10-14-2017, 04:41 PM | #1 |
Road Walker
I bought my dream, a 1970 3/4 Chevy just like Daddy hauled cattle and hay with while I stood in the middle of the tooled-leather look bench seat and provided much needed moral support. The one I finally found looked like a dragster. I’ve had the springs, tires, wheels, and shocks replaced in attempt to return it to 3/4 ton masculine workhorse status. I also had a spring spacer lift (2 1/2”) added to beef it up. After having the suspension modified, it walks all over the road. I know it needs new upper and lower ball joints. I had an allgnment done. Any suggestions as to why it’s walking the road so much? 16.5” to 16” and a 2 1/2” spring lift.
Posted via Mobile Device Last edited by Texas Kraut; 10-14-2017 at 04:47 PM. |
10-14-2017, 06:02 PM | #2 |
Post Whore
Re: Road Walker
welcome...if your upper/lower ball joints are shot they should never have attempted to align the front. ..get all the front end components in good shape...then get it aligned...loose steering parts will send you all over the road..check tires, air pressure. ..you could crawl under the front and get someome to turn the wheel lok2lok and look for abnormal joint movement
10-15-2017, 09:22 AM | #3 |
Re: Road Walker
Thank you. I'll get that done next
10-16-2017, 10:35 AM | #4 |
I am a Referee of life.
Re: Road Walker
You also need to find a different alignment shop. The one that did your alignment isn't reputable. If they were, they would have told you an alignment isn't possible with the worn components.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-16-2017, 11:43 AM | #5 |
Re: Road Walker
Spring spacer lift? where, front or rear?
