Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Body
Old 03-19-2001, 12:04 PM   #1
lock
Insert funny comment.
lock's Avatar
Post Wavy rear cab wall
I dont know the real name for it but the outside cab wall under the rear window on my truck is very wavy. Mainly the part between the top of the bed and the bottom of the wall. It looks like major work to get it reasonably straight. Is there replacement metal for this part or do I just need a real good body man? Im not after a show truck but I do want it reasonably straight.
68 C10 Stepside w/ 350 LT-1
86 IROC - 383/T56
- Mark
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
-68 C10, LT1 - Undergoing Frame off resto
-06 Colorado
http://www.iroc-ss.com
lock is offline   Reply With Quote
Old 03-19-2001, 06:59 PM   #2
Benrs86
Benrs86's Avatar
Post
Well mine was real wavy and the body man fixed it really good. He left the part that is covered by the box semi-wavy but he fixed the part above the box good. I think about any good body man should be able to fix it. I don't know of any patch panels but since it is a flat spot maybe you could make one? Guess this don't help much. Good luck, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 03-21-2001, 09:52 AM   #3
Randy70C-10
Randy70C-10's Avatar
Post
If the waves aren't too deep, skim the entire section with body filler and sand it back down with a long sanding board. Always sand in an x-pattern, never straight back and forth, or you'll end up with grooves.
Randy70C-10
70 C-10 SWB stepside
47 chevy fleetline
30 Model A coupe
87 Harley Sportster
Built in USA!!!!
Randy70C-10 is offline   Reply With Quote
Thread Tools
Display Modes
Design By: Scott Stubblefield Ported to vB by: Miner
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
