Putting a 1987 700R4 in my 1982 GMC 4x4...
Awhile back, I posted that the Internal Reaction (Ring) Gear shattered in my 1982 GMC 2500 4x4 truck. Here are the links to my previous posts.
http://67-72chevytrucks.com/vboard/s...d.php?t=217634 http://www.hotrodders.com/forum/inte...r4-103421.html I decided to take Jonboy's advice and purchase a SRTA (Service Remanufactured Transmission Assemby) 700R4 from my local GM dealership. The price was right -- a little over $1600 plus labor -- and they come with a 3 year, 50K mile warranty. Sounds good to me. How could I go wrong? Well, that didn't work out. I visited two GM dealerships. GM doesn't offer a SRTA 700R4 for the 1982 thru 1986 model years -- only for 1987 and newer. GM won't honor their warranty on a 1987 SRTA installed in a 1982. I asked them to go ahead and install it without warranty. Still, they declined to install it. I believe it is because of the differences in the vacuum/electronic mechanism for the Torque Convertor Lock-up between 1982 and 1987 model years. In case anyone is interested, GM offers a performance grade AL60-E transmission for older model years, including 4x4 trucks. p/n 19156259, trans, $2,174.00 p/n 12497316, (computer) module, $1,284.00 They even offer an AL85-E for slightly more money. This leaves me with two options: 1) Purchase a crate 700R4 from a rebuilder. 2) Purchase a used 700R4 from a salvage yard 700R4 and have it rebuilt locally. Question #1 Many shops here in Indiana have strongly recommended that I stay with a 1982-1986 700R4. Everything that I've read says otherwise -- I should upgrade to 1987 or newer. Should I continue searching for a shop that is willing to install a 1987 700R4 in my 1982 vehicle? Question #2 How does the factory mechanism to lock-up the torque convertor in my 1982 vehicle actually work? I see some vacuum hoses. I see a thermo-valve. I see a solenoid with two wires. I think that I see a one-wire connector on my 1982 torque convertor. I can't find anything to un-lock the TC using the brake light circuit. Question #3 Will the 1982 factory mechanism work properly on 1987 TC? I believe that the one-wire solenoid on 1982 grounds internally to transmission case. I believe that the two-wire solenoid on 1987 allows me to place an override switch on the external ground wire. Question #4 I am aware of... TCI AUTO TCI-376600 Torque Converter Lockup Kit http://www.tciauto.com/Products/GM/gm_2004r.asp http://store.summitracing.com/partde...t=TCI%2D376600 http://www.jegs.com/webapp/wcs/store...0002_748599_-1 B&M TC Lock-up Kit http://www.bmracing.com/ http://store.summitracing.com/partde...rt=BMM%2D70244 Painless Wiring TC Lock-up Kit - 764-60109 http://www.jegs.com/webapp/wcs/store...47219_-1_10733 What are the advantages of using these kits over my 1982 factory mechanism? |
UK Wildcat Fan!
Re: Putting a 1987 700R4 in my 1982 GMC 4x4...
I am NOT the expert on this, but when researching this topic a number of years ago for my 72 chevy, I found company's doing business through ebay that would rebuild to your specs. they could/would replace the weaknesses inherent to the early designs and upgrade to larger sunshells, clutches, shift kits-whatever you choose.
here is a poster selling for a project that fell through: http://cgi.ebay.com/ebaymotors/700R4...74414441QQrdZ1 seek and ye shall find :-) |
In 87 and after the TCC was controlled by the ECM, where the 86 down was controlled by the TV cable which is a way better setup in my opinion. The difference internally between the 2 is the earlier version has a TCC shift valve train in the valve body, the later has that bore plugged with 2 aluminum plugs. You can just take and install the valve train from an earlier model in the 87 and it will work just like the older one. And if you use the later tcc solenoid, you will have to either cut the black wire short inside and ground it or ground it after it comes out of the plug. The best way is to use a early wire harness. But it can be made to work just fine and you will not need bowtie overdrives to pull it off.
