Old 12-09-2005, 03:20 PM   #1
Crazy-J
Crazy-J's Avatar
Question Motor stuttering going up hill, not getting enough fuel?
Hi,
I am having some trouble with my motor when going up hill. It just starts running flat and doesn't give me the power I get on flat roads. You can actually hear and feel it go from full power to a like stuttering state where it seems to come in and out of power.
Giving it more throttle doesn't help at all. It will downshift but still has the same problem. I've found that giving it about 50% throttle helps keep it from screwing up as much but it still has the problem. It's never bad enough to keep from getting up whatever incline I am on but I do slow down a lot.
Flat surfaces and downhills give me all the power I need and running around town it never has a problem. But come to any incline and it starts giving out.
All I can guess is that it's not getting enough fuel. My '72 shortbed has a stock fuel pump on an early 80's Chevy 1500 5.7L 350. It's running a mild cam, headers, 600 CFM Edelbrock carb, and an Edelbrock RPM manifold. I am also running a Summit fuel cell in back under the bed which also leads me to believe it might be the fuel problem given that going up hill that fuell would be shifting all to the back. Do I need a higher performance fuel pump or could it be something else?
I was told that it could also be the floats on my carb are not set correctly so I am going to check that this weekend, however this motor was built by the previous owner and I think he just popped the carb on and didn't mess with it. Otherwise I am lost.
Thanks for any and all help!
1972 Chevrolet C10
1969 Camaro
Now filled with GOLDOLINE!
Crazy-J is offline   Reply With Quote
Old 12-09-2005, 04:31 PM   #2
cdowns
cdowns's Avatar
Re: Motor stuttering going up hill, not getting enough fuel?
first thing i'd check would be the fuel filter//then i check into the wiring for the distributor if it's an HEI and wired with the original resistor circuit it's possible the module is frying itself due to low voltage//also check for vacumme leaks // also if using rubber fuel hose(BAD) it could be kinking or collapsing //you could also pop off your gascap and see if that solves the problem(bad vent) // check condition of plugs also and see how they look and clean/replace and regap them and while your at it set the timing
Old 12-09-2005, 05:14 PM   #3
John Fabris
TOTY 2006
John Fabris's Avatar
Change your spark plug wires.
How does it run in neutral? Are you able to rev it up and it sounds good? If so, then put it in gear, foot on the brake and give it gas. If it starts to run bad, it more then likely is the plug wires are bad, and allowing the spark to jump from the wires. When it is dark outside (nighttime) open the hood with the engine running, and see if you see sparks jumping from the wires...
What is happing is that under normal conditions, the spark is getting to the plugs, but under load (going uphill), it takes more voltage to fire the sparkplug, and due to path of least resistance, the spark is jumping out from the wires.
New plug wires should cure this...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 12-09-2005, 06:04 PM   #4
724wdcopper
graphic designer
724wdcopper's Avatar
fuel filter. i did this 3 years ago, swapped 3 carbs, new plugs and wires, 3 fuel Electric pumps. when i pulled off the $50 fuel filter and put a stock one in the quadrajet, runs fine. cheapest and most likely the culprit is the fuel filter.
724wdcopper is offline   Reply With Quote
Old 12-09-2005, 06:56 PM   #5
ratrod67
ratrod67's Avatar
Is your advance on your distributor working?
ratrod67 is offline   Reply With Quote
Old 12-09-2005, 11:41 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Fuel filter would show up at high end more likely.
Do the wires, get a cap and rotor and plugs too sine you'r in there.
Old 12-10-2005, 02:00 AM   #7
Crazy-J
Crazy-J's Avatar
Thanks all, that gives me a lot more to work with. I will check all of that this weekend. It is running an HEI distributor. I replaced the plugs last weekend and while it helped it run better in general, it didn't solve this particular problem.
1972 Chevrolet C10
1969 Camaro
Old 12-10-2005, 11:05 AM   #8
Russell
Professional Grade
Russell's Avatar
Sounds like timing to me! Does it ever backfire when it is stuttering like that?
Doesn't have to be your plugs, wires, cap or rotor either, if one of the weights is stuck, or if the vac advance is frozen, you'll get that kind of an issue. A carb running out of fuel will stumble, or sometimes die, but timing won't be noticed till you put a heavy load on the engine
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-10-2005, 11:05 AM   #9
jhwkns
Registered Cruiser
jhwkns's Avatar
Check your fuel pump pressure too..
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 12-10-2005, 11:13 AM   #10
truckdude239
truckdude239's Avatar
sounds like an fuel problem i have an f-150 that when i'd go up hill i'd lose power and the motor would stall out changed me fuel filter and the problem went away changing the filter is the cheapest try fix to do frist just my $.02
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 101kmiles
2002 Honda Accord 4 door With 275k(sisters car)
2003 Honda Accord 109k( brothers car)
2002 Sububran 5.3 225k
2000 Tahoe 5.3l 369k
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
