Old 06-09-2006, 02:42 AM   #1
220mph
Speed Limits...yeh right
220mph's Avatar
5-SPEED transmission swap in a '72 4x4
Hi, I am new to this forum and yet I can see that there is a lot of experience among the members.
Has anyone replaced a 4-speed Muncie with a Tremmic 5-speed w/overdrive, or with any other 5-speed? Any help is greatly appreciated!!!
220mph is offline   Reply With Quote
Old 06-09-2006, 06:57 AM   #2
NitroMike
Active Member
NitroMike's Avatar
Re: 5-SPEED transmission swap in a '72 4x4
I'm in the midst of replacing the column shifted three-speed in my '67 with a new Tremec five-speed. I'll let you know how it goes as I finish it up.
The older I get, the faster I was!!
NitroMike is offline   Reply With Quote
Old 06-09-2006, 06:58 AM   #3
Not the Tremmac.But,the NV4500 is a common swap.You need either the later NP205 with the round mating surface(front)or a right-hand drop-out NP241 like what was in the last of the Blazers/Jimmys/Suburbans with solid front axles(pre-92).I believe t-case adaptors are made for other cases,but I wouldn`t bother with any other than the two I mentioned.
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi...'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72'
"Don't call me a rough cut country gentleman. I'm just a redneck"
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
Old 06-09-2006, 04:12 PM   #4
220mph
220mph's Avatar
I spoke with the guys @ NV4500. This seems like a well thoughtout quality product.
Has anyone tried the NV4500 and are you happy with the results?
Thanks for taking the time to answer
Old 06-09-2006, 05:58 PM   #5
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
One thing I know about that trans is that you can't haul a trailer in 5th gear. It will wear out in 500 mi. Owners manuals for any vehicle with a nv4500 will say it voids the warranty.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 06-09-2006, 08:10 PM   #6
220mph
220mph's Avatar
Which 5-speed will handle towing?
1972 3/4 ton 4x4 LONG BED
1940 Chevy Pickup
1970 El Camino Pro Street 496BB w/NOS
Old 06-10-2006, 08:58 AM   #7
You shouldn`t tow in O/D with any light truck.
Old 06-10-2006, 06:59 PM   #8
1969 GMC
1969 GMC's Avatar
I am going to swap in a NP542GL transmission from a C60. It has 5 speeds, but 5th is direct. It is pretty much a bolt-in.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 06-10-2006, 07:31 PM   #9
Chevrolet4x4s
Chevrolet4x4s's Avatar
What about a 6 speed out of a latemodel F body into a 2wd?
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 06-24-2006, 07:32 AM   #10
44th Miss Inf
I swapped in a nv4500 in place of a sm465 4 spd in my 4x4. The 81 up 208c case is a direct bolt on.
1969 GMC, doesn't that trans have the bigger input shaft? Or was that just the earlier 2T 5 spds?
Virgil
44th Miss Inf is offline   Reply With Quote
Old 06-25-2006, 06:37 PM   #11
1969 GMC
1969 GMC's Avatar
Virgil
Mine has the BIG input shaft, well bigger than my SM465's anyway. But I got the tranny complete with clutch, pressure plate, flywheel, bellhousing, and part of the clutch linkage, so it bolts up to the crank just like the stock stuff did. It was originally behind a 427 tall deck which has neutral balance just like the SBC, so i am good as far as that goes. I am going to use a divorced NP201 from an old International behind this beast, which is huge itself. Not too worried about breakage
EDIT: see my sig? thats the new shift pattern...will take a little getting used to.
1969 GMC K2500
1996 Honda Accord
Old 07-12-2006, 10:07 AM   #12
Daubs
Daubs's Avatar
Hmmmm...my 04 8.1/Allison does just fine towing in O/D.
'72 Chevy K-20 Crate 350, SM465, 4.10's
'04 Chevy 2500HD CC 4x4 8.1L/496, Allison, 3.73's
Daubs is offline   Reply With Quote
Old 07-16-2006, 04:30 PM   #13
TP from Cntl PA
TP from Cntl PA's Avatar
Maybe with a snowmobile trailer................Try it with a Gooseneck full of steers.
Main problem with the NV, is unlike an Auto which knows when to downshift, the guy in the seat doesn't think that way and problems start. Most of the NV problems started because of an engine called a 5.9 Cummins. You have so much torque it is possible to pull hills in OD which a huge load, the engine has so much low end it wouldn't quit, and common sense tells you that a rinky dink pickup tranny in OD behind that engine which has a much larger transmission behind it in Commercial applications is gonna be the thing that will break.
Anyway, I don't think an NV would mind running in OD towing down the fairly flat 4 lane black top...........Its the instances I mentioned above where they flake out.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 07-17-2006, 07:45 AM   #14
I`ve gotten around 100,000 miles from NV4500s in two different`K3500s w/6.5TD.I ignored the "no tow in o/d" warning.The NV4500 is hardly a rinky dink trans for a light truck.They can take torque in the 500+ range w/no problems.Anything more than that,you`re on your own with any light truck tranny.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
