Old 02-07-2007, 09:56 PM   #1
noahdallas
noahdallas's Avatar
Unhappy Spark plug gap for a '75 350 please...
I have asked before but could not find the thread. I have a '75 350 bored .040 over. I have a '69 pickup and thats what I "assumed" the engine was. I got the block and head numbers and it came up to be a '75. When I thought it was a '69 the guys at Autozone said the gap was 35 and for the '75 it is 60 if I remeber correctly. Any help would be appreciated.
noahdallas is offline   Reply With Quote
Old 02-07-2007, 10:07 PM   #2
Russell
Professional Grade
Russell's Avatar
Re: Spark plug gap for a '75 350 please...
I'd run the plug gap at .045 myself, and run a newer HEI distributor Not sure what the gap should be with points though...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-07-2007, 10:22 PM   #3
noahdallas
noahdallas's Avatar
oops... it does have HEI... I was hoping changing the plugs would give me a faster response. I did change the plug wires, timing chain, cam, lifters and carb (Holley 650)about six months ago. After some tuning and carb adjusting it has been running pretty decent. I just need a little faster response till my big block is done and the way my kids have been eating might be a little while.
Old 02-07-2007, 10:24 PM   #4
krue
Designated A-hole!
krue's Avatar
HEI should be .045.
Being stupid ain't illegal.
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger"
96 S-10 "Pop's Truck"
03 GMC 3500 van drivetrain donor for the Green Booger
krue is online now   Reply With Quote
Old 02-07-2007, 11:12 PM   #5
jsbgump
Gone Fishing
jsbgump's Avatar
Points is .035
Hei is .045
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2006 GMC Sierra 1/2 ton Crew Cab SLE2 (DD)
2014 GMC Acadia Denali (Wifes Ride)
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 02-07-2007, 11:17 PM   #6
noahdallas
noahdallas's Avatar
.045 it is... thanks everyone...
Old 02-08-2007, 12:31 AM   #7
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
noahdallas from what I have come across most books will tell you .045 for HEI, but this is misleading because the plug manufatuer actually determines the plug gap. Let me explain the OEM for you engine may be .045 for 75 chevy 350 with say AC R44t spark plug BTW that is the correct number for you, Then say since you want a better plug you go to a AC R44tx same thread, same reach, same taper, plug gap now .060 all because of the plug design. The main thing you have to be concerned with is getting the right thread size, reach, and taper if needed from your parts store wich can be tricky on rebuilt engines (ex. heads not off of original engine and vise versa.) SO that being said plug gap depends on what plug your parts guy gave you, and by no means don't trust all the counter guys at your local part stores.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 02-08-2007, 01:59 AM   #8
jimfulco
I think GM was recommending .060" back then, but changed their recommendation to .045" after a few years. Might be why early HEI plug wires used to get fried before they'd get to 50,000 miles.
jimfulco is offline   Reply With Quote
Old 02-08-2007, 07:27 AM   #9
cableguy0
you will cook a stock hei if you run a gap bigger than .045. the coil and module cant handle it. wider gap means more electricity to jump the gap.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-08-2007, 12:23 PM   #10
RACINJASON22
GEARHEAD
This is true to a point, which is the case with most stock replacement plugs. But many of todays performance specific plugs are being built with different resistance properties as is the case with many wire manufactuers also, So inturn you can run wider gaps for better combustion and gas milage at no risk to our older ignition systems. You do need to do some homework to make sure where you are at in this scenario. Technology is a wonderful thing sometimes and I think this is one of them.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
