Old 02-07-2007, 04:50 PM   #1
zeitlerusmc
zeitlerusmc's Avatar
Steering column questioN????
Anyone know if a cadi steering column would bolt up in my 63 c-10?????? (an older cadi column obviously)
zeitlerusmc is offline   Reply With Quote
Old 02-08-2007, 03:56 PM   #2
Bob Moore
Re: Steering column questioN????
An older Caddy column would be great - tilt and tele - however--- the outer diameter of the mast(jacket) is larger than the trucks if I remember correctly.
IMO a better choice would be the Van column. It would be easier to fit under the dash etc.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 02-08-2007, 07:50 PM   #3
zeitlerusmc
wouldn't a van column be way too short??? and not too educated on steering columns?
Old 02-09-2007, 12:00 AM   #4
rainmans63
rainmans63's Avatar
I just bought a 70's van column and the length is 35", the same as the Ididit and Flaming river columns so I think it will work fine but the outer diameter of the mast as Bob mentioned is too small in this case. Does anyone have any suggestions on filling in that space?
By the way, I found several of these columns on craigslist and ebay. I bought mine on craigslist for $75.00.
Thanks,
Ray
rainmans63 is offline   Reply With Quote
Old 02-09-2007, 12:05 AM   #5
zeitlerusmc
Sweet man thanks! what year did your column come out of??
Old 02-09-2007, 12:46 AM   #6
rainmans63
rainmans63's Avatar
The guy I bought it off of said it was either a 78 or 79. I like it because it doesn't have the key in the column so it looks more original. One thing I forgot to mention was that you have to buy a lower shaft that mounts at the bottom of the steering column and connects to the rag joint of the gear box. As soon as I find a size that fits I'll let you know. Once I get the steering column and power steering box mounted I'll know what length I'll need so I'll keep you updated.
Old 02-09-2007, 01:57 AM   #7
slepysal
slepysal's Avatar
chevy Fleetside gets all the credit for this Idea :
Use a lower shaft from an Impala ( I used one off of a 77 truck )cut the bell off and use a coupler 36splinex3/4dd
I hope you dont mind me sharing your Idea fleetside Look under his post he has a picture of it.
Hey rainman ..... nice truck
slepysal is offline   Reply With Quote
Old 02-09-2007, 11:41 AM   #8
rainmans63
rainmans63's Avatar
Thanks for the info Slepysal! And thanks for the compliment, I like your truck too! So I see your in the bay area too? You, John, and myself are going to have to meet somewhere one of these days for coffee!
Old 02-09-2007, 12:59 PM   #9
psychorodder
psychorodder's Avatar
I put a 72 column in my 65 went in easy I used steering sector with rag joint from 72 and adjusted the length worked good I have two more steering sectors with rag joints if anyone needs one.
psychorodder is offline   Reply With Quote
Old 02-10-2007, 10:23 AM   #10
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
OH GREAT...Another darn Coffee drinker!!!
Cool ...as soon as I get the engine back in !!!
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 02-10-2007, 12:49 PM   #11
slepysal
slepysal's Avatar
John
black, one cream.
Old 02-10-2007, 01:03 PM   #12
Chevy Fleetside
Chevy Fleetside's Avatar
You guys keep naming John.. It messes me up seeing I am John also.. Here are some pictures of the column installed... I used a lower shaft from an impala but the truck ones work also as Sal said... The colum is a tilt from a van.. I believe it was a 79.. I also have one from a 76 camper van I found at Pick and Pull on 25% off day... It is really clean and I just noticed it has a button for cruise control in the blinker stem.. I am going to try and use a column from an 88 burb with wiper switch and such in the column.. I am also using the entire wiring harness with the TBI engine also.. I ya what did I get myself into...
Chevy Fleetside is offline   Reply With Quote
Old 02-10-2007, 01:06 PM   #13
Chevy Fleetside
How about meeting at a pick and pull and have some real fun... You can bring your own coffee...
Old 02-10-2007, 02:00 PM   #14
zeitlerusmc
Damn that looks good fleetside hope fully mine will look simular to that soon. i still really want to modify a cadi one to fit..... ....off to the junkyard!!!
Old 02-10-2007, 03:49 PM   #15
bowtieguy61
you could turn a spacer that would slip over the column to fill the gap. i have a lathe and mill and could help if you want.
bowtieguy61 is offline   Reply With Quote
Old 02-10-2007, 04:43 PM   #16
rainmans63
rainmans63's Avatar
Do they allow beer at pick and pull?
Old 02-10-2007, 04:49 PM   #17
rainmans63
rainmans63's Avatar
Thanks for the offer Bowtieguy61, I'll let you know!
Old 02-10-2007, 09:35 PM   #18
Chevy Fleetside
If you have a jacket with a big enough pocket in it i am sure you can get one in.. You could even throw a sealed back of ice in with it...
Old 02-10-2007, 10:12 PM   #19
krue
Designated A-hole!
krue's Avatar
I know it's for 67-72 trucks, but there are several threads in FAQ on modifying van tilts, but I have seen a caddy tilt/telescoping column in a 70 truck and it looked pretty good. Have heard that the steering wheel options are slim tho. Click the Index link in my sig for links to FAQ.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
