Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 05-19-2004, 06:56 PM   #1
John Fabris
TOTY 2006
John Fabris's Avatar
1967-1972 Chevy Truck/Blazer/Burb/Panel Production Numbers
Here are the production numbers for 1967-1972 Chevy Trucks, Blazers, Suburban, and Panels. (Sorry, no GMC). This information is from the "standard catalog of American Light-Duty Trucks, 3rd edition".
I do not think that all of this data is 100% correct, so, if there is any misinformation about this, we can tell the editor of the book.
Here Goes!!
1967
1/2-Ton Commercial - Model C/Series 10 - 115-in. w.b
MODEL BODY TYPE PRICE WEIGHT PROD.TOTAL
CS10703 Chassis & Cab 2223 2914 2790
CS10734 Fleetside 6.5ft 2371 3333 43940
CS10704 Step-Side 6.5ft 2333 3255 45606
1/2-Ton Commercial - Model C/Series 10 - 127-in. w.b
CS10903 Chassis & Cab - - 39
CS10934 Fleetside 8ft 2408 3440 165973
CS10904 Step-Side 8ft 2371 3345 19969
CS10905 Panel 2742 3502 3827
CS10906 Suburban 2986 3670 5164
1/2-Ton Commercial 4x4 - Model K/Series 10 - 115-in. w.b
KS10703 Chassis & Cab 2903 - 32
KS10734 Fleetside 6.5ft 3051 - 1046
KS10704 Step-Side 6.5ft 3013 - 1229
1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b
KS10903 Chassis & Cab - - 41
KS10934 Fleetside 8ft 3088 - 2715
KS10904 Step-Side 8ft 3051 - 500
KS10905 Panel 3422 - 30
KS10906 Suburban 3666 3670 166
3/4-Ton Commercial - Model C/Series 20 - 127-in. w.b
CS20903 Chassis & Cab 2403 3346 6320
CS20934 Fleetside 8ft 2550 3848 50413
CS20904 Step-Side 8ft 2513 3753 785
CS20909 Stake 2606 3973 1415
CS20905 Panel 2884 3917 940
CS20906 Suburban 3170 4093 709
3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b
KS10903 Chassis & Cab 3083 - 498
KS10934 Fleetside 8ft 3230 - 2773
KS10904 Step-Side 8ft 3193 - -
KS10905 Panel 3286 - 8
KS10906 Suburban 3850 - 120
Long-Horn Pickup
KS21034 Fleetside 8.5ft - - -
1-Ton Commercial - Model C/Series 30 - 133-in. w.b.
CS31003 Chassis & Cab 2561 3556 11304
CS31034 FleetSide 8.5ft 2755 - -
CS31004 Step-Side 9ft 2695 3995 4026
CS30909 Stake 2875 4390 3236
1968
CE10703 Chassis & Cab 2320 3048 2735
CE10734 Fleetside 6.5ft 2468 3467 46483
CE10704 Step-Side 6.5ft 2430 3389 46322
CE10902 Chassis & Cowl - - 14
CE10903 Chassis & Cab 2358 3136 1197
CE10934 Fleetside 8ft 2506 3572 204286
CE10904 Step-Side 8ft 2468 3477 18632
CE10905 Panel 2839 3641 4801
CE10906 Suburban 3081 3809 11004
KE10703 Chassis & Cab 2874 3435 43
KE10734 Fleetside 6.5ft 3022 3851 1449
KE10704 Step-Side 6.5ft 2985 3771 1706
KE10903 Chassis & Cab 2911 3512 41
KE10934 Fleetside 8ft 3060 4024 -
KE10904 Step-Side 8ft 3022 3916 552
KE10905 Panel 3393 4123 59
KE10906 Suburban 3667 4212 4259
CE20902 Chassis & Cowl - - 12
CE20903 Chassis & Cab 2499 3458 6636
CE20934 Fleetside 8ft 2547 3960 60646
CS20904 Step-Side 8ft 2610 3865 7666
CE20909 Stake 8ft 2702 4085 1103
CE20905 Panel 2981 4035 1572
CE20906 Suburban 3264 4217 1573
KE10903 Chassis & Cab 3054 3590 498
KE10934 Fleetside 8ft 3201 4030 4705
KE10904 Step-Side 8ft 3163 3940 1047
KE10905 Panel 3534 4111 68
KE10906 Suburban 3611 4215 299
Long-Horn Pickup - Model C/Series 20 - 133-in. w.b.
