Old 06-09-2004, 05:58 PM   #1
case_bt
case_bt's Avatar
building up engine need some cam sugestions
picked up my short block today from local machine shop it was one they already had built 350 2 bolt 40 over stock cam and pistons I'm going to change the cam I ordered my heads today 64cc 2.02 valves I should get over 9:1 compression and i can go up to .510 lift with the heads I was wanting some cam suggestions I thinking of running the comp cam magnum 280 duration it has .480 lift it has an operating range thats starts at 2000rpm do you think i can get away with running it with a stock torque converter if not what type of cam should i use?
one more ? Can i reuse my balancer off my 327 on this 350?
case_bt is offline   Reply With Quote
Old 06-09-2004, 07:03 PM   #2
CJM72CHEVY
John Deere Tech
Comp Cams has an excellent tech-support line that is made for questions like that. I believe it is 1-800-CAM-HELP but I can't say for certain.
'72 C20 350/TH350/Dana 60 coils Factory Black/Light Green Interior - Undergoing restification and A/C installation. Daily driver.
'72 C20 350/TH350/Dana 60 leafs
Light Blue/White Cab Factory A/C - Currently building a 383 to GMPP HT383 specs.
CJM72CHEVY is offline   Reply With Quote
Old 06-09-2004, 07:36 PM   #3
cdowns
cdowns's Avatar
B-4 picking a camshaft you should set realistic goals as to what you want it to do and how you want it to do it
Old 06-09-2004, 07:59 PM   #4
Bowtie67
Bowtie67's Avatar
I would think your compression would be a little higher than that, most 350 are 8.5cr w/76cc heads, I would think more in line with 9.6cr with 64cc heads. I would think you would be a little better off with the XE268 than that old school cam, you'll find with the shorter intake duration to get a little better lowend and with the exhaut duration longer will equal that of the 280 your looking at for the topend, and should work ok with a stock converter but would work a little better with a 2000/2200 stall. A lot of guys are hitting into the low 13's and some even into the 11's with a 383 and the xe274.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 06-09-2004, 08:16 PM   #5
1972C10
1972C10's Avatar
that comp 480 isnt that great . Get a crane 480 alot better cam for alot less money and both will work with a stock convertor I have seen it I ran a crane with a stock convertor and my friend built and engine with that junky comp 280/480 and he ran stock convertor
IMO the crane is a better grind Just seemed to run better as to where my friends comp always sounded like it was all lope no talk.
1972C10 is offline   Reply With Quote
Old 06-09-2004, 09:08 PM   #6
case_bt
case_bt's Avatar
thanks for all the info gents im going to look into the crane and the xe
Old 06-09-2004, 09:17 PM   #7
case_bt
case_bt's Avatar
by the way it will be a daily driver wel about 3 days a week
Old 06-09-2004, 09:24 PM   #8
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
But what do you expect out of the engine? Do you still want to maintain some low RPM torque, or do you just plan to use your truck as a cruiser with more upper rpm power? As to the harmonic balancer, you could use the one from your 327, but an SFI approved balancer isn't really that expensive. Maybe it's just me, but unless I'm doing an "el-cheapo-get-me-another-6-months" rebuild, I always use a new one.
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 06-09-2004, 10:59 PM   #9
case_bt
case_bt's Avatar
ill go with a new one I want a cruiser but for a truck i still need low-end torque I don't plan on going to the strip or anything and i don't plan on going 100 mph everywhere either
Old 06-09-2004, 11:06 PM   #10
1972C10
1972C10's Avatar
If you want torque or to pull something get a comp 268 or a crane powermax
I had the smallest crane powermax in an engine a few years back with flat tops and a performe intake it was a stout combo the cam was a 427/454 lift
It would run good and still haul stuff. It smoked a new R/T Dakota Wich was back In 99 i guess My cousing had An 2000 R/T
Old 06-10-2004, 09:48 PM   #11
blazinwest
blazinwest's Avatar
get a marine cam, they are cool in trucks
blazinwest is offline   Reply With Quote
Old 06-10-2004, 10:20 PM   #12
case_bt
case_bt's Avatar
Its a toss up between the xe268 or xe274 it says to have a 2200 rpm stall on the 274 is it possible to run with a stock converter
Old 06-11-2004, 07:30 AM   #13
Bowtie67
Bowtie67's Avatar
You will be happier with the xe268 in a 350, the xe274 would be a little better in a 383 or 400, I haven't heard of to many guys complaining about the xe268. if you have around 9.5cr that will perfect for the xe268 but might be a little low for the xe274 in a 350 plus to take advantage you this cam you would also need some low gears, probally in the line of 4.33's or 4.56's for it to operate descently.