86K10 455 Olds 700R4 4.10 No Spin Rear Axle 8.5" Corporate Front (Limited Slip) 85K30 M1028 5/4 ton 6.2 diesel 400THM soon to be 700R4 4.56 no spin rear Dana 60 no spin front 74C20 350 .060 over 700R4 4:10 No spin axle REAL AMERICANS, DRIVE AMERICAN |
#4 | |
Update to...
http://www.hotrodders.com/forum/putt...x4-107964.html http://67-72chevytrucks.com/vboard/s...d.php?t=225385 Quote:
I searched for a neighborhood member of Automatic Transmission Rebuilders Assoc (ATRA) http://www.atra.com/source/amembers/...searchtype=reb http://www.atraonline.com/source/ame...searchtype=reb Last edited by robert213; 04-26-2007 at 08:16 PM. |
#5 | |
--UPDATE--
To lock-up the TC Clutch, the solenoid requires 12V power and hydraulic fluid pressure. The Electronics Side. a) Switched 12V Power. 12V source from either the Accessory or Ignition circuit. b) Normally Open Brake Switch. There are two brake switches. When the brake pedal is depressed, the normally-closed brake switch turns-on 12V power for the brake lights and the normally-open brake switch turns-off 12V power for the TCC Solenoid. This switch functions in a similar manner as a cruise-control switch. This is a fail-safe mechanism, if the hydraulics side should stop working correctly. Otherwise, the engine would die while coming to a stop because the TC stayed locked-up. c) Vacuum Switch. 1. Vacuum source is from the intake manifold. 2. Thermal-valve allows vaccum after engine reaches operating temperature. 3. Vacuum regulatory valve (GM-140206691) smoothes out spikes in vacuum. 4. Vacuum switch turns-off 12V power when vacuum drops below predetermined psi. My guess is somewhere between 6-9 psi. This un-locks the TC whenever the engine is under load conditions - e.g. wide-open-throttle or climbing a hill. d) TC Clutch Lock-Up Solenoid. When open, this solenoid valve allows fluid under pressure to pass thru to Torque Convertor. e) Ground side of solenoid, normally open 4th gear pressure switch. I do not know for a fact, but there may be (or may not be) a ground switch which turns-on when fluid is under pressure to activate 4th gear. There may (or may not) be another similar ground switch for 3rd gear. f) Ground is done inside of transmission. Things that changed when carburator was replaced with throttle body injection (TBI) setup... a) Vaccum switch and corresponding vacuum hoses were removed as engine load conditions - e.g. wide-open-throttle, climbing a hill, etc can now be calculated by computer using the manifold absolute pressure (MAP) sensor. b) TC Clutch Lock-up Solenoid changed from one-wire to two-wire. c) Electronic Connector increased to four pins. PIN-A - 12V power PIN-B - ECU input signal, 4th gear in use PIN-C - Unknown to me PIN-D - TC Clutch Lock-Up ground d) ECU now has complete control of TC Clutch Lock-up. It closes the ground side of TCC Lock-up Solenoid circuit, whenever it wishes the TC to lock-up. The Hydraulics Side. It may be best just for you to ask for the hydraulics circuit diagram for TCC Lock-up from a dealership service manual. In my understanding, in the valve body... a) Throttle Valve. The Throttle Valve (T.V.) cable is adjusted at carburator to determine throttle position. b) Speed Governor. A gear on the transmission output shaft is used to determine vehicle speed. c) TC Lock-up Valve. There is a battle of fluid pressure between Throttle Valve and Speed Governor. Whenever the Speed Governor wins the battle, the TC Lock-Up Valve allows fluid pressure to flow to the TC Clutch Lock-up Solenoid. Things that changed when carburator was replaced with throttle body injection (TBI) setup... In the valve body, the hydraulic circuit that regulated flow of fluid to the TC Clutch Lock-up Solenoid was plugged. The TC Clutch Lock-up Solenoid now receives constant continuous fluid pressure. If the TC Clutch Lock-up Solenoid electric circuit is grounded and the ECU removed, then the TC Clutch will lock-up in 2nd, 3rd, and 4th gears. It will not lock-up in first gear because the hydraulic circuit in the valve body does not allow fluid to pressurize until 2nd gear is reached. |
