Old 01-01-2007, 11:37 PM   #1
68350
68350's Avatar
dana 60 5 lug conversion
Has anybody done a 5 lug conversion to a dana 60 8 lug rearend? Or does anybody know where I can look to find out how to do it? Any idea on price for a conversion like this? thanks a bunch, doug
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
71 Chevy Cheyenne/20, 402/4 speed, tool and stowage
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
72 GMC Sierra Grande Longhorn 2500. 402/th400, a/c, tool and stowage
68350 is offline   Reply With Quote
Old 01-01-2007, 11:40 PM   #2
poorboy
poorboy's Avatar
Re: dana 60 5 lug conversion
I don't think it can be done.
poorboy is offline   Reply With Quote
Old 01-01-2007, 11:49 PM   #3
Schralper
Schralper's Avatar
Why??!!
For racing?
Sell it and buy a 9"
Schralper is offline   Reply With Quote
Old 01-01-2007, 11:52 PM   #4
manimal
manimal's Avatar
Do you want to keep it full floating? I have an article somewhere in one of my 4x4 mags about converting to full floating 5 lug. If you dont want a FF then you have to cut the flanges off and weld on new axle flanges,get axles made,backing plates,brake hardware,etc... I will look for the article and pm you when I find it.
-Lance
manimal is offline   Reply With Quote
Old 01-01-2007, 11:56 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you could unbolt that axle, and install a 5 lug axle
Old 01-02-2007, 12:02 AM   #6
poorboy
poorboy's Avatar
If you still want a floating axle that 's 5 lug you can run a 9" floater.
Old 01-02-2007, 01:08 AM   #7
masterbeavis
Having issues
masterbeavis's Avatar
Are you starting with a full floating or a semi floating rear axle? If you are running a semi, you can just have new holes machined into the flange. There are kits available to convert to a 5 lug pattern, or have a machine shop fill/redrill/turn down your hubs on your 60. It can be done, but it is not cheap. Expect to pay a minimum of $600, and that price is somebody doing you a favor. I know it is do-able with the 6 lug pattern, but don't know about the 5 lug pattern
masterbeavis is offline   Reply With Quote
Old 01-02-2007, 01:09 AM   #8
masterbeavis
Having issues
That axle is a semi float axle. The bearing surface is not the axleshaft, but the axle shaft still bears weight of the vehicle. For non HD purposes however, the 9" is a great axle. There are aslo C clip eliminator kits available for the 10 and 12B axles, that might be a cheaper solution rather than swap out stuff.
Old 01-02-2007, 01:23 AM   #9
poorboy
poorboy's Avatar
A 9" flaoter has full floating axles. It's what we run in our race cars. Here's a link to some. You ca normally get a good deal on used ones. Alot of asphalt cars run truck arms too.
http://www.daymotorsports.com/product/142/c/B377/#
http://www.secureperformanceorder.co...ProductID=2072
Old 01-02-2007, 02:32 AM   #10
BCOWANWHEELS
moser engineering is a great place to get a dana60 5 lug rear very reasonable
BCOWANWHEELS is offline   Reply With Quote
Old 01-03-2007, 01:10 AM   #11
masterbeavis
Having issues
Poorboy, a 9" is not a full floater. A full floater has a hub, with bearings that DO NOT touch the axle shaft in any way shape or form, and thus do not carry any weight. Those axles that do have hubs, and have bearings touching the axle shaft, but do not have C-clips are semi floating axles. The 9" has the bearing and race pressed onto the shaft. If the axle breaks between the bearing and the face of the wheel mounting surface, you loose your tire.
Old 01-03-2007, 11:37 AM   #12
poorboy
poorboy's Avatar
You are right. A stock 9" is that way. A floater is a (" that has bolt on hubs and floating axles. It's what Nascar runs,IMCA Mods, most Stret Stock,ect. It's mostly used in circle track but can be put in anything. Do a search for yourself and you'll see what I'm talking about. Here's a link to some 9" flaoter axles.
http://www.southwestspeed.com/?sec=v...x%205,%20Solid
Old 01-03-2007, 09:21 PM   #13
masterbeavis
Having issues
That upgrade sounds almost as expensive as doing a 5 lug 60
Old 01-03-2007, 10:03 PM   #14
poorboy
poorboy's Avatar
It might be. But I bet parts would be easier to find and you would have a better gear selection.
Old 01-03-2007, 10:14 PM   #15
kwmech
It can be done, I've been building custom axles for years, the only problem will be what ratio you want. The 60 can go from 3.54 all the way down to 7.17. If you want anything taller than 3.54, you can look at a D61 which will take you to a 3.08. All it take is a decent checkbook
Old 01-03-2007, 10:32 PM   #16
Jtrux
I'm a poor spectator
Jtrux's Avatar
You ask and you shall recieve.
With these kits you can still run 15 inch wheels too.
This is Geartech Heavy Duty's conversion kit. It's a bolt on deal.
http://www.geartechhd.com/gallery/di...?album=5&pos=8
Here's proof that there stuff works. This is a 14 bolt with a 5 lug conversion featured in JP magazine.
http://www.jpmagazine.com/projectbui...pickup_part_3/
I guess it's really not that big of a deal. Personally I want the 14 bolt with 6 lug conversion for my blazer.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
