Old 05-18-2005, 12:14 AM   #1
chevy72blu
chevy72blu's Avatar
Did GM make a non-vortec center bolt head?
Ok- I just got in a lengthy argument with an employee of a local performance part shop. I told him about how I modified my non-vortec intake to work with my 1.94/1.5 Vortec heads. He told me that the only difference was the bolt angles- and said there was nothing wrong with my set-up. After that, he proceeded to tell me that Vortec heads ONLY have 8 bolts, and all of the bolts are perpendicular(He showed me an intake like this, and its certainly not what mine looks like). I told him that I knew mine were vortec's
[I know they are vortecs. I assembled them myself- and my mechanic friend gave me a big lesson on what makes a vortec head a vortec head- showing me the differences. We honed the bowls in his shop].
He said that my heads arent vortec, and they are just an early Center-bolt style stock GM head.
Am I totally wrong here? Did I get ripped off when I bought my heads? This guy totally confused me!
RIP EastSideLowLife
chevy72blu is offline   Reply With Quote
Old 05-18-2005, 12:17 AM   #2
kwmech
The TBI heads had the center bolt valve covers, and have the 12 bolt intake and the 4 center bolt holes were angled differently.
Old 05-18-2005, 12:18 AM   #3
skid
Yep!
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 05-18-2005, 12:19 AM   #4
cableguy0
vortecs should only have 4 bolts per side on the intake not 6 like the older gm stuff. sounds like you got ripped off. and on the vortec heads all the bolts go straight down. heres some pictures i found to show the difference http://www.carcraft.com/techarticles/996/index2.html
No more truck for now. Parted it out and sold everything to fund buying a house.Next truck will be another 67-72 most likely LS powered. Shortly I will be looking for preferably a 71 or 72 in decent condition on the cheap as long as it isn't a basket case I don't care about condition. Its the first time since I have had my license I havent had something fun to drive and I dont like it
cableguy0 is offline   Reply With Quote
Old 05-18-2005, 12:20 AM   #5
HeavyD
HeavyD's Avatar
Yes, GM made non-vortec center bolt valve cover heads, if that's what you mean. IIRC, Vortecs have a "sawtooth" stamping on the front of at least one head. Best to check the casting numbers and ask someone on here what you have.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 05-18-2005, 12:33 AM   #6
chevy72blu
chevy72blu's Avatar
ok... so what are my heads exactly? I'll go check the casting numbers tomorrow.
They are the 12 bolt kind, with the 4 center bolts angled perpendicularly.
I've seen listings on ebay for heads that look exactly line mine, that claim to be vortec. Is this a common mistake?
The truck moves like hell for such a mild cam. It does 15.6's very consistantly, even with the wrong intake(well apparently it *is* right)
Ugh..
RIP EastSideLowLife
Old 05-18-2005, 12:37 AM   #7
badone07
Project 2 Resume
badone07's Avatar
So do the TPI heads.
John
1984 C30 Chevy Crew Cab Dually
1998 Jeep Cherokee 4x4
2004 Chevy Trailblazer 4x4 (wife's)
1970 Mustang FB fully tubed (getting 521 BBF & powerglide)
1978 Nova 2dr (going BBCaddy & S.P. th400)
1984 Monte SS (circle track car)
badone07 is offline   Reply With Quote
Old 05-18-2005, 12:40 AM   #8
cableguy0
your heads are just run of the mill stock centerbolt heads from 86 to 95 or so. they are generally thinner cast than older stuff and definately not optimal for performance stuff
Old 05-18-2005, 12:44 AM   #9
badone07
Project 2 Resume
badone07's Avatar
Ugh..
In the past I've emailed sellers on eBay who had them deliberately listed incorrect and continue to do so. I've also warned a few bidders. Yeah, I know but screw eBay's BS policy, can't stand scammers. They always seem to sell as vortecs and they get positive feedback from the sucker that "wins." Go figure. That's why casting numbers are important to get.
John
Old 05-18-2005, 08:04 AM   #10
smokekiki
Mike
smokekiki's Avatar
It takes a lot of work to make a non vortec manifold work.The angle that the intake meets the head is completly different.Takes lots of welding and macchine work.When vortecs first came out there was not many performance intakes available.They had to be built.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 05-18-2005, 08:45 AM   #11
chevy72blu
chevy72blu's Avatar
.... Thank you guys for the help.
I'll get the casting numbers this afternoon. Is there a site that I can look them up on?
RIP EastSideLowLife
Old 05-18-2005, 09:50 AM   #12
badone07
Project 2 Resume
badone07's Avatar
www.mortec.com
There are a few others but the most common are 191 (305 58cc) & 193 (350 64cc) which are both TBI heads. Then the 081 (305 58cc) & 083 (350 64cc)TPI heads.
John
Old 05-18-2005, 05:30 PM   #13
chevy72blu
chevy72blu's Avatar
I just pulled the valve cover off the driver side(2-4-6-8 cyl's)
and I got the casting:
14102193
on mortec, it said:
14102193...87-up...305/350......1.94"/1.5" valves
Is this a TBI or a TPI head?
RIP EastSideLowLife
Old 05-18-2005, 06:07 PM   #14
badone07
Project 2 Resume
badone07's Avatar
Yup, you have 350 64cc TBI swirl ports. They don't breathe in the upper rpm ranges. Good for low end though. You could grind the swirls out. But for what you do with your truck I would just swap them for actual vortecs or go aftermarket. Probably wouldn't bother with a set of TPI heads because they'll need some work too. Live and learn I guess.