CE21034 Pickup 8.5ft 2711 4084 1902
CE31003 Chassis & Cab 2657 3665 11948
CE31034 FleetSide 8.5ft 2852 4158 213
CE31004 Step-Side 9ft 2791 4104 2836
CE30909 Stake 2971 4499 3272
1969
1/2-Ton Blazer - Model K/Series 10 - 104-in. w.b.
KE10514 Open Utility 2852 2947 4935
CE10703 Chassis & Cab 2383 3116 2343
CE10734 Fleetside 6.5ft 2532 3531 54211
CE10704 Step-Side 6.5ft 2494 3450 49147
CE10903 Chassis & Cab 2421 3189 1203
CE10934 Fleetside 8ft 2569 3623 268233
CE10904 Step-Side 8ft 2532 3523 18179
CE10905 Panel 2960 3724 5492
CE10906 Suburban 3194 3815 14056
KE10703 Chassis & Cab 2936 3316 58
KE10734 Fleetside 6.5ft 3085 3732 1649
KE10704 Step-Side 6.5ft 3047 3652 1698
KE10903 Chassis & Cab 2973 3522 35
KE10934 Fleetside 8ft 3123 3836 4937
KE10904 Step-Side 8ft 3085 3651 521
KE10905 Panel 3513 3935 -
KS10906 Suburban 3749 4024 -
CE20903 Chassis & Cab 2614 3506 8440
CE20934 Fleetside 8ft 2762 4013 74894
CS20904 Step-Side 8ft 2724 3907 8090
CE20909 Stake 8ft 2832 4138 -
CE20905 Panel 3172 4093 1779
CE20906 Suburban 3447 4199 2736
KE10903 Chassis & Cab 3205 3626 556
KE10934 Fleetside 8ft 3353 4131 6124
KE10904 Step-Side 8ft 3315 4025 1071
KE10906 Suburban 4040 4316 545
CE21034 Pickup 8.5ft 2826 4066 8797
CE31002 Chassis & Cowl - - 236
CE31003 Chassis & Cab 2724 3689 16828
CE31034 FleetSide 8.5ft 2919 4276 2457
CE31004 Step-Side 9ft 2858 4120 1300
CE30909 Stake 3063 4617 -
1970
1/2-Ton Blazer 4x2 - Model C/Series 10 - 104-in. w.b.
CS10514 Open Utility 2385 3375
CE10514 Open Utility 2852 2947
NOTE: 4x2 (both E and S) production = 985
1/2-Ton Blazer 4x4 - Model K/Series 10 - 104-in. w.b.
KS10514 Open Utility 2955 3677
KE10514 Open Utility 3050 3807
NOTE: 4x4 (both E and S) production = 11527
CS10703 Chassis & Cab 2405 3090 2084
CS10734 Fleetside 6.5ft 2560 3506 40754
CS10704 Step-Side 6.5ft 2520 3426 40754
CS10903 Chassis & Cab 2445 3107 7277
CS10934 Fleetside 8ft 2595 3605 234904
CS10904 Step-Side 8ft 2560 3510 11857
CS10905 Panel 3040 3730 3965
CS10906 Suburban(doors) 3250 3862 11332
KS10703 Chassis & Cab 2975 3295 64
KS10734 Fleetside 6.5ft 3158 3711 2554
KS10704 Step-Side 6.5ft 3090 3631 1629
KS10903 Chassis & Cab - - 26
KS10934 Fleetside 8ft 3165 3810 7348
KS10904 Step-Side 8ft 3158 3715 464
KS10905 Panel 3641 3923 -
KS10906 Suburban 3849 4055 -
CS20903 Chassis & Cab 2650 3496 7277
CS20934 Fleetside 8ft 2790 3871 70880
CS20904 Step-Side 8ft 2752 3776 5856
CS20905 Panel 3269 3991 1032
CS20906 Suburban 3441 4113 2246
KE10903 Chassis & Cab 3402 3606 582
KE10934 Fleetside 8ft 3540 4101 6124
KE10904 Step-Side 8ft 3502 4006 953
KE10905 Panel 4019 4221 -
KE10906 Suburban 4190 4343 541
CE21034 Pickup 8.5ft 2854 3912 5281
CE31002 Chassis & Cowl - - 138
CE31003 Chassis & Cab 2725 3641 14873
CE31034 FleetSide 8.5ft 2935 4157 1404
CE31004 Step-Side 9ft 2875 4071 2101
1-Ton Commercial - Model C/Series 30 - 157-in. w.b.
