Old 05-25-2006, 11:21 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
How to beef up rear suspension???
I want to set up my 71' 2wd short bed with coil springs to pull me car trailer. Whats the best way to beef it up a little without ruining the ride???
1971ChevyTruck is offline   Reply With Quote
Old 05-26-2006, 08:06 AM   #2
Re: How to beef up rear suspension???
Air Lift air bags inside your coils.You add air to haul up to 1,500# more.Air down to ride stock.
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi...'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72'
"Don't call me a rough cut country gentleman. I'm just a redneck"
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
Old 05-26-2006, 08:18 AM   #3
fade94
fade94's Avatar
I have seen "helper" leaf setups on coil rears.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 05-26-2006, 08:18 AM   #4
fade94
fade94's Avatar
PM sent
Old 05-26-2006, 09:21 AM   #5
Gray Ghost
Gray Ghost's Avatar
The helper springs [leaf] to fit the coils are expenxive....$350+ to get the parts and mounting plates. I'd go with air bags if it were me. Course you could just order 3/4 ton springs.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 05-26-2006, 09:50 AM   #6
fade94
fade94's Avatar
I didnt' realize they were that expensive. I took a set off of a short step with a bent frame. Glad I kept them now.
Old 05-26-2006, 10:33 AM   #7
1-PU70
1-PU70's Avatar
went with overload shocks, shocks with coils over them. Didnt help much with extra weight but the truck handles much better around turns. If I were to do it again there is a kit that mounts air bags behind the original coils, not inside. Cant remember where I saw them but that are like to ones that mount coil overs
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 05-26-2006, 08:26 PM   #8
CG
BlahBlahBlah
make sure you have trailer brakes. i was told this was pretty much a must when you tow with a short wheelbase. but now that ive posted this im sure there will be people that say that isnt true...
Old 05-26-2006, 08:49 PM   #9
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Another option would be a weight and distribution hitch with an anti sway bar. You would have to have a reciever hitch to use it. The weight and distribution hitch costs $300-$350 and the anti sway bar runs about $100. With one installed you can haul up to 10,000 lbs and run as fast as you want down the highway. You can buy them online or from any U-Haul or RV dealer. You'll also want your electric brakes hooked up too.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 05-26-2006, 09:00 PM   #10
The Air-Lift bags are around $100,they give a 1/2t the load capacity of a 3/4t,or stock 1/2t ride when not hauling.I`d want trailer brakes for towing over 1,000#.
Old 05-26-2006, 09:50 PM   #11
1971ChevyTruck
I have a brand new trailer with dual brakes and break away brakes....I also have the weight dist hitch and two sway bars...I was just told these truck with the coil springs still sag bad in the back....anyone know where to get the air bag setup??? Thanks for all the help guys....
Old 05-27-2006, 07:11 AM   #12
Old Yeller 1970
DON'T TREAD ON ME
I think you can order Air Lift air bags from Autozone.
I used to set up weight and distribution hitches all the time. I know a few tricks that may help keep your truck from sagging. But first, how many inches does it sag?
Old Yeller
Old 05-27-2006, 08:49 PM   #13
Aarons72s
hay,
My orange and white has 3/4 ton HD springs in the rear even though it is a half ton truck. Ive had over a half a ton of metal in the back and 3/4 ton of metal in my brown pickup bed trailer and the truck all most sits level. Riding empty it has a good bit of rake. Ride is fair but it might be do to the old nasty shocks but I am used to riding in stiff trucks anyway.
Aarons72s is offline   Reply With Quote
Old 05-28-2006, 09:48 AM   #14
da-burb
"Ochre Ogre"
da-burb's Avatar
The factory overload spring would help out alot. It wouldn't affect your ride one bit when not trailering.
I just purchased a new 10,000# equalizer hitch for $199. It is a Putnam brand. I was lucky enough to work 1 mile away from this distributor so I didn't have to pay freight. www.onetouch2you.com should be their web address.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
