05-13-2006, 05:54 PM | #1 |
Kill switch wire
Quick question, what wire is best to use with a kill switch? I have a positive and a negative to my coil, and a positive and negative to my electronic ignition. Not sure which wire to cut......
Thanks!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
05-13-2006, 05:58 PM | #2 | |
Re: Kill switch wire
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
05-13-2006, 07:42 PM | #3 |
Its a 3sp manual. I was thinking the coil would be the best thing to disable, and I can hide the wires real good. Just dont know which one to interupt. Coil positive, coil negative, ignition positive, or ignition negative. I dont want to break something, you know?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree Last edited by farside847; 05-13-2006 at 07:46 PM. |
05-13-2006, 08:19 PM | #4 |
It don't matter. it's all dc current. i put a momentary on push button in line with my starter. so you gotta hold the button while you turn the key. i figure it complicated enough to confuse any one who want's to rid me of my baby. I got a Blazer, that's got the top all summer, so i can't count on door locks. i'm also thinking about a coil power switch, hidden in the grill somewhere. i think i just like being sneeky, and creative.
Nate |
05-13-2006, 11:48 PM | #5 |
I have always hooked up to the tach lead of the coil. When I flip the switch it grounds it.
05-13-2006, 11:49 PM | #6 | |
Happy to be here
You want a kill switch to "kill" the system. That means that if someone tries to hot wire the ignition switch they get nothing. It won't turn over, so they keep trying until they get frustrated and give up...
05-14-2006, 02:18 AM | #7 |
Why cut a wire? Just add a crimp-on, loop terminal to the engine end of your kill switch wire and bolt it to whichever wire's loop or U-terminal you pull off the coil. Cover with shrink wrap or electrical tape to prevent grounding. Run a new wire to the coil.
Luv the neutral switch wire idea. Needed to know that. Thanks, JYJohn.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 05-14-2006 at 02:18 AM. |
05-14-2006, 02:34 AM | #8 |
Truck junkie
Hello...If you want the kill switch to cut the motor off put it in the positive coil wire. It comes from the ignition switch which is how the key shuts off the engine anyway HOWEVER....if it's for antitheft the guys who use the solenoid wire to the starter are right. if you don't have a neutral safety switch it's still a purple wire on the ignition switch on the sol terminal. this won't let the thief crank the engine at all. Some people have a tendency to keep cranking an engine if it will turn over even if it doesn't start which will kill the battery and overheat the battery cables and starter wires.
05-15-2006, 12:13 PM | #9 |
purple wire going to the starter is the safest and easiest.
In high risk areas I pull the plug off the dizzy just enough so it looks like it is plugged in but in isn't.. |
05-15-2006, 04:09 PM | #10 | |
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
05-15-2006, 10:56 PM | #11 |
One thing you have to consider is when I hot wire my sons car all it takes is a jumper from the bat to dizzy and a screw driver and 10 seconds. Switches that interrupt electric "MIGHT" slow the average guy down but really won't stop them, Unless you add hood locks to keep them out of the engine compartment to bypass the switches you put in. Multiple systems including electric and fuel cutoffs are the best solution.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
05-16-2006, 10:14 AM | #12 | |
05-09-2008, 06:23 AM | #13 |
I know this is an old post, but I was hoping someone could clarify about the coil wire kill switch. I understand putting it on the positive wire from the ignition to the coil, but how does grounding the negative wire that runs from the coil to the tach act as a kill switch? does someone have it connected that way? I have a toggle switch where I can switch the wire coming from the coil negative from the tach to a ground, but I dont understand why that would prevent the engine from starting. Anyone?
05-09-2008, 06:49 AM | #14 |
Chevy nut
Here is a crazy idea I did about 15 years ago... I dont ever use my high beams. I had a 79 1/2...3 on the tree...screwed up column. I wired the starter to the dimmer switch on the floor to start it. Put the key in trun it to on and mash your foot down on the dimmer switch and when it starts mash your foot down to disengage the starter. Worked good. Someone tried to stel my truck 2 months after I did that...they peeled my column and found out they couldnt get it started.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
05-09-2008, 07:24 AM | #15 |
Msgt USAF Ret
Grounding the negative wire would prevent any build-up of current in the primary coil windings which when the points opened would normally break the circuit and allow the secondary windings in the coil to discharge and cause a spark to the plugs.
The problem with this setup is, if the key is left on it will energize the primary winding in the coil and could either burn up the coil or discharge the battery. Same with HEI but it's the module not points. the trouble is that not just one thing is going to keep thieves from stealing your truck. Suppose he has a buddy and they just ease it into neutral and push it down the street to another vehicle and tow it away. Then they can strip it later. No noise and no one sees anything.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-09-2008, 04:46 PM | #16 |
Thanks guys. So Vette, so as far as connecting the switch to a wire from the coil, the positive is the better choice then, because it will prevent power from getting TO the coil, right?
05-09-2008, 06:02 PM | #17 |
Msgt USAF Ret
In my opinion that is the first place a thief would go to put a jumper from the battery so grounding the negative side would be the best except for the reason I stated in my above post. I am in agreement with the other guys that say disable the battery or the starter so it won't crank at all. I've been toying with the idea of putting a relay such as a headlight relay in the main fusebox feed going into the firewall. A switch would disable all power going to the secondary electrical system. It wouldn't be enough though because the thief would still be able to jump the battery to the coil and then jump the starter and get the engine running. I think it would prevent the joy riders and amateurs from stealing the truck but it's not foolproof.
05-11-2008, 07:04 PM | #18 |
Knuckle head
I put a switch attached to the neutral safety switch wire. I like it and I think most crooks/joyriders wouldn't find. Heck I have issues sometimes.
I really like the idea of using a momuntary button switch. When I was deployed last year we had a Toyota Hi-Lux pickup that had an inconspicous metal tab just forward of the ignition. If a finger, from the hand you were turning the ignition with, wasn't touching the metal tab when you were turning the switch, the truck wouldn't start. It would turn over and thats it. Talk about a pain in the a$$ when it was your day to drive and no one had shown you how to start it. Last edited by AJohn6; 05-11-2008 at 07:05 PM. |
05-12-2008, 08:22 AM | #19 |
Rice Killing 101
i found out. if u have ac (just saying) in 68 there is a fatty brown wire that went to the interior ac box and the switch on that is a natural cut off i was quite suprised with my friend saying hey wat does this do goin down the freeway then the motor goin putt putt shhhh i was in utter amazement
distrubin the peace since i got the thing and broke the origianl radio on 95.5 classic rock Ride: 1968 c20 lwb 327(orig motor)/np435/eaton 4.10 w/posi puttin in a 496 rebuilding trans need to rebuild diff :| need to start takin pics and start a project thread |
Thread Tools | |
Display Modes | |
