Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 01-22-2005, 08:46 PM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
camaro tach
this question is asked so much that i thought i would post as much about this as possible in one place. i've never given instructions like this before so bear with me. ok...when you get down to it it's really easy to do. i went on ebay and bought a camaro tach for 11.50. correct me if im wrong but 70-81 are the years that work. there are a couple different needle choices so that's the main deciding factor when purchasing. first start by taking your guage panel apart. there are i think 18? screws that hold the bezel on. i started with the front metal plate which is shown here. cut out the area outlined in red. be careful and take your time cut only to the depressed area. i used a dremel tool to do this.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline
Old 01-22-2005, 08:52 PM   #2
67ChevyC10Stepside
the next step is the lens. i used cp and some scrubbing to remove the lines shown in red here.
Old 01-22-2005, 09:00 PM   #3
67ChevyC10Stepside
next the tach needs some work done to it. it comes with an insulator plate on it. you need to remove that. it will leave the tach with it's head the wires and a little circuit board with a plastic plate. just take the plate off. make a note of where the wires go on the circuit (they are engraved on the insulator plate)
Old 01-22-2005, 09:04 PM   #4
67ChevyC10Stepside
next you have the back plate. some people beat the hump flat i just cut it out. the red part is what gets in the way. the black dots is one place you can mount your circuit. i used the plastic plate that comes with the tach and mounted it on the backing plate of my guage setup that way i can connect the wires to the back of the setup and be done.
Old 01-22-2005, 09:06 PM   #5
67ChevyC10Stepside
ok...now you will have to trim the top and bottom of the tach a little...i just used some tin snips.(it's too tall to fit in the top plate) when you take the tach apart there is a oil light there that leaves a open space on the face. what i did for this was take electrical tape...and put a short piece onto a longer piece so that the hole was covered with the non sticky side but there was enough to secure it from the back side.
Old 01-22-2005, 09:09 PM   #6
67ChevyC10Stepside
then you are ready to start putting it back together.
Old 01-22-2005, 09:10 PM   #7
67ChevyC10Stepside
here is mine. it still has the crappy bezel on it etc but i am gonna be changing all that. i will get pics of the inside and back of it when i work on my truck again.
Old 01-22-2005, 09:49 PM   #8
c10crazy
Like a Rock!
c10crazy's Avatar
Here is the original post from awhile back with instructions also. http://67-72chevytrucks.com/vboard/s...threadid=37673
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline
Old 01-22-2005, 09:51 PM   #9
67ChevyC10Stepside
yeah he did it harder way than me....he kept the circuit floating around inside. i put it through the backing plate. either way works though.
Old 01-22-2005, 11:33 PM   #10
jhwkns
Registered Cruiser
jhwkns's Avatar
A couple of those pictures look familar Not all gen.II camaro tachs are the same. The one I used required me to cut a 1 3/4" hole in the back of the housing. It protruded through only about 1/4" so the printed circuit fit over it no problem. I sealed the hole with some 10mil vinyl tape. To allow light to reach the face I spaced it away from the front plate using cabinet door silencing pads. These are adhesive backed, and available at any hardware store. I'm probably going to disassemble mine to repaint the needles. When I do I'll take a couple more pictures.
I intend to live forever. So far, so good.
jhwkns is offline
Old 01-22-2005, 11:57 PM   #11
67ChevyC10Stepside
which one is yours? i was told to cut away part of the lip for the light to show through.
Old 01-22-2005, 11:58 PM   #12
67ChevyC10Stepside
every 70-81 tach i have seen was the same with a couple needles the only difference.
Old 01-23-2005, 12:21 AM   #13
jhwkns
Registered Cruiser
jhwkns's Avatar
Mines the one on the oak table.
jhwkns is offline
Old 01-23-2005, 12:40 AM   #14
67ChevyC10Stepside
how did you do your wire hookups?
Old 02-01-2005, 11:41 PM   #15
67ChevyC10Stepside
ok...you people better appreciate these pics. i broke my wire connector for my coil taking this freakin panel out lol
Old 02-07-2005, 07:01 PM   #16
Blue85
Oilfield Trash
Blue85's Avatar
so what year camaro tach will work?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline
Old 02-07-2005, 08:00 PM   #17
67ChevyC10Stepside
Old 02-20-2005, 02:41 PM   #18
chevy72blu
chevy72blu's Avatar
70-81
Im gonna do it this weekend =)
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline
Closed Thread
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
