Old 09-29-2006, 01:02 AM   #1
PBFAB.COM
PBFAB.COM's Avatar
Dropmember C4
Here's the latest version of the Dropmember... The DropmemberC4. It utilizes C4 Corvette suspension and steering components. The main advantage of the DropmemberC4 is performance, but other plusses include overall appearance and of course, EGO enhancement. It uses either a coil-over or Shockwave (PN SKW1030). It is offered with a ride height of 5" or 6" with a 27" tall tire. When used with the Shockwave, the 5" ride height will put the frame on the ground (with 27" tall tire), and the 6" ride height leaves the framerails an inch from touchdown.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 09-29-2006, 01:03 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: DropmemberC4
a few more...
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 09-29-2006, 01:06 AM   #3
krue
Designated A-hole!
krue's Avatar
Re: DropmemberC4
Being stupid ain't illegal.
www.daveramsey.com
96 S-10 "Pop's Truck"
Old 09-29-2006, 02:19 AM   #4
AesC10s
Chevy truck addict
AesC10s's Avatar
Re: DropmemberC4
would you be able to make one of those c4members for standard bags?
AesC10s is offline   Reply With Quote
Old 09-29-2006, 08:27 AM   #5
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: DropmemberC4
<------drooling Heavily
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 09-29-2006, 11:59 AM   #6
PBFAB.COM
PBFAB.COM's Avatar
Re: DropmemberC4
The standard bags are difficult enough to make work with the C4 components, but add the width and location of the frame-rails and there is not enough room for the bag and the shock. Also, the control arms are aluminum and that adds to the difficulty of bag/shock/ sway-bar mounts. I set-up a custom chassis a few years ago with C4 and bags up front... ended up changing it over to the Shockwave. There just wasn't enough room for the bag and shock when cycled through its travel.
The effort involved in setting it up this way would cost me more than a Shockwave would.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 09-29-2006, 12:29 PM   #7
67Fleet
67Fleet's Avatar
Re: DropmemberC4
Nathan, I may have missed another thread you've posted, but I think what AesC10s might be getting at (because I was wondering myself) is do you offer a dropmember that doesn't require using all the C4 components and does not need the rack? I'd be interested in going that route and still being able to use my stock arms (could go tubular if necessary), and current front bag setup.
-Bret
Old 09-29-2006, 01:19 PM   #8
PBFAB.COM
PBFAB.COM's Avatar
Re: DropmemberC4
All the Dropmember designs, current and future, incorporate a rack and pinion. If you were hoping to keep the stock steering box and linkage, it just won't work. Originally I had thought about doing so, but the advantages of using rack and pinion: ease of design and fabrication w/using rack and pinion, performance gains in steering w/rack, and of course when the frame is notched for tie-rod clearance the box would be in front of the notch and it would just be a matter of time before the frame cracked and broke... not "if". After weighing the pros and cons I figured a $250-$300 cost of purchasing a rack would actually be an investment.
What are the concerns with the rack? I have had a lot of people ask if they could use the stock box. I always assumed it was cost... is that correct?
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 09-29-2006, 01:29 PM   #9
panhandler62
Java Mechanic
panhandler62's Avatar
Re: DropmemberC4
Don't mean to thread-jack this but.. .. could something like this be set up as a static drop with .. oh say about 4 inches of clearance running 16 or 16.5s with a normal size tire or wold that be a completely different animal?
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-29-2006, 02:21 PM   #10
PBFAB.COM
PBFAB.COM's Avatar
Re: DropmemberC4
It definitely can be. The deciding factors on where ride height would be are tire diameter and then coil-over selection. With a 26-27" tall tire and the proper coil-over it will set about where you want it. My main purpose in building this piece was performance, I just made it capable of using a Shockwave so it could cover a broader market. Best of both worlds... performance guys get theirs, and the go low guys get theirs.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 09-29-2006, 02:58 PM   #11
AesC10s
Chevy truck addict
AesC10s's Avatar
Re: DropmemberC4
i want everything this has to offer but the only thing that i want is 1 that has standard bags becuz i already have them.
