Old 06-09-2017, 03:49 PM   #1
hop sing
hop sing's Avatar
60-62
just picked up a 62 torrision bar it has a V-8 does anyone got a picture of a in line 6 engine frame mount .. I am doing ass backward swap a 6 for a eight ,,thx for your time hop ..oh anybody have a set of inline 6 frame mounts out there thx Hop
Save a tree support your local drag strip !!!
hop sing is offline   Reply With Quote
Old 06-09-2017, 04:18 PM   #2
62stepside longbox
62stepside longbox's Avatar
Re: 60-62
Does it still have the Bellhousing mounts? Also depends what six you're putting in. If it's a 216/235/261 then you will need a front mount that attaches to the front of the crossmember. If you are putting in a later 230/250/292 then you will need side mounts. The 230/250 uses the same perches as a 1963 and up v8, as where the 292 needs a different passengers side perch.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 06-09-2017, 08:21 PM   #3
hop sing
hop sing's Avatar
Re: 60-62
thx for the info ,,no bell mount got a turbo 350 ,,so I will look for 63 6 cly perches putting in a 70, 250 cu
Old 06-10-2017, 03:02 AM   #4
62stepside longbox
Re: 60-62
Does your current v8 have side mounts? If so then the 70' 250 will bolt right up.
