Old 05-16-2007, 11:56 AM   #101
grebus1
grebus1's Avatar
Re: Finally got the beast home......
Here are a couple pics from different silver books. The first shows how the '60-'66 models were converted to crew cabs. The other pic shows both a light duty and a medium duty crew cab (with doors open)--both appear to be based on the same style.
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 05-16-2007, 01:32 PM   #102
AC72
AC72's Avatar
that's friggin awesome, is that original,or a fab? can't wait to see it done, rock on
AC72 is offline   Reply With Quote
Old 05-19-2007, 08:06 PM   #103
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
Got the chassis put together today. Just need to add the ECE frame stiffeners and a CPP bolt in C-notch. Then I can transfer over the the suspension components and the engine and tranny.
NOTE: I used these two links for reference and decision making. One is a stepped cut, the other is 45 degree cut.
Stepped:
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
45 degree:
http://67-72chevytrucks.com/vboard/s...d.php?t=232149
Rob
As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17
69 SuperBurb - "My grandpa used to have a Suburban exactly like that."
http://67-72chevytrucks.com/vboard/s...d.php?t=200387
6T8 ZZZZ - Farm truck... original paint, slammed, tubbed, stroked, blown and "Bad 2 da Bone"!
http://67-72chevytrucks.com/vboard/s...d.php?t=358692
Project Shifted: http://67-72chevytrucks.com/vboard/s...d.php?t=551258
DONKEY http://67-72chevytrucks.com/vboard/s...d.php?t=226302
1948 Chevy http://67-72chevytrucks.com/vboard/s...=122164&page=3
FAQ: http://67-72chevytrucks.com/vboard/f...play.php?f=220
Hart_Rod is offline   Reply With Quote
Old 05-19-2007, 08:08 PM   #104
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
Some more pictures and I added an ECE rear crossmember while I was at it.
Rob
Old 05-19-2007, 08:11 PM   #105
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
Shortened it 20" from the original chassis that I got, but it's still 17' 9" long! We had a few parts left over.
Rob
Old 05-20-2007, 12:37 AM   #106
SCOTI
SCOTI's Avatar
Why not just re-use the discarded section of frame vs. paying for the ECE reinforcements?
Slice it down the middle (lengthwise) to remove some height so it will just fit inside the trucks frame @ the splice. You could either weld it in or bolt it in on the top/bottom of the framerail like a trailing arm c.member.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
90SWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 05-20-2007, 03:19 AM   #107
GREASEMONKEY72
old soul
GREASEMONKEY72's Avatar
good progress
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-20-2007, 08:16 AM   #108
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
I didn't have a long enough piece left to do that. Plus, I'm lazy. .
Rob
Old 05-22-2007, 09:51 PM   #109
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
Gotta little grinding done on the frame. I also installed the drivers side c-notch. This is way easier than trying to do it on completed vehicle .
EDIT: Used this as reference for the C-Notch install
http://67-72chevytrucks.com/vboard/s...d.php?t=195566
Rob
Old 05-23-2007, 10:08 PM   #110
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
Got the passenger side C-notch cut out and mostly bolted in. When I did the c-notch on the Suburban, I made a template for marking the cut. For whatever reason, I kept it, which has made this somewhat easier.
Old 05-25-2007, 09:42 PM   #111
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
Got the ECE plates welded in. I welded them top and bottom along the frame rail and then I drilled holes on the top and bottom and plug welded them. I don't think she's gonna bend, . I radiused (sp?) both sides of the strengthening plate to help clean up the looks and add a little bit of flex. It also matches the ECE tranny mount.
Rob
Old 05-25-2007, 09:45 PM   #112
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
I also put exhaust cut-outs in the crossmember that the trailing arms attach to.
NOTE: I used this as reference for the exhaust cut-out install.
http://67-72chevytrucks.com/vboard/s...56#post1720456
Rob
Old 05-25-2007, 09:58 PM   #113
SCOTI
SCOTI's Avatar
Nice. . .....
