Old 12-17-2004, 04:49 PM   #1
grw800
Plastic Timing Gears?
I know from experience with my '78 K25 and '79 G15 that the plastic timing gears can be counted on to fail at right around 130K miles. If I knew then what I know now, the bent valves and bent pushrods could have been avoided by replacing the timing gears sooner. My neighbor has a '94 C10 that is nearing the magic number. Does the' 94 350 engine also have the plastic gears?
grw800 is offline   Reply With Quote
Old 12-17-2004, 05:21 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
While I can not say with 100% assurance...I am pretty sure the answer is no.
Old 12-17-2004, 08:08 PM   #3
Blue Beard
Blue Beard's Avatar
does the 250 6cyl have plastic gears?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 12-17-2004, 08:26 PM   #4
Stevetra
How about a 92 350 in a truck?
Stevetra is offline   Reply With Quote
Old 12-17-2004, 10:41 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
They went to metal gears in the V8's in the later engines as far as I've ever seen. The latest I've seen with the phenolic gear was an 85 if I remember correctly.
Beard, yes, the 250 should have 1 aluminum gear according to Santucci's 6 cylinder manual, but no plastic gears.
Kevin -
My Instagram
Old 12-17-2004, 10:50 PM   #6
Blue Beard
Blue Beard's Avatar
Sorry to say, I've not heard of that manual.
Thought maybe I was having problems with mine. Seems to be a good 6 buy no power range.
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 12-17-2004, 10:52 PM   #7
Tx Firefighter
Chevrolet Inline Six-Cylinder power manual by Leo Santucci.
Buy one.
No joke.
Every 6 cylinder guy simply must have this book. It's under 20 bucks new. Has factory engineering drawings showing sizes of bolt holes, casting numbers, build up guidelines, everything.
Kevin -
My Instagram
Old 12-17-2004, 11:16 PM   #8
grayw0lf
Correct me if I'm wrong, but the inline 6's have plastic counter rotating gears. No chain.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 12-17-2004, 11:53 PM   #9
Senor_paco
The reason they have palstic or resin gears is to keep the noise down. I've had many late 60's early 70's engines have chains jump, or worse, plastic pieces come off the gears, and jam up the oil pump. fun!. you can really hear those metal gears whirring. Dunno 'bout later vehicles. kinda stopped caring about '82-up.
Senor_paco is offline   Reply With Quote
Old 12-18-2004, 12:08 AM   #10
Destructo
Buy one.
No joke.
Sounds like I need one of those to go with the 250ci I6 in our 18' tri-hull!
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 12-18-2004, 09:24 AM   #11
Tx Firefighter
Negative
They have a steel crank gear that meshes directly with an aluminum cam gear. No chain, just gear to gear.
Kevin -
My Instagram
Old 12-19-2004, 03:38 AM   #12
4x4Poet
I just disassembled my K10's 350. Looks to be never rebuilt. The plastic teeth on the cam sprocket were all there, just not altogether.
One could see about 30 stress fractures; half open cracks, half cracks that hadn't opened yet. The timing chain had mucho slop. At least an inch movement installed. I'm surprised the plastic held out as long as it did. I'd guess that the loose chain rode easy on the teeth so it didn't break. Just conjecture, really.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 12-20-2004, 10:56 AM   #13
mhicks
mhicks's Avatar
My son's IL-6 had plastic gears. It was in a '74 Chevy. The gear went out on his and had to replace both of them.
mhicks is offline   Reply With Quote
Old 12-20-2004, 11:43 AM   #14
gn4u2c
gn4u2c's Avatar
Just did a 91 suburban rebuild . It was a plastic gear unit. definatly stock. 2 missing teeth from the can sprocket so I had to pull the oil pan Hmm ... well I found 1 of them anyway. guess the other came out in an oil change or something alson the way.
gn4u2c is offline   Reply With Quote
Old 12-23-2004, 10:49 PM   #15
jimfulco
6-cyl. engines destined for car use were made with plastic timing gears, but not the same type of plastic used in V8's. Truck 6's had metal gears.
jimfulco is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
