Old 06-14-2006, 12:32 PM   #1
makovai
makovai's Avatar
Superlift VS Skyjacker
Why is it for our rigs that softride superlifts cost bout $150 per spring and Softride Skyjacker cost bout $250 per spring?
I have brand new Superlift 6" front springs that cost me $310 to my door.
I bought a pair of Skyjackers softride 6" for the rear yesturday (new) off craigslist for $200 for the pair but they would have cost $500 to my door.
Are they that much better?
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 06-14-2006, 12:41 PM   #2
Jason915
Re: Superlift VS Skyjacker
Dang that is high, I only paid $185 per spring for my front and $165 per spring for the rear on my truck for 4" softride springs. Summit Racing sells Skyjacker and so 4Wheel parts can order them, where are you seeing them listed for $250 for each spring?
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 06-14-2006, 12:48 PM   #3
Jason915
Ok I just checked the prices out and now I know why that it seems high to me becasue it is for a 6" springs not 4". It seems to me that everyone else don't charge any different for 4" or 6" springs just Skyjacker. I also wonder why? I have no experience with Superlift. I can only compare my Skyjacker to Tuff Country, Warn, Ranco, and Rough Country.
Old 06-14-2006, 01:08 PM   #4
makovai
makovai's Avatar
with a quick search this is the best price i saw, now you have to ship 80+lbs on top of that...... BTW this is per spring
CR16S SINGLE SPRING 6'' REAR $226.95
www.fast77.com
1996 Z71 w/ 35's
Old 06-14-2006, 10:02 PM   #5
LUV2XCLR8
"Square Corvette"
LUV2XCLR8's Avatar
I think most of the Skyjacker price is in the name
The Toy: "Square Vette" 72 C5 Blazer
Toy Puller: "Burakkubyūtī" 12 Tundra
Toy Hauler: "Feathers" Aluma 8218T
Owner/Admin "TN Classic Truck Club"
LUV2XCLR8 is offline   Reply With Quote
Old 06-15-2006, 08:48 AM   #6
makovai
makovai's Avatar
Kinda like a warn and a milemiker winch right igor
www.fast77.com
1996 Z71 w/ 35's
Old 06-15-2006, 09:09 AM   #7
Jason915
I'd really like to see the quility difference.
Old 06-15-2006, 10:00 AM   #8
makovai
makovai's Avatar
Well i have brand new superlift 6" arched in the front and brand new skyjacker 6" arched in the rear. Both are softride. I cant see and diffence in quality.
www.fast77.com
1996 Z71 w/ 35's
Old 06-15-2006, 10:52 AM   #9
Jason915
Good to know, how about the ride any noticable difference?
Old 06-16-2006, 12:04 AM   #10
makovai
makovai's Avatar
well I kinda exagerated i have superlift installed in the front and the skyjacker are in the rear but they are still in the bed of the truck. Dont know if you read my last thread about my rear end trying to drive down my driveway. Anyway I'm waiting for a safer/flatter place to do the install.
www.fast77.com
1996 Z71 w/ 35's
Old 06-16-2006, 03:25 PM   #11
LUV2XCLR8
"Square Corvette"
LUV2XCLR8's Avatar
BTW, The ones on "GQ" ride really smooth and they are cheaper quality
Old 06-23-2006, 10:04 AM   #12
makovai
makovai's Avatar
I now have the skyjackers in and they do ride better. I doubt its $200 better but it is a softer ride. It's boucier but i good bounce not a stiff bounce. I also put RS9000 shock back there so it could be that those are the difference too.
Bad new is that now the rear sits higher than the front. I keep trying to get this truck level and keep adding more lift. by the time i get it level I'll be able to put 44's under it It looks level in this pic but on flat ground its about 3/4-1" higher in the rear.
www.fast77.com
1996 Z71 w/ 35's
Old 06-23-2006, 10:28 AM   #13
Jason915
You need a nice size toolbox with a heavy log chain, snatch block, hi lift jack, shovel tire chains extra u-joins, one extra hub, some extra oil, anti freeze and whatever else you can think of that you could need off road that you could put in the back.
