Old 05-21-2006, 01:54 PM   #1
Rokcrln
Rokcrln's Avatar
Project Lemon Drop: anything but stock!
Here are a few pic's of an up and comming project. It is a 68 step side 2wd build I will be starting on in a few weeks for afellow board member. Alot of cab work was started by another shop and now it is getting to be time to finish it all up.
What has been started:
Shaved front drip rail.
Shaved and reformed side drips.
Welded rear roof line.
Floor and rocker repair.
Replaced a small section of the inner windshield area.
Total paint strip and primmed.
Started to set door gaps.
Rebuilt door hinges.
What I will be doing/re-doing:
Finish or fix everything listed above.
Create 3/16" door gaps everywhere.
Get the body ready for finish (pull and metal work all dings and dents)
Do a full "show car" fire wall shave and reforming.
And a whole lot more. I will let the owner fill you in on the rest of this plans if he want to let tings out of the bag!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 05-21-2006, 01:55 PM   #2
Rokcrln
Rokcrln's Avatar
Re: Project Lemon Drop: anything but stock!
And the last for a few weeks!
Kevin
LFD Inc.
Old 05-21-2006, 06:09 PM   #3
72CSTC5
72CSTC5's Avatar
You are going to have to quit your day job pretty soon.
72CSTC5 is offline   Reply With Quote
Old 05-21-2006, 08:00 PM   #4
cornutz
All Praise RANDY!!
cornutz's Avatar
I agree! Where do you find the time in the day??? Sleep must not be an option for you at all!
cornutz is offline   Reply With Quote
Old 05-22-2006, 04:34 PM   #5
jugernot
Life, Be In It.....
jugernot's Avatar
As Kevin stated he will soon work his magic on my cab. I would love to tell you all what is in store, but I think that pictures tell the story better. So you will have to wait for the play by play as Kevin does his work. In addition to the modification Kevin mention, we plan a few suttle mods. As for the project name Lemon Drop. The frame has a four/six DROP, and I plan on painting the body YELLOW. I am thinking of personalized plates "URN DROP" 18's in the front and 20's in the rear. I hope to have the truck in paint by the end of summer.
Stay tuned for progress updates from me or Kevin.
Thanks again Kevin.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 05-22-2006, 05:18 PM   #6
Rokcrln
Rokcrln's Avatar
He don't know me that well does hehehe!! Good thing he did not specify 2006 or 2007!!
Kevin
LFD Inc.
Old 05-22-2006, 05:31 PM   #7
ChevyDude
Awesome dude!!! keep the pics coming!!! Question for you...when putting it back together does the cowl go on prior to the fenders? My painter flaked on me and I just don't see how to get the cowl on with fenders all bolted up???
Alex
ChevyDude is offline   Reply With Quote
Old 05-22-2006, 06:04 PM   #8
Rokcrln
Rokcrln's Avatar
No the fender go on first then the cowl then hood. But before you tighten down your fender make sure all your gaps are set how you want them because once your cowl is on you can not get to the bolts to change things.
Heres a tip for ya! Go the the local paint store and get a roll of 2" blue or green masking tape and put over all your edges(door, fender, hood) where two parts might touch while adjusting things. This will give you a little protection against chips. Do not use the regular masking tape as it has too much glue and can pull soft paint and it leaves a residue behind as well. The best to use in my opinion is the green but it is more money then the blue.
Kevin
LFD Inc.
Old 05-22-2006, 06:08 PM   #9
cstanley
cstanley's Avatar
that one's gonna be nice. what's the difficulty level/involvement for shaving the drip rails? i know it was previously done, but still...
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 05-22-2006, 08:52 PM   #10
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Not to steal the thread, but Kevin - Is welding the upper rear seam the best way to clean that up? I would like to do that too, and was wondering what the best way is?
jugernot - From what I've seen so far on this board, your cab is in the BEST hands possible for sheet metal work!!!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 05-22-2006, 11:43 PM   #11
Rokcrln
Rokcrln's Avatar
If you want the rear seam "shaved" then yes it does need welding and then in my opinion then the best way to finish it from their is to use lead as a filler for anything beyond fill-primer. This part of the cab can get some vibration so I do not feel bondo is a long lasting product for this area. My self I fell the rear seam looks great when you have it stripped to bare metal and use just enough primer and paint as needed leaving a real nice crisp line. The problem I have with welding up this seam is the body does not flow real well at that point. In order to make it flow (to my liking) you would need to cut the roof cack about 3" on each side of the seam and roll out a new filler piece that creats a smooth flow. But this option is big $ because you also need to remove the headliner so you can work both sides of the metal.
