Old 09-10-2006, 07:06 PM   #1
pcmcobra
pcmcobra's Avatar
1986 Silverado, and 3.5" dash speakers...
I want to replace my dash speakers with better speakers. Mine are original and are just about in the grave. I just put in a new cd player, that will put out about 20-25 watts per channel.
Looking for something so I don't have to modify anything. What brand, model do you recommend?
thx
pcmcobra is offline   Reply With Quote
Old 09-10-2006, 08:26 PM   #2
84 400
Sb 400 club
84 400's Avatar
Re: 1986 Silverado, and 3.5" dash speakers...
lmc sells them and i think they are avilbe at wall mart not sure of the watt rating though
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
2000 Tahoe LS(dads)
1956 Willys Wagon (327 chevy) Project (Now Buick 225) t90,dana 18 twin stick,dana 25 front, dana53 rear 588's.....
1976 CASE 210(Project)
84 400 is offline   Reply With Quote
Old 09-11-2006, 12:29 AM   #3
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
A while back I was thinking the same with my dash speakers. But, it's relatively costly to replace them with a quality pair. I know you mentioned that you don't want to mod anything, but you may be better off wiring a typical size (i.e. 6x9s) speakers into the cab, say in rear of the cab. You'll get a better sound from them than those in the dash and may be a bit less costly.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 09-11-2006, 09:18 PM   #4
edman87
junk collector
You can get decent 3.5' s for about $50- pioneer, blaupunkt, infinity. You might as well use some decent speakers if you are going to take the hassle of removing the dash and installing them. I have an extra set of pioneers that I took out somewhere since I will be going back with a custom stereo because you can't get a whole lotta sound out of a 3.5!
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 09-11-2006, 09:38 PM   #5
pcmcobra
pcmcobra's Avatar
I am going with a custom set up, either 6.5 in the door, or kick panels.With some 10's in a box.
Would it even be worth it to replace the 3.5's? They would just be running off head unit power.
Thinking about replacing the 4x10's in the back with some thing, just don't know with what.
Any ideas?
Any help appreciated.
thx
Old 09-11-2006, 09:43 PM   #6
84 400
Sb 400 club
84 400's Avatar
i have been wonder ing the same what can i do with the 4x10"s they don't seem to sell them around hear/ thanks
2000 Tahoe LS(dads)
Old 09-11-2006, 09:58 PM   #7
edman87
junk collector
pioneer still sells 4x10 3 ways I am pretty sure, got a set of them too. The 3.5 will definately add some "high" to you combo. I used to have a set of kenwood 3.5 that made a huge difference in sound quality, backed up by 2 10's and some mini dome tweeters.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 09-11-2006, 10:11 PM   #8
pcmcobra
pcmcobra's Avatar
pioneer, sony, polk, kenwood all have 4x10's. I have been checking online steady for the last week.
Maybe some more brands I overlooked...
Old 09-11-2006, 11:01 PM   #9
mitch1965
mitch1965's Avatar
When my wife bought me a new Pioneer cd stereo for Christmas, I put 6x9's behind my seat, and new 4" speakers in the corners of the dash. I had to modify the dash and rear mounts, but they fit.
Mitch
'87 V20 - 350/TH400, factory TBI, 4.10 w/powertrax locker, HD springs, helper air bags on rear
'96 K1500 - 350/ 4L60E, 3.73
mitch1965 is offline   Reply With Quote
Old 09-11-2006, 11:08 PM   #10
pcmcobra
pcmcobra's Avatar
what exactly did you have to do to the dash?
I have mine off right now, and it's tight on drivers side. I don't want to cut the dash pad, so far it does not have a scratch on it!
Old 09-12-2006, 12:50 AM   #11
Slonaker
Insert Witty Text Here
Slonaker's Avatar
If you have 4X10 mounts for the cab corners, you can mount 6X9 speakers to them with a little bit of work. Swap the mounts side to side (L to R, R to L) and you'll have extra room for large magnets. A friend was able to get some rather large 6X9 Pioneers in the cab corers using this method.
Cab corner brackets used to be common in stereo shops, but nobody carries them any more. I found a set in a junkyard after about 2 years of searching. One of these days I might even mount them...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 09-12-2006, 01:31 PM   #12
84 400
Sb 400 club
84 400's Avatar
Slonaker
thanks i have heard of this before. Mune has no corner mount brackets right now because the previous owner was running his 6x9 in there own boxes. so if i take the empty brackets i have and switch the sides i will be able to mount 6x9's? anyone got a pic of this ?
sorry to jack the threade
thanks
2000 Tahoe LS(dads)
Old 09-12-2006, 02:05 PM   #13
Jonboy
Slots go on anything!
You can also mount a pair of 5 1/4 speakers in the center hole of the dash.
1974 Jimmy- 5.3/4L80e/NP241
Old 09-12-2006, 03:28 PM   #14
Ric83
Ric83's Avatar
When I had my system in my truck, I was running a single IDQ 12" behind the seat with an amp on either side; one for the sub and one for some 6x9"s in the cab corners, and some 3.5"s in the dash running off of the deck. Sounded awesome this way.
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 09-12-2006, 05:11 PM   #15
Slonaker
Slonaker's Avatar
thanks
I don't have any photos. I saw some once on another Chevy site, which is what prompted my friend to try it. He sold the truck last month, though.
Slonaker
Stock '01 Silverado
Old 09-12-2006, 05:38 PM   #16
boxrodz
boxrodz's Avatar
Any ideas?
thx
If you're going custom, you could just go with tweeters in place of the 3.5s for your high freqency and then replace your 4x10s with a more popular size, like 6x9s. Then, fab up an enclosures/brackets for the 6x9s.
boxRODz
Old 09-13-2006, 02:56 AM   #17
AceX
>130dB Moderator
AceX's Avatar
The first question I have is: Are you going for sounds quality, or just pure volume?
If you're not too worried about sound quality, just throw a set of 3.5" speaker from Infinity, Kenwood, or Eclipse in there, a pair of 6x9's behind the seat, and probably a new headunit to get some more power to them.
If you want more sound quality, just say so and I can give you a run down on what to look for.
AceX is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