67SWB-B.B.RetroRod
64SWB-Recycle
90SWB Driver
All Fleetsides
Old 05-25-2007, 10:05 PM   #114
onetonk5
Cereal Killer
onetonk5's Avatar
Are the angle on the notches opposite of each other? Looks like it in the pics.
Why not do a round notch to match the axle?
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 05-25-2007, 10:39 PM   #115
68 P.O.S.
Junior Member
Looks like it really coming together. Nice work.
68 short step 1/2 ton -Mild 350/350 combo -3/5 drop w/ c-notch -painless harness -Edel RPM intake -Edel 600cfm carb -GM HEI -SW gauges
68 P.O.S. is offline   Reply With Quote
Old 05-26-2007, 07:27 AM   #116
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
Nice. . .....
Thanks man!
It looks funny because of the way the frame is shaped. I could have done the round notch, but I've used the bolt in notches before and it's pretty simple. My goal was to have the frame complete and bolted together in 2 weeks. I've got 6 days to go............
Thanks! When ya driving your truck up?
Rob
Old 05-26-2007, 07:47 AM   #117
Rokcrln
Rokcrln's Avatar
Dang your not done yet I think if you had gone with the blue see-thru tool box you would have been done two days ago! LOL
Hay that is turning out real nice, do you have a finished rendition of the over all look?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 05-26-2007, 08:03 AM   #118
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
Kevin
LFD Inc.
Professional grade, . I'm kinda slow, . I guess if you add in the 3 months of planning, it really took longer. I've not decided on a theme yet, but was thinking something simple as this will probably be my "shop" truck. I wasn't even going to do this much, but the engine and drivetrain were to good of a deal to pass up. I'm going to get it to a roller and then shove it in my garage until I finish the Suburban. I should have all of this done, , before I leave for New Mexico this fall.................
Rob
Old 05-26-2007, 08:38 AM   #119
Rokcrln
Rokcrln's Avatar
We are too much alike! Start one project, slide over to another only to push it aside to go back to another one for abit. If we just stayed focused on one at a time they would all get done much faster. Well that is what the wife keeps telling me and she is almost always close to being right
I would love to find a motor set up like that for Low Buck once the low buck build is done and I turn it into my shop/play toy. The motor in their now is a new crate motor but their is nothing like a factory EFI motor and AOD. Even when you have two 300hp motors side by side and one is carbed and the other is EFI the EFI motor always feels like it has 20% more power
Kevin
LFD Inc.
Old 05-26-2007, 06:51 PM   #120
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
Kevin
LFD Inc.
That's the kiddy box I get to use. This is my buddy's tool box. I got the other exhaust cut-out welded in and both sides of the frame completely welded up.
Old 05-26-2007, 08:32 PM   #121
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
I also added an ECE hidden hitch while I had it flipped over (it sure is easier to drill from the top than the bottom!). Then we bolted it to the rotissierre so we can shoot a couple more coats of POR15 on it tomorrow. We had to add an extension to get it to fit. When we pulled it in the booth, it wouldn't fit so we had to take the front part of the rotissiere off. Looks like we'll be painting it in pieces, :LOL:.
Rob
Old 05-26-2007, 09:43 PM   #122
I need to get me a bigger welder.
That is some great work Rob!
"Pieces" 70 Chevy SWB Step (4.3/T350)
"Hoopty Jr" 83 Chevy Scottsdale SWB Fleet (350/T350)
"Whitey" 02 Chevy Silverado 1500 SWB W/T
Board Vendors
Palf70Step is online now   Reply With Quote
Old 05-27-2007, 08:54 AM   #123
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
Thanks! Looks like you might have yours drivable by Cruizin the Coast, .
Rob
Old 05-27-2007, 09:03 AM   #124
68 P.O.S.
Junior Member
Shoot, I don't know man. With gas prices and that "new" 3:73 I'm a little afraid to drive over there. I'll have to do that some time though.
Old 05-27-2007, 09:50 AM   #125
ChevyDude
GREAT JOB!!!! I'm sure this Crew truck is going to be awesome, I'm tuned in and watching!!!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
