Just Don't Stop!
LS1/T56 installed!
Ladies and gentlemen, it is finally in. I still have some motor mount issues with the vette headers to work out but it is VERY CLOSE. I can feel it now.
Next up is a custom shifter for the 6 speed, having my LS1 driveshaft lengthened and working in the hydraulic clutch linkage. Almost, almost... |
Just Don't Stop!
looks like it was meant to be there
Big Block
![]() Join Date: Dec 2003
Sweeeeeet!!!!!! Was That A One Man Job??
1970 CST/10 LWB factory buckets, air, PS, PB, cruise, 402, th400 - Sold.... ![]() 1997 Chevy ext cab Z-71 |
The oddest Todd around
What does it take to get one of those transmissions hooked up behind a pre-86 350sbc? I want the 6 speed, but I don't want to have to deal with all the new "fang dangled" computer stuff on multi-port injected engines.
Todd |
That is cool. I haven't seen anyone else with an LS1 and a 6-speed yet. I'm going old school with a 454/th400 combo in my 67, but I'm sure yours will do a burnout just as well as mine!!!!
Oilfield Trash
![]() Join Date: Sep 2003
How well does the shifter line up?
05 fURD Superduty F350/ 5.9Cummins/Allison Auto 97 Dodge 1500 2wd SWB 5.9l (wifes wheels) 80 GMC K10 High Sierra bone stock 71 Chevy C-10 lwb 70 Chevelle 350SS long term project 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
#7 | |
Just Don't Stop!
haha
#8 | |
Just Don't Stop!
The fuel injection stuff is the beauty of the monster IMHO. However you can hook up a T56 6 speed easily with a LT1 six speed tranny (93-97) F-Body if you are using an older block setup. |
#9 | |
Just Don't Stop!
I think it will. This motor makes 345 hp and 390 ft pds stock. Then I did a cam/springs and milled the heads alittle. Should around 400 horse and 500 torque... |
#10 | |
Just Don't Stop!
Still working on that, will get pics up after I figure it all out. |
Oilfield Trash
koo
Looks like it's coming together
68 short fleet with 71 front clip 2wd jaguar blue 99 chevy ext cab shrtbed z71 loaded 99 chevy swb fleetside(daily driver) Sparks, Nevada |
#13 |
About time someone else went with the 6 speed behind the LS1 swap. Looking good.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
#14 |
I especially like the .49 final gear of the 6 speed (or is that only the six speed in the corvette?). With a final drive of .49 you can get away with 4.10's easily.
#15 |
Active Member
![]() Join Date: Feb 2000
I think there are a lot of us that would like to have this set up- myself included. There's nothing like rowing thru the gears with a nice sounding set of pipes, especially if you're a former "double clutchin fool from the motor pool" Keep us posted on the progress. luv those headers!
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
#16 |
For all you guys(me included) who want a carb instead of messing with computers and wiring, there are now intakes available for LS1's that are for a four barrel carb. I think Chevy makes them now, I just saw it in a magazine somewhere. The LS1 makes a lot of power, I have had a 98 Z28 1LE and a 2000 Z28 and they were a blast, but they wont have the torque that a nicely built big block would have, but they will rev a lot quicker and higher.
72 Chevy C20, SOLD (Dang it.) 09 Challanger RT six speed in all black. 74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power. 73 C10 long bed, 350/350 combo, nice shape. |
#17 |
Green club
I love it, wish I had the money to pick up one of those combos and stick it in the truck.
Keep us updated on the progress please
71 short/fleet ECE 4/6 drop, vortec/voodoo equipped355/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, suicide doors baby Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
#18 |
Insert funny comment.
![]() Join Date: Dec 1999
Firstgen, What did you end up doing for a gas tank/fuel pump?
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com Last edited by lock; 07-10-2004 at 01:09 PM. |
#19 |
Just Don't Stop!
