05-06-2008, 05:34 AM | #1 |
mechanical advance distributors
I started this thread after a discussion I got into with Billla about non-vacuum advance dizzy's. I bought a brand spankin new MSD pro-billet mechanical advance distributor a while back for my BBC bracket/street motor (it still hasnt been fired). I was told by an "old school" racer/friend of the family that vacuum advance isnt desirable on a bracket motor because it will not always come in at the same time and thus be less consistant. I've since been told that this will cost me power, mileage, and eventually limit the life of the engine. Fuel mileage really isnt a concern, but the first and last of course are. Being that it is "mechanical advance" rather than vacuum advance, I would assume that the motor will still receive the right amount of advance at higher RPM via the springs and weights (I still need to learn more about this). Is this not the case? I just want some more feedback on the issue.
Thanks guys!
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e Last edited by chevy72blu; 05-06-2008 at 05:35 AM. |
05-06-2008, 06:41 AM | #2 |
Msgt USAF Ret
Re: mechanical advance distributors
Here's some feedback for you.
http://www.lbfun.com/Corvette/Tech/v...Adv%20Spec.pdf
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 05-07-2008 at 04:22 PM. |
05-07-2008, 03:04 PM | #3 |
in wide open throttle conditions vaccum advance has no part in the timing. vaccum advance is there for fuel economy at cruise speed. when you go wide open and vaccum drops the vaccum can doesnt advance.you have the right distributor for your app.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
05-07-2008, 04:39 PM | #4 |
If you don't mind driving around town or at cruise speed with the timing seriously retarded,yes,that's the right distrib.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
05-07-2008, 04:55 PM | #5 |
theres no reason his timing needs to be retarded just because it doesnt have vaccum advance.set the total mechanical to be all in at around 3000rpm depending on the cam.stock distributors with a vac advance usually have springs so heavy the mechanical advance wont even move until 4 or 5000rpm.get your distributor curved to your motor.
05-07-2008, 06:44 PM | #6 |
To be clear in my comments - I noted that non-vacuum advance wasn't appropriate for a street engine. If the usage is all race - or you're willing to drive something that doesn't run well on the street, then it's fine. Any racing engine that gets driven on the street is a compromise - the jetting you're using also impacts longevity, etc. I think maybe I gave a snap answer to a quick question and didn't take the time for full context.
Mechanical advance even on a stock engine starts early - not at 4-5000 rpm - but I agree (as I've noted many times) that a custom-curve is required. |
05-07-2008, 07:06 PM | #7 |
Truck and auto performance nut
if it will only see track time then yes a mechanical dizzy is correct. if it will also see street time too....in addition to the other issues, your engine will also run hotter w/o vacuum advance.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
05-07-2008, 09:49 PM | #8 |
Vacumn advance is not "required" on street driven engine, but it surely would be a good idea if you drive some miles on the street. Another 10-15 deg advance at idle and light cruise will let it run cooler as mentioned, better mpg if it matters and lilely keep the plugs cleaner.
At the track just unhook the advance line and plug the carb port if you want to eliminate possible vac advance variations affecting the ET
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
05-08-2008, 01:04 AM | #9 |
Thanks for the replies guys! As much as I'd like to keep my truck as a "race only vehicle", I love it too much to not drive it around and show it off. That makes sense about the motor idling and cruising cooler. Hmm, I still need to do some more thinking on the issue.
I was under the impression that there was a disadvantage to plugging the vacuum advance on the dizzy and carb. If there isnt, there is no reason to not swap mine, and just recurve it when I go to the track. I've been thinking more and more that I should just dyno the thing and answer a lot of these questions for myself.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
05-08-2008, 04:18 AM | #10 | |