CE31103 Chassis & Cab 2775 3788 -
1971
CS10514 Open Utility 2659 3375 1277
KS10514 Open Utility 3234 3677 17220
CS10703 Chassis & Cab 2656 3090 1476
CS10734 Fleetside 6.5ft 2816 3506 32865
CS10704 Step-Side 6.5ft 2816 3426 19041
CS10903 Chassis & Cab 2689 3107 588
CS10934 Fleetside 8ft 2854 3605 206313
CS10904 Step-Side 8ft 2854 3510 7269
CS10906 Suburban(doors) 3599 3862 4550
CS10906 Suburban(gate) 3631 3870 5395
KS10734 Fleetside 6.5ft 3414 3824 3068
KS10704 Step-Side 6.5ft 3414 3739 1438
KS10904 Step-Side 8ft 3451 3832 364
KS10934 Fleetside 8ft 3541 3927 9417
KS10906 Suburban(doors) 4226 4191 631
KS10906 Suburban(gate) 4256 4191 994
CS20903 Chassis & Cab 2897 3496 4523
CS20904 Step-Side 8ft 3058 3896 3406
CS20934 Fleetside 8ft 3058 3991 62465
CS20906 Suburban(doors) 3760 4245 1343
CS20906 Suburban(gate) 3791 4253 1203
KE10903 Chassis & Cab 3641 3659 509
KE10904 Step-Side 8ft 3804 4061 674
KE10934 Fleetside 8ft 3804 4156 10066
KE10906 Suburban(doors) 4530 4414 256
KE10906 Suburban(gate) 4538 4414 353
CE21034 Pickup 8.5ft 3236 4100 3331
CE31002 Chassis & Cowl - - 139
CE31003 Chassis & Cab 2735 3641 11438
CE31034 FleetSide 8.5ft 2935 4157 1479
CE31004 Step-Side 9ft 2875 4071 1557
CE31103 Chassis & Cab 2775 3788 6071
1972
CS10514 Open Utility 2585 3375 3357
KS10514 Open Utility 3145 3677 44266
CS10703 Chassis & Cab 2530 3090 1640
CS10704 Step-Side 6.5ft 2680 3426 22042
CS10734 Fleetside 6.5ft 2680 3506 39730
CS10903 Chassis & Cab 2560 3107 717
CS10904 Step-Side 8ft 2715 3510 7538
CS10934 Fleetside 8ft 2715 3605 273249
CS10906 Suburban(doors) 3495 3862 6748
CS10906 Suburban(gate) 3525 3870 10757
KS10734 Fleetside 6.5ft 3251 3836 6069
KS10704 Step-Side 6.5ft 3251 3766 1736
KS10904 Step-Side 8ft 3287 3846 407
KS10934 Fleetside 8ft 3287 3926 18431
KS10906 Suburban(doors) 4273 4206 993
KS10906 Suburban(gate) 4305 4206 2145
CS20903 Chassis & Cab 2760 3496 5974
CS20904 Step-Side 8ft 2915 3896 3973
CS20934 Fleetside 8ft 2915 3991 94458
CS20906 Suburban(doors) 3650 4245 2136
CS20906 Suburban(gate) 3680 4253 3141
KE10903 Chassis & Cab 3415 3651 676
KE10904 Step-Side 8ft 3567 4051 755
KE10934 Fleetside 8ft 3567 4141 19648
KE10906 Suburban(doors) 4275 4141 503
KE10906 Suburban(gate) 4308 4585 879
CE21034 Pickup 8.5ft 3088 3950 3328
CE31002 Chassis & Cowl - - 127
CE31003 Chassis & Cab 2845 3641 14988
CE31004 Step-Side 9ft 2990 4071 1542
CE31034 FleetSide 8.5ft 3050 4157 2450
CE31103 Chassis & Cab 2885 3788 8944
John Fabris
67 C10 SWB
John Fabris is offline
Closed Thread
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