Old 09-29-2006, 04:39 PM   #12
67Fleet
67Fleet's Avatar
Re: DropmemberC4
Nathan, you would be correct in your assumption of price, at least from my perspective. Not that I don't think it is worth it because it clearly is IMO. I'm just on a tight budget, and right now it isn't in my budget unfortunately. I am building my truck to be a weekend cruiser and my needs are not really performance oriented anymore, (I'm getting older...) though it must perform better than stock, be as safe or safer than stock, and be able to get low. I think my best option would be to section the existing x-member I have, but it sure would be nice to have the money to buy that piece of art that you have developed.
-Bret
Old 09-29-2006, 05:27 PM   #13
PBFAB.COM
PBFAB.COM's Avatar
Re: DropmemberC4
67Fleet-
Have you seen the original Dropmember? It sounds a lot like what you're referring to. It can use your stock arms and bag set-up you currently have, but the rack is a must... You can find a MII manual rack for $160 rebuilt... who knows what one on E-bay would go for.
As for budget, I know exactly what you mean... that's why I currently drive a 1995 Silverado with 18's and no suspension mods! Turns out that there isn't much left over after the mortgage and expenses for the wife and kids get taken care of! (I've been dumping the majority of revenues back into my business. Tools and equipment aren't cheap in this industry!)
Hopefully I will get my own sick ride done in the next year or two!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-06-2006, 09:00 PM   #14
Rokcrln
Rokcrln's Avatar
Re: DropmemberC4
Looking great as always! I sure can't wait to start on the ...OOP's never mind
So when is the C4 back half kit going to be comming out
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 10-06-2006, 09:04 PM   #15
tom71
what happened to flint mi
tom71's Avatar
Re: DropmemberC4
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 10-09-2006, 05:36 PM   #16
valleycustom
Re: DropmemberC4
I wish I had that...
Please become a site supporting vendor to advertise a business in your signature. you can do so here
valleycustom is offline   Reply With Quote
Old 10-16-2006, 01:48 PM   #17
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: DropmemberC4
what kind of cost is there for a complete setup? rack, arms, shockwaves, spindles, etc?
Do you see any issues with using larger tires? like in the 29-30" range.
IvelDesigns is offline   Reply With Quote
Old 10-16-2006, 03:13 PM   #18
PBFAB.COM
PBFAB.COM's Avatar
Re: DropmemberC4
DropmemberC4- $1200
Rebuilt C4 Rack and Pinion- $350
DropmemberC4 Basic Kit- $1500 (Includes Dropmember and C4 Rack and Pinion)
Spindles/Brakes/upper and lower control arms (used from salvage yard)- $750-$850 ... I've seen em for less as well. (Keep in mind possible rebuilding of parts/components) Good idea to buy front suspension complete with rack, crossmember, and transverse spring... you can sell off the parts you do not use and recoup a few hundered bucks.
Shockwave's- $849
Tie-rod ends- $150
Steering joints and Linkage- $350
Total $3700 + misc. expenses ~ $4000
As for the tire diameter question... 27" will put the frame on the ground, so a 29" diameter will put the frame 1" off the ground. You can go larger than 27" diameter, clearances just get tighter and tighter.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-16-2006, 10:39 PM   #19
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Re: DropmemberC4
Drool!!! I better start saving my pennies
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 10-17-2006, 03:51 PM   #20
CochinoFilipino
CochinoFilipino's Avatar
Re: DropmemberC4
WOW! How'd I miss this? That's an awesome piece or work. Does it maintain the original C4 geometry?