#6 | |
--UPDATE--
This is why companies developed TC Clutch Lock-up Kits. The instructions for the B&M TC Lock-up Kit has the most very useful information... http://store.summitracing.com/instru...%2D70244%2Epdf Last edited by robert213; 04-26-2007 at 08:21 PM. |
#7 | |
--UPDATE--
http://store.summitracing.com/egnsea...115+4294903956 TCI AUTO TCI-376600 TC Clutch Lockup Kit Instructions http://www.tciauto.com/Products/Inst...76600_inst.htm Does NOT have normally-open brake switch. Does NOT have Vacuum Thermal Valve. Does NOT have Vacuum Regulatory Valve. Does have Vacuum Switch. Replace TCC Lock-up Solenoid wiring harness inside of transmission. Splice into existing TCC Lock-up Solenoid (two-wire). Replace 4th-gear pressure switch (two-wire). TCC Lock-up occurs when... 1. Vacuum is greater than 9 psi. 2. Transmission is running in 4th gear only. Kit has manual lock-up switch in order to lock-up while running in 3rd gear when towing a trailer. However, driver must remember to turn off switch while vehicle comes to a stop. Painless Wiring 764-60109 TC Clutch Lock-up Kit Instructions http://store.summitracing.com/instru...%2D60109%2Epdf Does have normally-open brake switch. Does NOT have Vacuum Thermal Valve. Does NOT have Vacuum Regulatory Valve. Does have Vacuum Switch. Replace TCC Lock-up Solenoid wiring harness inside of transmission. Replace TCC Lock-up Solenoid (two-wire) -- no splicing Replace 4th-gear pressure switch (two-wire). TCC Lock-up occurs when... 1. Vacuum is greater than unknown psi. 2. Transmission is running in 4th gear only. JET Performance JET-700211 TC Clutch Lock-up Kit Instructions http://<br /> http://store.summitra...5&autoview=sku http://www.jetchip.com/products.asp?pid=14475 Does NOT have normally-open brake switch. Does NOT have Vacuum Thermal Valve. Does NOT have Vacuum Regulatory Valve. Does have Vacuum Switch. Replace TCC Lock-up Solenoid. TCC Lock-up occurs when... 1. Vacuum is greater than unknown psi. B&M 70244 TC Clutch Lock-up Kit Instructions http://store.summitracing.com/instru...%2D70244%2Epdf B&M takes a different approach. Rather than restricting the TC lock-up to just 4th gear, B&M replaces the internal hydraulic functions with a speed pulse generator. Does NOT have normally-open brake switch. Does NOT have Vacuum Thermal Valve. Does NOT have Vacuum Regulatory Valve. Does NOT have Vacuum Switch. Does have Electronic Black Box. Does have Speed Pulse Generator. Does have adapter for speedometer cable. TCC Lock-up occurs when... 1. Vehicle is traveling above adjustable predetermined m.p.h. .. Kit suggests somewhere between 30 and 40 m.p.h. |
--UPDATE--
http://www.hotrodders.com/forum/putt...x4-107964.html http://67-72chevytrucks.com/vboard/s...d.php?t=225385 What did I decide to do? I am keeping the factory OEM electronics... a. Replacing OEM vacuum switch with adjustable aftermarket vacuum switch. b. Performing a test with volt-meter to insure electronics are working properly. c. Adding an indicator-on light to dash using ground side of TCC Lock-up solenoid. I am keeping the factory OEM vacuum mechanism... a. Replacing all rubber vacuum hoses with silicon hoses. b. Installing Vacuum Regulatory Valve (GM-140206691) c. Performing a test with vacuum gauge to insure vacuum mechanism is working properly. Since I do NOT wish to modify hydraulic circuit in valve body and since I do NOT wish to modify internal wiring harness, I am installing B&M 70244 TC Clutch Lock-up Kit to perform the function that was previously performed by TCC Lock-up Solenoid circuit in valve body. Other folks may wish to use circa 1987-1988 valve body. Others may wish to modify 1987-1988 valve body to use larger 1991-1992 valves. I am going to insure that TC Clutch will lock-up in 2nd, 3rd, and 4th gears and then install B&M kit to restrict lock-up to vehicle speeds above 40 m.p.h. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
