Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-17-2021, 12:30 AM   #1
Seanext
1971 C10 Parking light connector
Anybody know where you can get the connector that goes through the radiator support for the parking light on a 71 C10? It is part of the front wiring harness not the pigtail on the light itself. Thanks for any help.
Seanext is offline   Reply With Quote
Old 01-17-2021, 11:19 AM   #2
Andy4639
Old member
Andy4639's Avatar
Question Re: 1971 C10 Parking light connector
Are you wanting the wires & rubber plug that fits the radiator support hole?
If I remember right it's part of the harness, it's not separate I think.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-17-2021, 11:31 AM   #3
Seanext
Yes that is what I am look for. It has the rubber grommet that pops through the radiator support and yes it is part of the front light harness. The ones on mine are hard and cracked. Could get them from an old harness but may run into the same problem. I know someone makes them as they are making new harnesses just finding who is the issue.
Old 01-17-2021, 02:26 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 1971 C10 Parking light connector
From the picture of the LMC on line it's made to the park lamp housing.
https://www.lmctruck.com/1967-72-che...-for-chevrolet
Old 01-17-2021, 03:57 PM   #5
Seanext
I think that picture it shows the pigtail that is on the light that plugs into the connector that I am looking for.
Old 01-17-2021, 06:35 PM   #6
Andy4639
Old member
Andy4639's Avatar
It maybe. It's been awhile since I took mine apart. But if I remember right it's made to the wiring harness so you would have to buy the whole wiring harness to get the other side of the plug.
Old 01-17-2021, 06:42 PM   #7
Andy4639
Old member
Andy4639's Avatar
Manes truck parts has it but as stated it's part of the head light harness. You can see the ends in the picture.
https://www.manestruckparts.com/stor...&Category_ID=8
Old 01-17-2021, 10:48 PM   #8
Seanext
Yeah I am afraid I may have to buy a new harness if I can't find them.
Old 01-17-2021, 10:50 PM   #9
Seanext
I did find these and I think they will work just cost to much by two and I am a third of the way to a new harness.
https://www.ecklerscorvette.com/1969...-189250-1.html
Old 01-18-2021, 11:15 AM   #10
Andy4639
Old member
Andy4639's Avatar
How about some door jam seals for the wiring to pass through the door. May work out fine then again may not who knows.
https://www.summitracing.com/parts/o...hoCJNUQAvD_BwE
