Old 04-20-2006, 11:35 PM   #1
oscareltemblo
"Hell Yeah I Drag"
oscareltemblo's Avatar
1968 C-10 lsx conversion
Hello I'm doing the famous lsx conversion and I started today,I just pulled out the 327 and th400 to put in the 6.0 and 4L80E that I bought at a junk yard nearby with all accesories and harness with the cpu for $3000.00 the motor and trans is from a 2005 express van. I'm keeping the fuel tank in place for now untill I get going cuase I'm going to buy a fuel tank from a member here that's from michigan he is Kas68c10. I'll post some pics later.
oscareltemblo is offline   Reply With Quote
Old 04-21-2006, 12:02 AM   #2
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Re: 1968 C-10 lsx conversion
That sounds like a great project!
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 04-21-2006, 12:05 AM   #3
oscareltemblo
"Hell Yeah I Drag"
Thanks Pual this site has been really helpfull it's a learning experience all the time I'm on here.
2004 Silverado SS Mods. Shortie headers, Radix 2.8 pulley, flowmaster 50 series, Built Transmission, K&N drop, E-fans in.. 60Ft 1.86 1/4 et 13.13 @ 102.46mph My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844
Old 04-21-2006, 07:16 AM   #4
68 short step
cool.thats gonna be neat.
68 short step is online now   Reply With Quote
Old 04-21-2006, 12:50 PM   #5
shifty
Finally out of debt
shifty's Avatar
have fun. i have links to two things in my signature - one is a thread i'm doing on my swap @ ls1tech, another has pictures of all of my truck mods in progress (or already done) including pictures of the swap. they might be of help.
DO YOU KNOW '80s-'90s KAWASAKI BIKES? HELP ME!!!
1968 C10 step - LS1/T56 swap in progress!
LS1 swap thread (@LS1tech): http://www.ls1tech.com/forums/showthread.php?t=370781 (please don't message me about it, thx!)
shifty is offline   Reply With Quote
Old 04-21-2006, 07:29 PM   #6
oscareltemblo
"Hell Yeah I Drag"
Yeah, thanks shifty I seen your links they rock Ive took a few Ideas from you and put them to my use.
Old 04-22-2006, 01:15 AM   #7
oscareltemblo
"Hell Yeah I Drag"
I have a small problem well many but, this one. The engine I brought has the power steering pump but no resevoir can I make one or do I need the original.
Old 04-22-2006, 11:09 AM   #8
72armyswbtruck
72armyswbtruck's Avatar
Have fun with this swap
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-22-2006, 02:59 PM   #9
oscareltemblo
"Hell Yeah I Drag"
An other problem today as I'm preping the engine and cleaning it I decide to test it so try to turn the crank pully with my socket. So I turn it a little and then no budge I mean it wouldn't go past a 1/4 turn on either way does this mean the engine is bad?
Old 04-22-2006, 02:59 PM   #10
oscareltemblo
"Hell Yeah I Drag"
I still have 20 days warranty.
Old 04-22-2006, 03:05 PM   #11
Injected68LS1
Injected68LS1's Avatar
If you left the spark plugs in when you tried turning the engine over, the compression will prevent you from turning it over. Just take out the spark plugs, then turn it over. It never hurts to look down the cylinders as you turn it over for extra confidence.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 04-22-2006, 03:34 PM   #12
Chevrolet4x4s
Chevrolet4x4s's Avatar
Whats gonna happen with the 327?
Good luck with the swap
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 04-22-2006, 03:37 PM   #13
oscareltemblo
"Hell Yeah I Drag"
I sold the 327 and trans.
Old 04-22-2006, 03:52 PM   #14
yote1234
yote1234's Avatar
well? is it froze? hope not...
1972 hugger cheyenne 350
1968 camaro 327/210hp
1965 chevelle malibu 283
1968 honda minitrail z50a #377
yote1234 is online now   Reply With Quote
Old 04-22-2006, 04:30 PM   #15
68 short step
we wanna know ,and we sure hope not.
Old 04-22-2006, 08:54 PM   #16
oscareltemblo
"Hell Yeah I Drag"
It's not froze I can turn a little but after I hear air suction it stops like if there was a bump I tried it with extra pole for leverage and won't budge when the compression is high shouldn't it push back like a spring?
Old 04-22-2006, 08:55 PM   #17
oscareltemblo
"Hell Yeah I Drag"
Tommarrow I'll take the spark plugs off as a last resort if not it's going back to the Junk yard where I got it from.
Old 04-23-2006, 07:28 PM   #18
oscareltemblo
"Hell Yeah I Drag"
I took out all the plugs it's still the same wtf what can it be?
Old 04-23-2006, 07:40 PM   #19
gringoloco
PENDEJO BORRACHO
gringoloco's Avatar
Don't wanna rain on your parade, but it sounds to me like the motor may have hydro-locked at some point. When this happens, the connecting rods bend and you get interference problems between the rod/piston or rod/crank. I could be wrong.
You could also have dropped a valve. That could stop a piston on the upstroke. I say pull the valve covers and oil pan and look for anything abnormal.
Some motors just have tight spots where they are not as easy to roll over. try a little more leverage, just not so much that you break anything. The harmonic balancer bolt can take it. They are torqued to 450 ft/lbs or so.
-Chris
'70 Short-Wide (Patiently awaiting it's turn...)
'72 Blazer 2WD (Moved to Canada...)
'05 Yukon (The daily)
gringoloco is offline   Reply With Quote
Old 04-23-2006, 07:45 PM   #20
Injected68LS1
Stupid question; Is the transmission connected to your engine?
Old 04-23-2006, 08:07 PM   #21
oscareltemblo
"Hell Yeah I Drag"
no it's not
Old 04-23-2006, 08:26 PM   #22
Injected68LS1
I told you it was a stupid question! I was going to suggest taking it out of gear. haha.
I hope you get it figured out. I really can't think of anything that would prevent it from turning over on a good engine. There are many things that could possibly be wrong inside. Good luck!
Old 04-23-2006, 08:53 PM   #23
oscareltemblo
"Hell Yeah I Drag"
Thanks anyway tomarrow it goes back what a pain it's going to be .
Old 04-23-2006, 09:15 PM   #24
LUV2XCLR8
My Square Corvette
LUV2XCLR8's Avatar
Pic's ???
PROJECT: "YFTSB" 1972 BLAZER 2WD
TOW RIG: "GAS HOG" Y2K GMC 3500
LUV2XCLR8 is offline   Reply With Quote
Old 04-23-2006, 09:20 PM   #25
68 short step
dang!!!! i was affraid of that.
just cause, whats the oil look like?
Thread Tools
Display Modes
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