Old 06-23-2006, 06:50 PM   #14
makovai
makovai's Avatar
I read what you wrote twice and i got it the second time. I'm a little slow.
Maybe I'll just get a "I'm offensive" sticker and load them in the back
www.fast77.com
1996 Z71 w/ 35's
Last edited by Liz; 06-23-2006 at 07:18 PM. Reason: :) or I could just set my fat ass in the back, rude comment deleted, thank you have a good evening
Old 06-24-2006, 12:26 AM   #15
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Put some ORD zero rates in the front to level it out. You definatly need some 38's now.
71 2wd Blazer. Its the super*****inest, megacoolinest, superflowinest. 350/350 Turbo. 600cfm Edelbrock 1406, Edelbrock RPM performer intake, big cam ?,Headers,Flowmasters.
2wdBlazer is offline   Reply With Quote
Old 06-24-2006, 10:38 AM   #16
makovai
makovai's Avatar
whats that?
Hope its not different springs. I just spent $310 on these new Superlifts.
www.fast77.com
1996 Z71 w/ 35's
Old 06-24-2006, 11:07 AM   #17
IGOR
IGOR's Avatar
No - zero rates are little thin blocks with offset hole & pin for the leaf spring pins.
You use them to shift your axle forward or backward along the leaf spring. Typically they are 1" to 2" thick.
Hey check your PMs - I sent you a phone # for a guy that does balljoints.
-Ben
1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 37" Krawlers, 8" lift, curently a pile of parts that when assembled resemble a Blazer
2002 GMC 2500HD - 4x4, Denali front end, WARN flares, 8.1/Allison, Leer 100XQ canopy, Nathan P3 train horn
2008 Scion XB
My blazer build thread:
http://coloradok5.com/forums/showthread.php?t=264786
IGOR is offline   Reply With Quote
Old 06-25-2006, 05:34 PM   #18
Jason915
I was just suggesting that you put about 300# of tools and off road equipment that would sit the back down a bit and the extra weight may even make it ride nicer, as well as better traction. My GMC sits real level and I like that except when I haul heavy stuff it sags in the rear prematurley (sp?)
Old 06-26-2006, 08:50 AM   #19
2wdBlazer
The Blazer King
2wdBlazer's Avatar
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
They can be run centered as well. No need to shift the axle if it doesn't need it. It's kinda like a block but it actually bolts to your spring pack so it is very safe.
No come to the dark side and slap on some 38's!!!
Old 06-26-2006, 10:02 AM   #20
makovai
makovai's Avatar
obi wan, the force is strong with you, but i'm going to the toyo 37x14.5. I dont like too much tire under the fender well.
www.fast77.com
1996 Z71 w/ 35's
Old 06-26-2006, 12:05 PM   #21
2wdBlazer
The Blazer King
2wdBlazer's Avatar
37x14.50 will be nice. Most 37's are skinny which is a big Yuk.
Old 06-26-2006, 12:44 PM   #22
makovai
makovai's Avatar
everyone i've talked to says these toyo are excenptional nice riding tires. They are the only one i can find thatcan get a little life out of them that have width.
I hate the swamper im running now.
I've never gotten more than 15K out of baja claws
and those are the other 2 choices that have any width.
www.fast77.com
1996 Z71 w/ 35's
Old 06-27-2006, 10:31 AM   #23
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I have been happy with my PJ's. I run a Borgeson U-joint in the sterring shaft that has a built in vibration dampner. Works awesome.
Old 06-27-2006, 08:53 PM   #24
makovai
makovai's Avatar
u got photo's of that setup?....im just curious to see it.
www.fast77.com
1996 Z71 w/ 35's
Old 06-27-2006, 09:49 PM   #25
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Yeah. see here http://67-72chevytrucks.com/vboard/s...light=borgeson
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