'67 C10 Short Stepside 5.0TPI/700R4
CochinoFilipino is offline   Reply With Quote
Old 10-17-2006, 04:06 PM   #21
LUV2XCLR8
"Square Corvette"
LUV2XCLR8's Avatar
Re: DropmemberC4
The Toy: "Square Vette" 72 C5 Blazer
Toy Puller: "Burakkubyūtī" 12 Tundra
Toy Hauler: "Feathers" Aluma 8218T
Owner/Admin "TN Classic Truck Club"
LUV2XCLR8 is offline   Reply With Quote
Old 10-17-2006, 04:17 PM   #22
PBFAB.COM
PBFAB.COM's Avatar
Re: DropmemberC4
The geometry does vary slightly from the original C4 design... due to the fact that we are dealing with a longer wheel base, a higher center of gravity, and of course a heavier vehicle. The geometry needed a bit of tweaking to make it work as desired on this application. The idea behind this design is true performance. I'm a big fan of the G-machine craze, and there hasn't been much performance suspension systems designed or developed for trucks... nothing that I know of. I think it's a market that is going to start seeing some real growth... trucks that handle like sportscars!
Thanks for the compliments.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 10-17-2006, 04:38 PM   #23
CochinoFilipino
Re: DropmemberC4
Sounds like your "tweaking" was done to actually further improve performance and not just to make it fit. That's even more cool.
Old 10-30-2006, 07:46 PM   #24
GMCGRANDS
Re: DropmemberC4
I have been following your threads and have been impressed with your work. I have been through 4 front suspensions in the last four years, and what you now have looks to be what I have looked for over that time. I want my truck lower but I am not interested in draging frame. I want the handling. I settled for a Fatman at the time but this has posed new challenges with my engine/trans combination, headers, engine mounts, and steering shaft . I have limited fabrication skills and prefer a bolt in application. I have a few questions . Does the C4 member include the engine mounts for a Gen 3 (LSX) engine?
I noticed in the dropmember thread you weld the mount on for the steering shaft support, is this done on this kit as well? How about a front swaybar? If draging frame is not a goal what mods are required to the floor hump or cab floor? Can wider front wheels be run to bring the track width closer to stock without negative effects to handling? Do you build a header for this application or have a suggested manufactor that will work? As the truck gets lower the wheels move closer to the firewall, will this kit keep the wheels centered in the wheel wells? I for one am glad to see someone interested in handling. Sorry for the long post. Thks
Mark
72'GMC Sierra Grande 2wd SWB, Fatman stageV IFS, 6.0 liter LQ4 Gen 3 and 4L80E under construction
05' GMC Sierra Denali LQ9
GMCGRANDS is offline   Reply With Quote
Old 10-31-2006, 12:29 AM   #25
PBFAB.COM
PBFAB.COM's Avatar
Re: DropmemberC4
Originally Posted by GMCGRANDS View Post
I have a few questions . Does the C4 member include the engine mounts for a Gen 3 (LSX) engine? I noticed in the dropmember thread you weld the mount on for the steering shaft support, is this done on this kit as well? How about a front swaybar? If draging frame is not a goal what mods are required to the floor hump or cab floor? Can wider front wheels be run to bring the track width closer to stock without negative effects to handling? Do you build a header for this application or have a suggested manufactor that will work? As the truck gets lower the wheels move closer to the firewall, will this kit keep the wheels centered in the wheel wells? I for one am glad to see someone interested in handling. Sorry for the long post. Thks
The Dropmember C4 will be offered with mounts for the increasingly popular LSX engines. The LS engines take up a little more space than the traditional small block and clearances are at a premium. The LS motors will fit without firewall clearance problems. The steering shaft is tricky, and I can mock it up for you in my shop truck before shipping (if you are using a stock or stock replacement column) I will have a better idea of header to steering clearances in the next few weeks (we are installing this same combo in a 71 blazer... full C4 and an LS motor). All the floor needs is the large hump tranny tunnel. The rear of the cab should not require any mods if you do not intend to do extreme lowering. The wheel offset will have an effect on the scrub radius (let me know what backspacing you intend to run and I can tell you how much of an effect). Sway bar is a must... I can offer some better input as we move forward on the Blazer project. The wheels do move towards the cab in compression. I set it up to have the center-line slightly forward of the wheel opening center-line and at full compression it is pretty close to center (see pics).
Hopefully I answered all the questions. If you have more, don't hesitate to ask.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