It really wasn't that expensive of a swap. I paid $800 for the motor (ok I know it was a steal) and $1000 for the complete 6 speed and driveshaft, shifter, clutch etc. There is definatly ALOT of misc crap you have to do before it runs but it's under $1500. All in all I think it is just as cheap as any other build up. Figure that you will spend AT LEAST $2500 for a healthy SBC carbed and another $1000 for a good tranny and stall...
#20 | |
Just Don't Stop!
Keep in mind that there is no dizzy on the LS1 and no way to add one so you will have some fun with that. I have heard of carbed LT1's since they have a sort of mounted weird crank trigger/dizzy idea called optispark or (optipuke ).For $350 several compaines on the net will modify and simplify the hook up of these wiring harnesses for you so that you can retain everything, fuel injection, self learning and calibrating mass air flow (no more swapping jets), 8 seperate coil packs (one for every cyclinder). These motors also have knock sensors right underneith the intake and automatically retard timing anytime detonation is sensed. That is only the begenning. Most of these motors were underrated from GM. The silverado SS guys have taken the trucks to the dyno with only a LS6 cam and put down 380 RWHP!!! This is with the front driveshaft removed of course. They are still slow because they weigh in the 7,000 pound range. I just think it's cool
#21 | |
Green club
#22 | |
Don't say "Oops!", Doctor
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
#23 |
You can get aftermarket ignition system that will work with the coil on plug ignition the LS1 has. Also, step up the power with a LS6 conversion kit to get over 400 hp. Its expensive, like $2,300, but you get the complete heads, intake, cam, rockers , gaskets, etc. to do the whole thing. Make sure you get a 00 up LS1. I know for sure that the 98 blocks can not be bored over but the later ones can. If you scuff a liner in the newer blocks it can be bored out and reused, the 98 blocks can't(this is in the F bodies, not sure about the 97-98 Vette blocks). The Chevy SS is a joke compared to the Lightning and even more compared to the SRT Ram, 500 hp 500 ft/pounds tprque with a real transmission, a manual six speed. Plus the Chevy is ugly in my opinion. The Lightning is supposedly going to be offered with more power and a manual trans also within a couple years from what I have heard. Wish Chevy would actually build something that would compete with those other two trucks.
#24 |
I just looked at the pictures closer, that looks like a cast iron block with some rust starting. If thats a cast iron block its not the true LS1, its a LS1 design but with either 4.8, 5.3, or 6.0 liter displacement. The LS1 in the Vette and F bodies are all aluminum from top to bottom. It displaced 5.6 liters or 346 cubic inches. If you got the 6.0 you got a good engine though, you can put a stroker kit in them and make them huge and the cast iron block is stronger for the abuse a truck would give them.
#25 |
Just Don't Stop!
yeah it's a gen iii LS1 motor. If you read the thread I said 6.0l LS1. Whatever LS6 kit you are looking at is a waste of money. They heads are almost identical to the basic LS1 but they do have .5 higher CR. For way less than that you can make over 400 horse (cam/springs and long tubes). The 4.8, 5.3, 5.7, 6.0 use almost identical heads (at least in design) the main difference is the CC, valve size, bore. The intakes swap over on all motors. so do the majority of the internals minus the pistons obviously. Even the cam specs in my 6.0 motor are the same as the 2001-2002 LS1. The valve train is identical. Not sure where you get 5.6 liter? It is actually 5669.9 CC which is rounds to 5.7.
So how does the aftermarket ignition get the trigger signal? I'm sure there is a aftermarket one available however the point being that it would be way more expensive than wiring the EFI up. Check out Keiser engineering for a modified 6 speed tranny that will let you move the shifter location forward and use the stock consoul on your Chevelle. They sell the whole tranny package or you can have your modified for 699. ouch. I'd have to agree that the SS is the slower of the bunch. However this is factored to the weight and AWD. The SRT 10 is a $h!tty truck for the money. They run 13.9's at the track with 500 horse??? The Lightnings run alot better and the SS being HALF the money runs slightly behind the SRT 10. Sorry for the long post, I'm "at work" and being paid for typin on this BS forum. Good luck, Taylor Last edited by FirstGen; 07-11-2004 at 02:25 AM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
