Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Suspension, Steering and Brakes
Old 08-06-2002, 12:29 PM   #1
ebfabman
Replacing upper "A" arm bushings and balljiont
replacing ''A" arm bushings
remove A arm and remove balljoint remove old bushings & shaft
disassembled
screw in one bushing
screw shaft into bushing screw in 2nd bushing
next the balljoint
use the grade 8 bolts
install back on truck
tighten everything up & grease
Some tips. Screw in the first bushing all the way into the A arm. then after greasing the shaft, screw it all the way into the bushing, then unscrew it out one turn. Then screw the other bushing into the A arm. Snug them down good. I have seen the bushings tack welded to the A arm, just be sure to tack them so they can be removed later.
Final tightening/torque should be done when the suspension is aligned.
There may be other ways to do this, but this is how I've done it over the years. If anyone has anything to add please feel free.....eb
ebfabman is offline
