Old 08-11-2005, 11:13 PM   #1
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
here's what i have been up to
i started 4wd to 2wd swap and vice versa
day 1 disassembly
day 2 was spent pulling the front axles out of both trucks and cleaning the frame rails
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 08-11-2005, 11:23 PM   #2
sixty8c10
sixty8c10's Avatar
day 3 finished cleaning the frame rails and made templates for them
used the template to mark holes then test fit
test fit is perfect all measurements are within 1/32 of an inch. tomorrow i will raise the frame back up and drill the holes clean the crossmember and bolt it in (before anybody asks about the milk crates they are only there to prevent the crossmember from rolling over they are not supporting any weight)
Old 08-12-2005, 01:40 AM   #3
1974gmc
In Progress
1974gmc's Avatar
looks good, hope to see the rest of the swap as you get through it
1993 Chevrolet K2500 454 4L80E
1974 GMC 1/2t 2wd Stepside 305 auto *sold*
1985 Ford Mustang GT 5.0 5spd
1974gmc is offline   Reply With Quote
Old 08-12-2005, 02:02 PM   #4
sixty8c10
sixty8c10's Avatar
thats my plan
Old 08-12-2005, 10:25 PM   #5
sixty8c10
sixty8c10's Avatar
day 4: i did not get a whole lot done today (had to work late). by the time i got home i only had about an hour of daylight left so i drilled a few holes and test fit a few of the brackets. hopefully i won't have to work so late this weekend.
Old 08-13-2005, 12:11 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Ok maybe you posted this and I missed it, but what are you going to end up with? Is the truck going to be 4wd and the Blazer a 2wd? Is there a reason for all this work? I know there must be a method to your madness so bring us up to date on what your doing....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-13-2005, 01:46 AM   #7
sixty8c10
sixty8c10's Avatar
yes, the truck will be 4wd and the blazer a 2wd, the truck is pretty rough and will make a nice toy....the blazer is pretty decent and will make a nice daily driver. i really wanted a 2wd blazer and i could not find one this nice for the price (i got both of these trucks for less than half of what the blazer booked out at). the blazer will soon take over daily driver duty so i can finally get my 68' to the body shop. and the truck, i have already someone interested in taking it off my hands when i get it rolling.
did i leave anything out.
Old 08-13-2005, 01:50 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by sixty8c10
yes, the truck will be 4wd and the blazer a 2wd.....
Nope, I think that covers it. I assumed it was something like that but I wasn't sure. Keep the progress reports and pics coming....
Old 08-13-2005, 02:33 AM   #9
1FaastC10
1FaastC10's Avatar
are you going to swap the rear spring hangers on both trucks? if im not mistaken, they are different between 2wd and 4wd.
1FaastC10 is offline   Reply With Quote
Old 08-13-2005, 03:56 PM   #10
sixty8c10
sixty8c10's Avatar
yes, but i want to complete the front ends first
Old 08-14-2005, 11:57 AM   #11
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
why swap hangars? why not just swap rearends? and leave leafs intact? im assuming you are swapping to get like bolt patterns all the way around?
milehightoyz is offline   Reply With Quote
Old 08-14-2005, 04:17 PM   #12
sixty8c10
sixty8c10's Avatar
the 4wd rear hangers are longer than the 2wd
Old 08-14-2005, 04:18 PM   #13
sixty8c10
sixty8c10's Avatar
day 5: did not touch the trucks....had to help a buddy move
Old 08-14-2005, 09:55 PM   #14
sixty8c10
sixty8c10's Avatar
day 6: got home from work about 4:30 today got changed went out,took some measurements drilled a few more holes, test fit the 4wd eng mount brackets in the pick-up, then the sky opened up and it started pouring. needless to say i didn't get to much further along today
Old 08-16-2005, 08:44 AM   #15
sixty8c10
sixty8c10's Avatar
day 7: is it ever going to stop raining...it started raining about 30min after i got home from work....so i got nothing done once again
Old 08-18-2005, 11:40 PM   #16
sixty8c10
sixty8c10's Avatar
day 8: @#$%^& rain
day 9: got called into work and was stuck there all night
day 10: made some big progress today......finished drilling most of the holes in the pick-up's frame.......mounted everthing except the 4wd front x-member....gotta little tweaking to do to get the axle in there....will get fresh pics in the morning...worked on it til dark
Old 08-19-2005, 04:22 PM   #17
'78 Fleetside
Young'n
'78 Fleetside's Avatar
Lightened them up a bit, if you dont mind.
1978 Chevy C10 Fleet (For Sale!!)
www.rudezone.net/daniel
"It's ok for you to not like me, because i already dont like you!"
'78 Fleetside is offline   Reply With Quote
Old 08-19-2005, 06:08 PM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
I editededededed your edit....
Old 08-19-2005, 06:30 PM   #19
sixty8c10
sixty8c10's Avatar
thanks for brightening up those pics
heres the pics for day 10 i waited til this morning to take them
as you can see i still got to mount shocks, steering box, brake lines, and swap out front crossmembers so i can mount the sway bar.
Old 08-19-2005, 06:38 PM   #20
sixty8c10
sixty8c10's Avatar
day 11: finally got the front end mounted in the blazer
i still gotta do the shocks, steering, brake lines, swap the front crossmember so the 4wd can have its sway bar, and mount the 2wd sway bar.
but they both look alot different
Old 08-19-2005, 06:45 PM   #21
sixty8c10
sixty8c10's Avatar
wait for it to cool off a bit then i will get back to work.
Old 08-20-2005, 12:40 AM   #22
SmittySmith
'82 GMC Sierra Classic
SmittySmith's Avatar
Lots of work... I admire your spunk!!
SmittySmith is offline   Reply With Quote
Old 08-24-2005, 09:31 PM   #23
sixty8c10
sixty8c10's Avatar
sorry about not having a report in awhile. been working alot. anyway got a couple of days off this week maybe i can get something done. today - i got everything mounted on the blazer except for the brake lines. try to get pics tomorrow. tomorrow i plan to get the front end complete on the pick-up. then its on to the rear swap.
Old 08-25-2005, 10:41 PM   #24
sixty8c10
sixty8c10's Avatar
here yesterdays progress, with todays completeing the brake lines on the blazer
and i got the front end completed on the pickup as well, i still gotta secure the tank vent line.
Old 08-25-2005, 10:45 PM   #25
sixty8c10
sixty8c10's Avatar
sat morning when i get off work it will be time to start to the rear end swap
