WTB Choke Thermostat for 69 Rochester 2GV on 307 V8
All righty then. I have hit up all the parts stores, resto places, etc. No one has this thing, it has passed into obsolecense.
I need the choke thermostat (bimetallic coil), choke stove (cover), and the linkage if you have it. This is the divorced (mounts on intake manifold) choke for the Rochester 2GV carburetor on my '69 with 307 V8. Attached is a pic of where it goes. You can see the screw holes and one screw left in there: ![]()
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Click HERE for Blazer pics. Click HERE for Nissan Frontier stuff. |
Re: WTB Choke Thermostat for 69 Rochester 2GV on 307 V8
I have bought the coils from LMC and NAPA. I have bought the choke covers from other vendors. I have made the rod from coat hangers. When you go to NAPA you have to use part numbers from their 1971 parts book. They have none older unless you ar lucky enough to find one that has kept the old books. If all else fials, try calling the NAPA store in Randolph, Vermont or the one in Lebanon, Newhampshire.
Good luck.
Bob 68 C20 Camper Special |
I bought one from NAPA about 8 years ago. If you don't have any luck with them, I'll see if I still have the receipt and part number.
Here is what you need:
http://www.napaonline.com/cgi-bin/nc...grpid=53292269
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#5 | |
The NAPA CRB2293 crosses with: Wells E603 (obsolete) Standard CV11 (obsolete) Borg Warner TH11 (obsolete) No one can get these things. Even LMC's listing only shows 71-72. To me it appears that the base is different on the one I need as compared to the only one I have found online (it has only one mounting hole, my manifold has two that flank the coil spring). I will probably end up building some sort of adapter plate to mount a different one, or if I can buy some sort of electric choke that will divorce mount I might do that. I had wanted to take it back to stock but it looks like that might be impossible. Doesn't anyone still run this carburetor?
![]() Join Date: Aug 2003
I have 1 but did not run the engine.
Electric chokes:
http://www.carbsonly.com/carbs/carbschoke1.htm
![]() Join Date: Dec 1999
Check with a speedshop Edelbrock makes them, they purchased all the molds and rights from GM for the Qjets. The divorced choke and cover are sold separately. I am sure the online places like Jegs carry them as well.
Richard 1972 K10 Custom Deluxe SWB Fleetside |
I forgot I have one on a running engine if you interested.
Broke
![]() Join Date: Jun 2005
Did they ever use a divorced choke on a straight six? I have a hand choke on
mine and I hate it. I would like to put a divorced choke on if possible. |
#11 | ||
I went ahead and ordered the newer style for 71-72 as well, will probably have to adapt it. I will update when I get it. Quote:
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Click HERE for Blazer pics. Click HERE for Nissan Frontier stuff. Last edited by 69TowRig; 11-12-2005 at 12:52 PM. |
I have one here if you can use it...$20 shipped for the whole carb.
#13 |
![]() Join Date: Dec 2002
Go to some of the Camaro restoration sites. When I couldn't find one for my 70 Blazer I got one From Rick's First Generation Camaro in Atlanta. Eventhough if its not to pricey go with an electric conversion. Have had one on my 71 Blazer that I paid 15 bucks for from JC Whitneys. Been on there for 10 yrs never a problem, I know they cost alot more now
Thread Tools | |
Display Modes | |
