Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 05-21-2005, 06:30 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Question CS130 Alternator wiring question
Has anyone installed a CS130 alternator (later model GM) and if so how did you wire it up? I have no idiot light for the alternator.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline
Old 05-21-2005, 09:02 PM   #2
neonlarry
neonlarry's Avatar
The battery wire should be obvious. The S terminal isthe voltage sensing wire, hook the to the origional buss bar(red wires on DS fender well). The L terminal goes to a switched ignition source THRU A 35-100ohm 3+watt resistor. This circuit needs this resistor to keep from frying the electronics in the Alt.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline
Old 05-21-2005, 09:12 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
So if you have the light do you still need a resistor?
Smitty
71 C10 283/3SPD (I know its not original but I like the motor) 4 Whl Disks,Dakota Dash,Moved Fuel Tank,Frame Off
71 GMC 1500 Sierra Grande 350/700R4 3.42 rear, Repainted with my own hands and it looks Freaking Sweet.... http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 Suburban Former military GSA truck,,still solid as a rock! Its starting,,,350/700R4 3.42 rear, Dodge seats.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber...Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one.....Gen 5 5.3/8L90E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
71meangreenc10 is offline
Old 05-21-2005, 09:37 PM   #4
neonlarry
neonlarry's Avatar
^ no, use the light in place of the resistor.
Old 05-21-2005, 11:15 PM   #5
mocwon
Keep On Truckin'
mocwon's Avatar
THANKS!!! That's exactly what I needed know.
Just Passin' Thru
mocwon is offline
Old 05-22-2005, 10:51 AM   #6
dmec
dmec's Avatar
what about if you are using a voltmeter, would that act as the resistor?
dmec is offline
Old 05-22-2005, 11:20 AM   #7
neonlarry
neonlarry's Avatar
^No.
Old 05-22-2005, 06:34 PM   #8
mocwon
Keep On Truckin'
mocwon's Avatar
I found a pigtail with the correct resistance in the wire that AC Delco makes for this; part # 8078 and cost $21.88 from Advance Auto parts.
Just Passin' Thru
mocwon is offline
Old 05-22-2005, 10:11 PM   #9
neonlarry
neonlarry's Avatar
Thats good to know, a lot of people have had trouble finding a resistor that will work.
Old 05-23-2005, 11:04 AM   #10
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Bought mine from partsamerica. http://www.partsamerica.com/ProductD...artnumber=8078
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline
Old 05-23-2005, 03:18 PM   #11
Nima
Blue 67
When I switch to internal regulator alt few months ago, I bought 75 ohm 3 watt resistor from a local electronic shop; 50 cents each, Still working well. I just coverd the resistor in some kind of sheild to protect it from heat and possible trauma. I bought 3 of those. if you like I can look for them. I don't promiss to find them though since my place is a mess right now.
Nima is offline
Old 05-23-2005, 08:00 PM   #12
chickenwing
You could definately make a nicer harness than that jumper I listed. This was an easy way to go though. Just plug it in.
Old 10-30-2005, 12:02 PM   #13
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: CS130 Alternator wiring question
Here is the cs130 conversion that I found on the board
http://www.chevelles.com/techref/tecref14.html
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline
Closed Thread
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
