02-19-2007, 02:43 AM | #1 |
Registered Mail
How do I know If my Frame is Twisted or Bent??
I took the bed off my lwb and I am planning on cutting the frame and making it into a nice short box truck... but after looking at the back two supports connecting the frame rails together they do not measure square..? is this correct? it just doesn't seem right..
does anyone know a good and accurate way to check if a '67 frame is straight?
'67 chev 496, lwb to swb, bagged - pro street project |
02-19-2007, 03:05 AM | #2 |
In Memoriam...
Re: How do I know If my Frame is Twisted or Bent??
If there's no obstructions, you can measure the frame in an X-pattern...ie: Left front to Right rear, and Right front to Left rear. Measure at same points and see if there's any difference.
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
02-19-2007, 03:28 AM | #3 |
Needs a Big Block
The 2nd crossmember in by the hard bar mount it mounted at an angle, this may be throwing you off .
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
02-19-2007, 09:53 AM | #4 |
~Rest In Peace~
is the right side higher than the left side my frame is twisted i noticed my bed is titling to one side got under it and found the frame at the rivets is spread
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
02-19-2007, 11:40 AM | #5 |
It is normal for the support to be at an angle.
72 Cheyenne Super 80 Silverado Blazer 2wd |
02-19-2007, 03:52 PM | #6 |
There is a ton of information shared on this site. It would help if members would read what others have posted. Maybe you could answer your question before posting it.
If you have not purchased a "Factory Assembly Manual" and a "Factory Shop Manual", I strongly advise you to do so. This comment is not directed at smokenbarrels. As posted by FarmTruk and Slammed66, measure your frame diagonally. The 2nd from rear is mounted "non-square" and plays tricks on your eyes. You should not have a problem when you shorten your frame if you take care and double check and triple check your measurments before you cut.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
02-19-2007, 05:43 PM | #7 |
Registered Mail
Thanks guys, I was confused there for a min., yea that pan hard bar bracket is not straight..
I will be using a older thread illustraiting how to shorten the frame.. it looked very detailed.
02-19-2007, 05:49 PM | #8 |
Here are some typical frame specs to use to see if it is twisted.
http://www.chuckschevytruckpages.com/framespecs.html
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
02-19-2007, 06:06 PM | #9 |
The LuvShack Garage
Good info on that Linky
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-19-2007, 06:58 PM | #10 |
Thread Tools | |
Display Modes | |
