10-22-2006, 07:59 PM | #1 |
newer 2nd row seats
Has anybody here put a row of 73-91 seats in their sub? If so could you post some pics of em up and folded down, also do they take much fabrication or will they just bolt in?
thx in advance |
10-23-2006, 08:51 AM | #2 |
Junior Member
Re: newer 2nd row seats
They go in without a lot of fabracation. The only thing I had to do was modify the lower seat center bracket and shim the lower seat outer stands that the seat sits on when it is in the seat position. To make the seat back latch I made a sheet metal piece from the wheel well forward. I will try to get some pictures posted of the brackets in place and the sheet metal filler for the latch. Dave
10-23-2006, 10:21 AM | #3 |
I would be interested in pics also. My PO installed a late '70s seat, but it does not latch in the upright position. I kinda know what I have to do to get it to latch, but if your way is easier, then gret....
10-23-2006, 04:45 PM | #4 |
Junior Member
Here are the pictures of mounting the brackets and hinge for the seat backs. I also included a shot of the brackets I made for the front seats. Dave
10-23-2006, 04:48 PM | #5 |
Junior Member
Here is the last of them. Dave
10-24-2006, 07:16 AM | #6 |
Junior Member
I made the filler panels to mount with screws. The hole in them is for a speaker. The back side has a stiffner added to it. I drilled the holes for the latch then welded nuts to the back side. Dave
10-27-2006, 11:13 AM | #7 |
Thanks a ton faster- couldnt have asked for anything better than that...
Ill post some pics when im done |
01-31-2011, 03:14 PM | #8 |
any updates on this?, new pictures?.....sounds promising!
04-15-2012, 10:38 PM | #9 |
08-29-2012, 09:18 PM | #10 |
anyone else have pics???