Kevin
LFD Inc
Old 07-23-2006, 10:41 PM   #12
Rokcrln
Rokcrln's Avatar
It's time to get started on this beast! It is now in the good side of the shop (where stuff gets done) and I will get started on it this week Sorry for the weight but I had more work in front of me than I thought! All those jobs are done for now and it will just be this project untill it is finished.
Here are a few shots from today (7hrs in 110* heat with out air) in order to get this side of the shop ready!
Kevin
LFD Inc.
Old 07-23-2006, 11:54 PM   #13
jugernot
Life, Be In It.....
jugernot's Avatar
Thats weird that you type a response today. Earlier I re-visited this link to refresh my memory of what it said.
Thanks for the update. If there is anything I can do to help let me know.
Old 07-24-2006, 10:03 AM   #14
78Bronco
New Member
Wow, pictures of a Bronco on this forum...... is that legal?
71 Cheyenne, SWB, K10
78Bronco is offline   Reply With Quote
Old 07-25-2006, 03:54 PM   #15
Rokcrln
Rokcrln's Avatar
SHhhhhhhhhhhh! We don't talk about these things! Youy know he is their and he is quite different than the rest of the kids but you don't point him out, you just don't!!!!!!!!!
Kevin
LFD Inc.
Old 07-29-2006, 02:05 AM   #16
Rokcrln
Rokcrln's Avatar
Project starts first thing Saturday morning with a full fire wall shave and rework. Pic's to come!
Kevin
LFD Inc.
Old 07-29-2006, 10:07 AM   #17
72CSTC5
72CSTC5's Avatar
Sneaky, I saw how you slipped those orphan kid shots in there. That was brilliant. I thought wow, the owner of lemon drop changed dircetions and was going with a yellow Bronco. You forgot to stretch the quarter to fit the 24" wheels in the back when you bag and bodydrop that thing. Nice work Kevin.
Old 07-29-2006, 10:13 AM   #18
Rokcrln
Rokcrln's Avatar
How did you know it was going 2wd? No body drop but it should be getting a 4.6 Cobra set up with IFS and maybe IRS as well then 18's or 20's!
Kevin
LFD Inc.
Old 07-29-2006, 08:38 PM   #19
Rokcrln
Rokcrln's Avatar
This is stage one of the fire wall. Stage two will be first part of the week.
Kevin
LFD Inc.
Old 07-29-2006, 09:17 PM   #20
jugernot
Life, Be In It.....
jugernot's Avatar
Wink Re: Project Lemon Drop: anything but stock!
Keving Its looking great. Glad I could help with the up coming THING as well. I am looking forward to seeing both of them complete. I am off from work next Sunday, if you need any help let me know. I would be great to see the MASTER at work. You don't charge anything to watch do you??????
I just got a bunch of parts back from powder coating. Here are some pics of some of the parts.
Old 07-29-2006, 10:00 PM   #21
Rokcrln
Rokcrln's Avatar
Parts look great, I like the powder chrome my self. And yes I do charge to watch, ?? per hour And that up comming THING is on the down low if you know what I mean
Kevin
LFD Inc.
Old 08-01-2006, 10:05 PM   #22
Rokcrln
Rokcrln's Avatar
I got some time tonight for the fire wall part 2. The pass side now matches the drivers side for a much better look. I will get two the wire rail in the next day or so.
Kevin
LFD Inc.
Old 08-01-2006, 11:11 PM   #23
Hart_Rod
Hart_Rod's Avatar
Do you have a side picture Kevin?
R
Hart_Rod is offline   Reply With Quote
Old 08-03-2006, 08:36 PM   #24
Rokcrln
Rokcrln's Avatar
R
Not yet as I did not want to complete the top untill I re-shoot the Epoxy anywhere that will be covered. Should get to finish it up this weekend. I got all the epoxy/filler primer today as well as 10lbs of .035 tig rod for more body welding. I have been using my mig wire while I was waiting for the new rod to come in. That stuff sure does not like to go strait
Kevin
LFD Inc.
Old 08-04-2006, 08:09 PM   #25
Rokcrln
Rokcrln's Avatar
All primed and ready for the top wire rail to get filled in the morning!
Kevin
LFD Inc.
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