2009 Toyota Tundra
Old 06-11-2004, 08:10 AM   #14
case_bt
case_bt's Avatar
ill go with the 268 thanks guys for all your input
Old 06-12-2004, 03:41 AM   #15
SufferInTruth
Does anybody have the Crane 480 grind number?
'71 Chevrolet C10 shortbed - 414" LQ9/4L80e/S91 turbo --- PROJECT!
'99 Chevrolet Camaro Z28 A4 Yank 4200 stall/AZPS 03 cam (242/248 .621"/.615" @ .050" lift)/UMI 4130 suspension/True Duals/Moser 9" 3.73/AR Torq Thrust M's Black
SufferInTruth is offline   Reply With Quote
Old 06-13-2004, 03:34 AM   #16
1972C10
1972C10's Avatar
It's a really good came for the money Here ya go
270-100072 Advertised Duration: 284
Duration @ .050: 228
Lobe Separation: 112
Gross Lift: .480''
RPM Range: 3000-6000 $99.99
Old 06-14-2004, 03:10 AM   #17
500HP/SB
please don't break
500HP/SB's Avatar
i run a comp cams xe268 in my 350 with 10:1 comp and an edelbrock c-26 intake manifold (dual quads). i can pull up the hill to my house (pretty slow and steep) at 1000 rpms in second with 3:73's and 35 in tires. it can pull down low but it doesnt start making power until about 2500 and realy pulls from 3k+
70 k10 35s 350/sm465/np205
titanspeed.com
500HP/SB is offline   Reply With Quote
Old 06-14-2004, 03:36 AM   #18
SweetandLong68
Nitrous Freak
SweetandLong68's Avatar
Definetly gonna have to go with an higher stall coverter with the CompCams 280H. 1000rpm over stock should work.
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 06-15-2004, 02:02 PM   #19
blazinwest
blazinwest's Avatar
lifters
what kind of lifters are you running?
i have a crane cam like yours that i am about to put in my 78 blazer 4x4 350/th350
i was wondering if roades lifters were any good?
any suggestions?
Old 06-15-2004, 09:01 PM   #20
1972C10
1972C10's Avatar
any suggestions?
I am running the lifters that came with the cam I had a set of rhoades lifters but i didnt want to jack with them as i recall they had to be set like solids I figure that crane sends the lifters with the cam and they are suited for it isnt that radical of an idle
I have mine set up 4 degrees advanced with one of them cloyed double roller chains .
That gives the came more bottom end
Old 06-16-2004, 10:05 PM   #21
SweetandLong68
Nitrous Freak
Are you insane? hahaha Saying the Comp 280H (.480lift) isn't all that great of a cam. The 280H is a very good cam. Not a throw it in and go cam like a 4x4 cam or a RV cam. But if you want a small torquey cam that you wont have to run a stall in go with one of those. But saying the 280H isnt a great cam is silly. My 500hp 355ci SBC shows just how bad it is! BAD to the bone maybe. And people said it couldn't be done. hahaha
lata
CHRIS
Old 06-16-2004, 10:14 PM   #22
1972C10
1972C10's Avatar
Well thats all well and good But Im My Opinion and experience i do not like the comp 480 lift 280 duration cam
Id rather have the crane 480 lift 284 duration
I put in several of both and i am very happy with the crane seems a better cam to me
Old 06-16-2004, 11:19 PM   #23
TIMSPEED
TIMSPEED's Avatar
On my setup, I'm going to have a:
355 9:1 Bottom End
Vortec #885 Heads (Upgraded to accept a .525 lift cam)
Comp XE274 with 1.5:1 Roller Rockers
Performer RPM Air-Gap
Holley 750cfm 4160.
Backed by a TH350 with a 2500 stall and 3.42 gears with 28" tires.
Hopefully, with my combo, good air and good traction, I can click off 12's.
BTW: The XE274 is 230/236 490/490 @ .050 on a 110 LSA. Makes power from 1800-6000.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 06-16-2004, 11:39 PM   #24
SweetandLong68
Nitrous Freak
Well I must say I was assuming that you were using some sort of ratio rocker. I am using CompCams Magnum 1.52s and that may be the difference maker.
Of course everyone has opinions...But they know what 'they' say about those... hehe
I am sure the Crane is a fine cam but to say that the Comp 280H is a "not all that great cam" would be out of line to me.
lata
CHRIS
Old 06-17-2004, 12:18 AM   #25
bagged87chevy
bagged87chevy's Avatar
I'm running the comp 280h in my 358ci. I absolutely love the cam! It sounds awesome I didn't need a new torque converter. This cam will definately wake up your engine in the 2k and up range. And to say this cam is junk doesn't sit well with me. I'm not so hot on the same grind crane cam. I've had experience with both and made more power with the comp.
I want my truck done!
bagged87chevy is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
