Old 08-06-2006, 04:29 PM   #1
dennislbrooks
We can make that
dennislbrooks's Avatar
67-68 stainless Grill Mesh - been a while
Ok--- I am near done with my grill mesh. If I find a right angle drill small enough to drill about 6 more 1/8" holes I will add them. To make my mesh one piece, I also started my inside hood release project - I will be using an 88 hood release assembly from LMC - Part # 31-1450. You will see my temp opener pics. Also added piece for the future cable attachment --- I will probably add another clamp piece for the release cable once I get the 88 hood release and ponder it.
I used 1/8" hole mesh with .032 stainless wire size for my grill insert on my 67. Larger holes and thicker wire may look as good or better but a larger wire size will be more difficult to work with.
The mesh dimensions is 50.5" x 10.25" for complete coverage. I used my spare TX grill to trial fit the mesh. If you have your grill out -- put some spare 1/8" holes about every 4" in the back side for possible future use. A pair of good tin snips will cut the.032 mesh. A spring type clip works well for the bottom and side fasteners along with a strap clamp and existing rear support holes. I do not plan on putting the oem back support in - may change my mind and later modify the support. Will keep the mechanism lubricated.
I have enough material left for 3 more grills and I still need a good SM420.
More pics coming when I finish the inside hood release.
dennislbrooks is offline   Reply With Quote
Old 08-06-2006, 04:31 PM   #2
dennislbrooks
We can make that
Re: 67-68 stainless Grill Mesh - been a while
more pics
Old 08-06-2006, 04:32 PM   #3
dennislbrooks
We can make that
temporary opener ------ last pic for now
Old 08-10-2006, 09:34 PM   #4
dennislbrooks
We can make that
Final pics
Old 08-10-2006, 09:36 PM   #5
dennislbrooks
We can make that
the rest of the final pics
Old 08-10-2006, 10:24 PM   #6
incoma
incoma's Avatar
nice job. I love the mesh in front. I'd like to do that as well. Looks like a pretty clean install.
"Green Monster" (Red Sox fan)
1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension
incoma is offline   Reply With Quote
Old 08-10-2006, 11:13 PM   #7
wibilly
wibilly's Avatar
that should keep the birds out of the radiator lol looks real good. i like the remote hood upgrade too
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 08-11-2006, 08:10 AM   #8
dennislbrooks
We can make that
I dunno -- the orange rope looked very southern Ohio. I am placing a 3/32" metal rope loop under the latch also in case the hood release should fail for some reason. I would stick a bent coat hanger thru the bottom rope hole to catch the loop if necessary.
Old 08-11-2006, 11:22 AM   #9
Hart_Rod
Hart_Rod's Avatar
I'll take one! Where's the order form?
Rob - http://instagram.com/hart_rod
As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17
FOR SALE: DBW pedal bracket, Pedal adapter for LS trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=651123
FOR SALE: ChubTubz, Rear tubs for slammed trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=675754
FOR SALE: Hood Brackets, Bolt in hood brackets! http://67-72chevytrucks.com/vboard/s...d.php?t=679945
1969 SuperBurb - 5.3/Magnacharger..http://67-72chevytrucks.com/vboard/s...d.php?t=200387
1968 Farm truck: LS3/6L80/TVS1900: http://67-72chevytrucks.com/vboard/s...d.php?t=358692
1968 SWB - SHIFTED: PB Xtreme DM/LS1/Dakota Digital/AccuAir/Vintage Air/...http://67-72chevytrucks.com/vboard/s...d.php?t=551258
1948 5 Window Chevy http://67-72chevytrucks.com/vboard/s...=122164&page=3
FAQ: http://67-72chevytrucks.com/vboard/f...play.php?f=220
Hart_Rod is offline   Reply With Quote
Old 08-11-2006, 04:56 PM   #10
ratrod67
ratrod67's Avatar
Do you have any pics of it mounted to the truck from farther back? I'd like to see the whole front if possible. Thanks!!
ratrod67 is offline   Reply With Quote
Old 08-11-2006, 06:12 PM   #11
What type of truck did you get the hood relase handle/cable assembly from?
ooooppps...Never mind I see where you mentioned it.
1981 GMC High Sierra SWB Stepside
2006 GMC Sierra 1500 SWB W/T
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 08-11-2006, 07:46 PM   #12
dennislbrooks
We can make that
here are 4 more pics -- one is the super secret emergency loop in case there is a cable failure. Only I and 4000 other people know where it is. I took a couple of front pics but will take a couple more at the Hooters Car show Sunday on Beltline Rd. The 88 hood release works fine -- as you know you cannot get your fingers under the hood for the second release ---- I pack a 1/4" x 1" x 6" long piece of wood to release it. I still plan on putting 4 more screws to secure the mesh better on the center horizontal --- 2 on each side of the center -- as soon as I get my 90 degree air drill.
Old 08-11-2006, 09:30 PM   #13
Sweet72
Sweet72's Avatar
The hood release is a very nice mod!
I sure wished I had one a few years ago when I was leaving work and found that someone in the parking lot had been eye-balling my engine (my hood was wide open). The old girl seemed "dirty" after that, like as if someone had lifted her skirt to see if she was wearing panties.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 08-12-2006, 10:11 AM   #14
Joe67
67 is sold
I agree - very nice
Great write up too
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-12-2006, 10:30 AM   #15
LUV2XCLR8
"Square Corvette"
LUV2XCLR8's Avatar
Sweeeeeeeeeeeeeeeeeeeeeeeet
The Toy: "Square Vette" 72 C5 Blazer
Toy Puller: "Burakkubyūtī" 12 Tundra
Toy Hauler: "Feathers" Aluma 8218T
Owner/Admin "TN Classic Truck Club"
LUV2XCLR8 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