John
Old 05-18-2005, 07:25 PM   #15
chevy72blu
chevy72blu's Avatar
wow. I really feel like a dumbass. I bought them from my "mechanic", who is a friend of mine. He has built some serious hot-rods in his time, but he's an older guy, and hes pretty "old-school". I honestly think he just asumed they were vortec heads because of the bowl design. I only payed him like 150 bucks a peice for them, and he helped me assemble them and put em on. I guess it was worth it just for the experiance, and im sure they flow a little better than the stock "L82" crate motor heads that were on it. I know he doesnt know much about new engine tech, but he sure has made my truck damn consistant. It can duplicate runs in the hundreth's on command. It just upsets me to know how much more power my truck *should* be making right now. I mean, it isnt a slouch, but I wouldnt mind it droppin the ET a little.
We are in the process of putting a motor for it together right now anyway. He had a short deck 427 block that we planned on building, but he decided against it because of part cost. He has a sbc 400 which has been freshly bored to .030, decked, and ready to go. We're going to put a set of AFR aluminum heads on it(2.02/1.80), and increase the stroke. Forged dished flat tops- something to the tune of 10.25 compression, and about 425-430 cubes. It'll still be a reliable street motor(it'll easilly run on 91 octane. And maybe even 89 with some timing taken out)
And the best part is, as long as I do all the work, he isnt charging me a dime for it. He has the parts laying around, and doesnt have any use for em. I just have to give him my motor to put in a car he's restoring as payment!
Thank you guys for the help!
RIP EastSideLowLife
Old 05-18-2005, 08:08 PM   #16
tmcgrawlookalike
just remember the actual "vortec" head didn`t come out until `96.alot of people assume that the `87 up heads,w/center bolt v/covers were vortecs.
tmcgrawlookalike is offline   Reply With Quote
Old 05-18-2005, 10:55 PM   #17
funky3821
My brain fell out
funky3821's Avatar
Ok another question about the heads!
I was looking through that motec page and I found these two vortec casting numbers!
10239906...(year)96-up...350.........."Vortec 5700", "L31", 64cc chamber, 170cc intake port, 1.94"/1.5" valves
And
12558062...(year)98......350..........L31 Vortec, truck, 64cc chambers, 1.94/1.5, 170cc intake port
Whats the differance?
'96 Monte Carlo: 15.974 at 86.xx
3400sfi swap; UD pulley, P&P heads, intakes, CAI, exhaust, Custom DHP PCM
Performance parts for you 3100sfi/3400sfi?
Go here
'88 Chevy Silverado w/305
funky3821 is offline   Reply With Quote
Old 05-18-2005, 11:13 PM   #18
shadetree
shadetree's Avatar
In my opnion, you did NOT get ripped off. You got a good deal on decent (non vortec) heads.
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 05-19-2005, 12:19 AM   #19
badone07
Project 2 Resume
badone07's Avatar
Jeez, had a post disappear in here. Anyway, were they worth close to $300 for a used set...no. Considering all that he's been doing for you, you really didn't get ripped off. You're still making out. If you're bracket racing you want to be consistant anyway.
Here's what you have in pic 1...
Vortec in pic 2...
Funky3821, no difference really, just actual casting number.
John
Old 05-19-2005, 04:03 PM   #20
Jason915
15.6 is good I doubt if a head swap to L31's would be worth your time and money. Just spray a 150-200 shot on it and replace the heads when they fail lol
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 05-19-2005, 07:13 PM   #21
Tom
driving is in my blood
Tom's Avatar
They're a 30hp or so boost to any pre-vortec headed motor, thats worth the time and money to me.
The difference between the 906 and 062 castings is [drum roll] nothing! Some of the 062 castings had different seats installed for 3/4-1ton HD applications. Some claim that hurt flow, GM stated it didn't. I belive they don't flow any different myself.
-98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags, Kicker sterio.
-06 CBR600F4i: 110mph in 2nd at 14,000rpm= happiness.
Old 05-19-2005, 08:37 PM   #22
qksilver
I have seen complete "new" vortec from a couple of catalog companies for around $450
qksilver is offline   Reply With Quote
Old 05-21-2005, 01:42 AM   #23
funky3821
My brain fell out
funky3821's Avatar
Do you people know about http://www.gmpartsdirect.com/
Go here
Old 05-23-2005, 08:44 AM   #24
Jason915
30 HP is a good gain just by switching heads, but I wouldn't bother with a head swap unless I could bolt on 50 HP, unless something is wrong with the cylinder heads on the truck and you just looking to replace the cylinder heads with some factory cast heads.
Old 05-23-2005, 03:55 PM   #25
jamis
F.A.S.T. president
jamis's Avatar
@ chevy72blue
I know we got into a brow beating contest before, and I would like to apologise. Here is a link that can better explain the vortec head which is the L31 head.
One thing that I would like to clarify the "vortec" that has been rated so well is the L31 design that first apeared in the 98 trucks. But GM calls just about all their motors after 97 "vortecs" 4,5, 6,and 8 cyls use the Vortec name. Thats why you see a lot of people selling vortec heads..... but it is not the L31 vortec head thats been a good performer. Someone may be selling you a "vortec" head with out any intended malice, its our own fault we made that Vortec name stick, when it can mean alot of diffrent models.
http://www.sallee-chevrolet.com/Cyli...ds/Vortec.html
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
