Old 07-31-2006, 06:58 AM   #26
70c10
67-72 Addict!
70c10's Avatar
Re: Rear Anti-Sway bar arrived Friday...
Alex- one last question. In one of the pics that shows the long bolt on the drivers side, it looks like the bar lays right up against the trailing arm. Is that the case or is it just the way the pic was taken?.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-31-2006, 10:22 AM   #27
ChevyDude
That's just the way the pic was taken. Plenlty of clearance everywhere with this install. This Mod was one that was quick and I realy feel good about. Really a good quality sway bar and heavy duty!
ChevyDude is offline   Reply With Quote
Old 08-02-2006, 02:03 PM   #28
Already Gone
60+ (Old Skool Club)
Already Gone's Avatar
I was under my truck yesterday when I was getting the trans serviced and looking where the rear sway bar would clamp. With the combo of your pics and seeing where the bar attaches ( the frame and trailing arms), this may be a dumb question but wouldn't attaching the sway bar to the farme and trailing arms restrict the the up and down movement of the trailing arms therefore making the ruck ride a lot harsher?
1972 C10 Custom/Deluxe 613 Highlander 350/TH350
Ethics is knowing the difference between what you have right to do and what is right to do !!.... Potter Stewart
RIP Glenn Frey 1948-2016
Old 08-02-2006, 02:48 PM   #29
ChevyDude
Well, I hope not! Lets hope the Helwig engineers knew what they where doing. The reviews I read about this bar were nothing but thumbs up, with no negitive remarks. Guess I'll have to see when I drive it. There's always Ebay if I don't care for it, but I seriously doubt that I won't like it...LOL!
Old 08-02-2006, 03:19 PM   #30
bryanw1968
bryanw1968's Avatar
I have a front and rear sway bar on my short bed step side '68.
Adding the front sway bar made a HUGE difference in handling. It made it much more fun and safer to drive.
Adding the rear sway bar also helped but was less noticeable. One thing to watch out for is how big of a sway bar you put where. If you have a rear wheel drive vehicle you want a bigger sway bar in the front and a smaller one in the rear to prevent understeer. It's the opposite for a front wheel drive setup.
All in all, a great mod. Best bang for the handling buck!
Great job on the install. Very clean truck.
bryanw1968 is offline   Reply With Quote
Old 08-02-2006, 03:33 PM   #31
Already Gone
Yes I would assume that the Hellwig engineers knew what they were doing when they designed the sway bar. I'm real anxious to see if you can see any notable difference with the rear bar attached. In saying that though it looks to me like you are assembling your truck and wont really know how the truck drove without the rear bar.
Old 08-02-2006, 03:54 PM   #32
ChevyDude
Already Gone...you are right....Only drove the truck once, and that was to the paint shop over 3 years ago. I will be able to tell you if I like the way the truck rides and feels, though. Shortly....with a little luck!
Old 08-02-2006, 04:19 PM   #33
boraxman
Keepin an eye out
boraxman's Avatar
Would the rear sway bar possibily eliminate the need for a panhard bar?
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 08-02-2006, 04:49 PM   #34
ChevyDude
No, panhard bar is to keep the differential from twisting. 4 link will eliminate panhard bar.
Old 08-02-2006, 07:05 PM   #35
bryanw1968
bryanw1968's Avatar
When I installed the rear sway bar I could hug the corners much tighter. However I do notice now that if I'm going around a corner hard and there's a bump in it that my rear end hops some instead of absorbing the bump.
All in all I like it though.
Old 08-02-2006, 07:19 PM   #36
ChevyDude
I am sure it will tighten up the suspension and travel...but I'm not looking for a Cadilac ride.
Old 08-03-2006, 12:25 AM   #37
smbrouss70
smbrouss70's Avatar
Actually, a 4-link (or the factory trailing arms) keeps the differential from twisting. The panhard bar keeps the rear end from moving side to side. And a "normal" 4-link still requires a panhard bar, a triangulated 4-link will eliminate it.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2012 Chevy Tahoe LT "Powdered Sugar"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
Shop Build
smbrouss70 is online now   Reply With Quote
Old 08-03-2006, 01:55 AM   #38
ChevyDude
Thanks for clearing that up...I am no expert for sure.
