12-14-2016, 01:20 PM | #1 |
1985 single cab 1 ton dually manual trans. Is transfer case a 205?
Up here in Hailey, ID. and its too dang cold and too much snow on the ground to crawl underneath and look. My guess is a 205. Trying to do some homework, thanks!
12-14-2016, 03:14 PM | #2 |
Re: 1985 single cab 1 ton dually manual trans. Is transfer case a 205?
Could be, but more likely an NP208.
Scratch that.. civilian 1 ton likely NP205, military NP208. That's what I'm thinking.
White K20 |
12-14-2016, 04:06 PM | #3 |
All 1 tons in the 80s had the 205. Military is different, but the duallys did get it too. If it doesn't have a 205 it was swapped in.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
12-14-2016, 04:31 PM | #4 |
Thanks!
12-14-2016, 09:13 PM | #5 |
It should be a np205,You can take a picture of the shifter in the cab,The shifter is different between a np208 and np205.
12-15-2016, 02:09 AM | #6 |
No need, as stated all 1 tons got the 205
12-15-2016, 09:18 AM | #7 |
They all came with them. however, I have castrated several k30s and resold as k20s. What they had 30 years ago may not be what they have now.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2 1991 V3500 350/4l80/205 60/14 4.10 35 toyos. |
12-15-2016, 10:56 AM | #8 |
That's guys, I have a SM465 with a Gear Vendors overdrive unit in the truck, the GV keeps blowing the fuse, I think the solenoid is bad.
12-15-2016, 12:15 PM | #9 |
Why did the military have 208's? Is it because of the lower ratio?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
12-15-2016, 12:58 PM | #10 |
Potentially, although you can shift 205s into 4wd on the fly, I think 208s are lil easier. But don't know the "real" reason. Why military intelligence is the biggest oxy moron....
12-16-2016, 03:31 AM | #11 |
The military blazer used the np208 so maybe they wanted the pickups the same so they will interchange and have parts easier.
12-16-2016, 11:47 AM | #12 |
It was probably GMs choice. The military usually starts with a concept to fill a need. The vendor produces a vehicle that fits the criteria. Then the Army takes your vehicle, weapon or whatever, to the proving grounds and they thrash it. If it lives they order a whole bunch and you get rich. So I guess the 208 survived the proving grounds. But of course we all know the CUCVs did not stand the test of time for Military abuse.
White K20 |
12-16-2016, 04:55 PM | #13 |
Its easy, cast iron case=205, Aluminum case=208
12-17-2016, 04:03 AM | #14 |
95 s trucker you forgot gear driven 205 and chain on the 208.
12-17-2016, 07:07 AM | #15 |
12-17-2016, 10:47 PM | #16 |
The shifter in the cab on a 205 is straight up the 208 leans foward some.
12-19-2016, 12:28 PM | #17 | |
I just got a Christmas idea for 57NapCo! He needs one of these. Good for cold plus, it's orange so wife won't run him over in the driveway! Merry Christmas 57NapCo!
White K20 |
12-21-2016, 02:43 AM | #18 |
Fly and drive number 25 +/-
Just got home, 1900 miles...no issues. I spun that ol big Block pretty tight going 70 mph for a bit. In the interest of getting home, I pulled it back to 60-65, 8-10 mpg 1985 GMC 1 ton single cab dually 4X4, factory air, stock big block, sm465, 4:11's, GV overdrive unit (not working for trip), no rust, 122,000 miles... seems possible. Bumps and bruises ah plenty. Red River NM ah couple nites ago. |
12-21-2016, 04:05 PM | #19 |
I am interested in the nuances of the GV, with the 465/205 setup, when you get it running. I am thinking about maybe getting one. I only know of people that have them. But I don't personally know anyone that runs one. I kind of want one, but without getting in a vehicle with one, not sure about the bucks just yet.
White K20 |
12-21-2016, 10:36 PM | #20 | |
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
12-22-2016, 01:47 AM | #21 | |
12-22-2016, 08:01 PM | #22 |
That's a GREAT looking dually! I've got an '86 K30 dually with 454/4 speed and a 205. But it's been rode HARD and put up wet as they say. But it was cheap!
12-22-2016, 08:44 PM | #23 |
12-22-2016, 09:28 PM | #24 |
Gonna keep the gv in it? I'M looking for an adapter for gv to 205.
12-22-2016, 09:41 PM | #25 |
