I spoke with a highly experienced and highly regarded rear end guy and he said to simply torque the pinion nut to 150 lb/ft and be on my way. It takes a LOT more torque than 150 lb/ft to crush the crush sleeve so at 150 lb/ft you will not affect the crush sleeve or alter the pinion depth.
One thing that is VERY important is that you clean the threads on the nut and threads on the pinion. Make sure that any and all old threadlocker has been removed and that there are no nicks or damage to the threads. Then, using a quality high strength threadlocker reassemble and torque to 150 lb/ft. If you haven't done so, adding a touch of RTV to the splines on the yoke will help prevent a leak via the splines which can appear like a pinion seal leak in the future.
I have to stress, be sure to clean the threads very well. Leave no residue behind. Did I mention you need to clean the threads? Any remaining old threadlocker can wildly affect getting the proper preload via the torque setting. Don't forget to clean the threads.
I have had to do this three times over the years chasing a leaking pinion seal. I've had no problems with the rear end and it remains as quiet as when it was new. I have hauled and towed plenty with no issues so it is clear I got good advice and have not altered the pinion depth in any way.
Rich69shortfleet is offline   Reply With Quote
Old 06-13-2018, 04:10 PM   #6
57taskforce
57taskforce's Avatar
This is how Iíve done a few as well. Never had one problem with bearing or gear wear doing it this way.
'57 3100 350/700r4 35x12.5's
'72 K/20 Cheyenne 350/SM465 in pieces awaiting ly6 6.0 swap. http://67-72chevytrucks.com/vboard/s...d.php?t=662879
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6"RCD 315/75/16's
Ď10 Camaro 2SS/RS l99 6l80e Aqua Blue Metallic #2399
Old 06-13-2018, 05:14 PM   #7
Rich69shortfleet
FYI, the torque required to begin to crush a crush sleeve is 225 lb/ft or more.
Old 06-13-2018, 05:52 PM   #8
72LB
72LB's Avatar
Wow it didn't feel that tight when I took if off. I will clean the threads thoroughly, what about using loctite? Me thinks torquing the nut will be fun under the truck.
Old 06-13-2018, 07:04 PM   #9
Rich69shortfleet
Loctite is fine as long as it is the high strength version. As far as torquing the nut, hopefully you have an effective parking brake. Applying the parking brake and leaving it in gear (wheels off the ground!) should be enough. And either a long torque wrench or a long helper handle. You need to get the truck as high as you can safely so you have as much room to swing the wrench as possible.
Old 06-13-2018, 07:35 PM   #10
72LB
72LB's Avatar
I have a yoke wrench so I should be ok.
Old 06-13-2018, 11:52 PM   #11
CastIron
CastIron's Avatar
I've done it by marking the old nut and loctiting back in the same spot. I've also done a lot of them on rwd cars when I worked at a GM dealership. The proper procedure for those (it was a recall with specific instructions) was to just torque the nut. I don't remember exactly how tight it was though.
CastIron is offline   Reply With Quote
Old 06-14-2018, 06:23 AM   #12
Metaldoc
Metaldoc's Avatar
I believe you need a new crush sleeve and torque till you have 10 inch pounds of drag on the torque wrench.
Metaldoc is offline   Reply With Quote
Old 06-14-2018, 09:55 AM   #13
Rich69shortfleet
Lucky duck!
No, not at all if all you are doing is removing the pinion nut to replace the pinion seal. If you are replacing bearings or gears, yes, but not for just removing and replacing the pinion nut.
Old 06-14-2018, 10:56 AM   #14
RustyBucket
RustyBucket's Avatar
A friend of mine had a drive line shop and used an industrial sized 1" drive impact wrench to crush the new sleeves. He had a touch for just how many times to hit it. Said the sound changed as the sleeve began to crush. Then he would check the pre load w/an inch lb. torque wrench. One of those guys that made everything he worked on look easy. .... unlike ME
Dad always said, "Son, WISH IN ONE HAND, and ......."
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
'66 Plymouth Belvedere City of Miami cop car clone
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- shop ornament, needs resto.... SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, needs resto...SOLD!!
RustyBucket is offline   Reply With Quote
Old 06-14-2018, 11:06 AM   #15
slikside
slikside's Avatar
Sub'd.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor.
slikside is offline   Reply With Quote
Old 06-14-2018, 12:36 PM   #16
72LB
72LB's Avatar
Lucky duck!
Found it at a swap meet last year, I knew there was a reason I bought it.
Old 06-14-2018, 01:55 PM   #17
72LB
72LB's Avatar
Torqued it too 150 and it was fairly tight, ended up backing it off a tiny bit and it has around 10 to 12 inch lbs of drag to it.
Old 06-15-2018, 08:45 AM   #18
volksworld
that 10 inch pounds would be for a pinion gear in a bare case...so if you have a diff , axles and drums there would be a hellava lot more drag....and i sincerely doubt the sleeve "uncrushes" when you backed the nut off
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 06-15-2018, 09:22 AM   #19
72LB
72LB's Avatar
Thats with axles in it, was told to check the drag with tires and drums off.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
