Old 05-03-2005, 11:20 PM   #1
mdoncall
250 6 cylinder won't start
Great to find a website for Chevy truck owners and i could sure use some help from any and all with a motor prob i have.I have a 1972 Chevy C/10 with the original 250 six banger in it.The truck has been sitting for four years without being ran and i recently decided to put it back in use and start a restore project on it.The truck was running fine when it was last ran four years ago.I'll try to keep this brief and not take up too much space here.I have installed new plugs,points,condenser,plug wires,coil,dist.cap and a rotor button.She still won't run.I made sure the rotor button was installed correctly and the points gapped right and the firing order was right.I'm at an end and don't have a clue as to what to check next.Sorry for the lengthy post but any and all help is much appreciated.
mdoncall is offline   Reply With Quote
Old 05-04-2005, 01:40 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Well you mentioned the ignition system but what about fuel and compression. Are you getting a spark? Did you clean out the fuel tank, put in a new filter and clean the carb. You could have some valves stuck open. Did you change the oil and filter. You should. I would pull the valve cover and see if all the valves are moving.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-04-2005, 02:36 AM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Vette asks some good questions. Start with the basics.
Fuel. Does the carb squirt fuel when the throttle is pumped? If not, check the flow by disconnecting the fuel line and pumping into a container by cranking the engine. No flow, check the lines, filter and pump.
Ignition. Remove a spark plug that you can lay on a grounded surface and crank the engine. No spark, remove the distributor cap and see if the points are opening. Use a voltmeter and start checking voltages, making sure you have power in and out of the coil and distributor.
If you have fuel and spark, check your plug wires for the proper order. The firing order is 1-5-3-4-2-6. #1 on the cap is about 2 o'clock, the spot closest to the #1 plug. Go clockwise on the firing order. As long as you didn't move the distributor the timing should be okay, but that is next to check.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-04-2005, 01:14 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Fred he said he has the 250 six banger , isn't that the inline six? What would the firing order be for that?
VetteVet
Old 05-04-2005, 01:49 PM   #5
79C10
The 250 is an inline six.
My bet is on the carburator. sitting for four years has no doubt dried out some of the gaskets in the carb not to mention other places. I bet it needs to be rebuilt. I would check spark first and if you have spark the dump a little gas down the carb and then see if she'll fire up.
79C10 is offline   Reply With Quote
Old 05-06-2005, 01:43 AM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
1-5-3-6-2-4
1_5_3_6_2_4. Clockwise Firing Order.
Clockwise to ADV, CCW to retard.
HTH
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
