Old 11-22-2004, 02:21 PM   #1
dunkinhard02
dunkinhard02's Avatar
Question Engine casting 3970010...
I finally got around to getting the casting number off of my block, and it seems that I have just another run of the mill 350 chevy block. The code is 3970010 (69-79 or 80 350). I am trying to figure out any other information about this block, what year, what it came from, etc. I have not dropped the pan yet, so I do not know if it has 2 or 4 bolt mains. I am assuming that it is a 350 and not one of the '69 302s or 327s. I could not find a date code, but stamped onto the flat panel above the oil filter are the codes 371, 335, and 135N. The carb is a 2BBL rochester coded 17056114 and 265 5ABP which appears to come back to a 76 Monte Carlo with a 305. There is a 16 cast into the bottom of the block below the fuel pump. Also, the intake is stamped with 3887773 and GM2. The crank pulley has 458530CH stamped onto it. The entire engine is painted in chevy blue as seen in the attached picture. It was raining when I took it, and I haven’t had time to clean up under the hood. Please excuse the insane amount of blue wire loom the previous owner has scattered around the engine compartment. Thank you in advance for any more information you might have on this block.
PS...I know that the fan is not designed for a V-Belt system, I have replaced it since this photo was taken.
68 K10-350/400 Turbo-35x16x15 SS Boggers
dunkinhard02 is offline   Reply With Quote
Old 11-22-2004, 05:00 PM   #2
dons454s
dons454s's Avatar
get the numbers and letters off the flat pad on the front of the block that is under the alt. and they will get you more info
dons454s is offline   Reply With Quote
Old 11-22-2004, 05:13 PM   #3
grayw0lf
010 is the preferred 350 block. Correct me if I'm wrong, but it has 1% tin & 2% nickel in the cast mix that helps it to wear a little better.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 11-22-2004, 05:32 PM   #4
Bryce M
Its pretty much the most common small block casting number it could be a 4 bolt some are some arent it doesnt really matter 2 bolt will hold up to more power then you would want in a street motor In front of the head there should be the prefix code it will narrow it down to only a few cars in a few years If the block has been decked you wont find it or much of it
Bryce M is offline   Reply With Quote
Old 11-22-2004, 06:16 PM   #5
Randy70C-10
Randy70C-10's Avatar
That's a high-nickle block, check to see if it's a four bolt main. Those are great blocks, I have three of them.
Randy70C-10 is offline   Reply With Quote
Old 11-22-2004, 06:20 PM   #6
Sweet72
Sweet72's Avatar
From what I have heard you need to pull the front cover (timing chain) off and look for a 10 or 20 in the casting. The 20 being the preferred higher % nickle alloy. My 3970010 350 block is a 10 and I'm sure it'll wear just fine as most blocks of that era were 10's.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