Old 08-03-2006, 10:28 PM   #39
centsless
sufficiently talented fool
centsless's Avatar
Very nice job on the sway bar. It really does look like it belongs there. Everything on your truck looks top notch!! I just got mine done, and looking at yours makes me think I need to re-do it!! Can't wait to see it all done
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 08-03-2006, 11:16 PM   #40
smbrouss70
smbrouss70's Avatar
no problem, Your truck sure is looking good. Make sure you post a thread with the finished pics of it!
Steven
R.I.P. Oscar
Shop Build
Old 08-06-2006, 09:18 PM   #41
ChevyDude
Thanks Guys...will do!!!
Old 08-05-2010, 06:02 PM   #42
ERASER5
ERASER5's Avatar
Back from the dead! I needed to look at your rear sway bar pictures. My sway bar is a little different, but the frame mounts are similar. I would have never guessed it mounted that way! So thanks for your posts so long ago.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-05-2010, 08:08 PM   #43
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I found somewhere about camaro rear sway bars, never heard of how a sway bar handled with these trucks, I know the front did loads of good though..
John
1999 Toyota Tacoma 4x4
Old 08-05-2010, 10:07 PM   #44
ERASER5
ERASER5's Avatar
Never heard? Well, the word is GOOD! Hellwig is a popular brand.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 08-05-2010, 11:35 PM   #45
GMCshorty
Looks great. I was thinking about putting a rear bar on mine as well but my truck has leafs. What do you leaf spring guys use for a rear bar?
GMCshorty is offline   Reply With Quote
Old 08-05-2010, 11:37 PM   #46
oldblue1968chevy
Is it as good of an upgrade as the front bar?
John
Old 08-06-2010, 02:36 AM   #47
ERASER5
ERASER5's Avatar
Front bar first. That will make world of difference. The rear will make a difference, but not as dramatic. I need to control 300 gallons of water sloshing back and forth. The rear sway will really help me there.
Hellwig 7402 is for leaves. It will stiffen up the ride.
I have use PST before with good luck, but that was on a car.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 08-06-2010, 03:20 AM   #48
rockvette
rockvette's Avatar
I have a 1964 1/2 ton short stepside with 1-1/4" in front and 1-1/8"in rear.This thing handles like a go-cart no leaning or swaying it is the best thingI could have done Got my kit from CCP
1972 corvette (454-4speed)
1960 corvette (283-2-4barrel-powerglide)
1966 corvette (427-4speed)
1964 chevrolet stepside (502-6speed)
2002 corvette (LS2-6speed)
http://photobucket.com/rogers-64
under albums click Ineeda
rockvette is offline   Reply With Quote
Old 08-06-2010, 06:49 AM   #49
LONGHAIR
LONGHAIR's Avatar
Come on ERASER5, don't you know that newbies are supposed to dig up the old threads? LOL
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-06-2010, 07:19 AM   #50
djmachinist
djmachinist's Avatar
ChevyDude,
Your truck build is awsome!! What Dia. rear bar did you use? I have the CPP 1 1/8in. dia rear bar with the 1 1/4 in. bar in the front. I have not installed the rear bar yet because I was afraid it would induce oversteer in a hard corner.
Just the front bar keeps it pretty flat in corners, not much body roll. Let us know how that rear bar works when you get it back on the road.
What I really want to here about is the Stereo set up you have behind the seat. I just installed a CPP rear alum. tank setup in my truck so I would have more room behind the seats. What is that black panel across the back of the cab made of? How is it attached? I see three shiny bolts at the top, is the cab doublewall where the bolts are located. I'm trying to figure out how to clean up the rear cab wall so I can install bucket seats and a console. I like what you did! Do tell all!!!
Thanks,
Dale
1969 GMC SWB FLEETSIDE
ZZ 383 CRATE MOTOR,700R4,& 3.73 POSI & VINTAGE AIR
DALE JONES
MY BUILD THREAD: "69 GMC SHORT FLEET"
http://67-72chevytrucks.com/vboard/s...d.php?t=388447
djmachinist is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
