Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > FAQ > FAQ Truck Tech
Old 04-04-2007, 04:39 PM   #1
Frizzle Fry
It's only metal
Frizzle Fry's Avatar
Blazer Tank Install on the CHEAP... $50
After mentioning this tank on the Low-Buck thread I've had a few PMs about it, so I figured I'd post the info here.
I did this a couple years ago and have since sold the truck to board member JRB. So I'll post all the pics I have of it, for any more pics (such as the sender mod) we'll have to go through JRB.
You can get 73-87 style Blazer tanks "new" (old but not used), from HERE for $25 plus about $25(+/-) shipping. Search for Blazer and it will come up. They do list as "Diesel," but that does not matter for our application. Since they are unused they will hold gasoline just as well as they would diesel (no flush required).
To save even more money I welded in the sender flange from the truck tank, and bent the truck's sending unit float arm to work in the blazer tank.
The Blazer sending unit has a bigger flange/seal and these tanks don't come with a sending unit. I was on a really tight budget at the time and didn't want to buy the correct sending unit at ~$120 or so new. So I figured out how to use the sending unit out of the truck tank. Part of that involved cutting the smaller flange from the truck tank and welding it into the blazer tank.
Then the dip tube and float arm had to be bent appropriately to work in the detentions of the new tank. It actually ended up working flawlessly.
...or you could just buy the sender that goes to that tank.
I also welded on the filler neck from the truck so I could just use the original cap and fill through the bed floor. Because the tank is square you should be able to mount it turned 90* if you want to use a side filler.
***Safety Note: I filled the tank with water before welding. Even though it's "new" there's just something scary about welding on a fuel tank.. maybe it's just me
Also, I believe the tanks are galvanized, but if you sufficiently clean the areas to be welded with a blaster or wire-wheel you can make a good weld. Just be sure to do it outside and avoid the fumes more than you normally would when welding. I've heard galvanic poisoning sucks big time
The "crooked" crossmember behind the rear-end had to be trimmed a bit as seen in the pics.
The hanger straps I used were found in the plumbing section of Home Depot. I think they are meant for securing hot water heaters. These were not the type with perforations. They are galvanized with doubled-over edges. I also used a plastic/rubber insulator made from that floor/wall/edge kick-guard stuff you see in classrooms and offices (another Home Depot purchase).
I held the tank in place with a floor-jack, drilled through one strap and the frame, secured it, then pulled it tight and did the same on the other side. In the end I used 4 bolts per strap.
I extended the fuel gauge wire and ran rubber fuel line from where it normally turns from the frame over to the cab floor. I bent that back towards the back more (normally a 90) so that I still had access to install the clamp, but got the fuel line back into the frame as soon as possible. I know some say you should always run 100% steel line for fuel, but I felt safe with the way I routed and secured the line.
So for $50 plus a couple penny items I was in business
Here's the pics:
Frizzle Fry is offline
Old 04-04-2007, 04:40 PM   #2
Frizzle Fry
It's only metal
Re: Blazer Tank Install on the CHEAP... $50
...and the joy of no in-cab tank
Old 04-04-2007, 05:08 PM   #3
jimmydean
jimmydean's Avatar
Nice work! I have no excuse now!
The huge box of audio/video equipment (currently sitting in my garage) thanks you in advance.
New Project: 1971 LWB C10
Plans:
Biodiesel conversion
6.2 Turbo Diesel running home made B100
Dropmember
4 link rear
Bags all around
http://67-72chevytrucks.com/vboard/s....php?p=2702054
jimmydean is offline
Old 04-04-2007, 05:13 PM   #4
dan42
Moderator
dan42's Avatar
That's a keeper - I'm bookmaarking it -
'67 SWB Fleetside 350/SM465
'70 LWB 3/4 ton 350/350 sold!
'10 4 door Silverado 4X4 (worker bee)
Click here to support the board
"The best high is the Most High!"
dan42 is offline
Old 04-04-2007, 05:15 PM   #5
LUV2XCLR8
My Square Corvette
LUV2XCLR8's Avatar
How many gallons is that?
PROJECT: "YFTSB" 1972 BLAZER 2WD
TOW RIG: "GAS HOG" Y2K GMC 3500
LUV2XCLR8 is offline
Old 04-04-2007, 05:53 PM   #6
Frizzle Fry
It's only metal
Since that is a a Military Surplus place I think when these tanks are gone they are gone. Not sure how many they have. I've though about buying one just for a future truck.
The site lists it as 27 gallons, but I remember it was more like 25.
Old 04-04-2007, 05:54 PM   #7
Shane
Registered Offender
Shane's Avatar
The link says 27 gallons.
Originally Posted by Frizzle's link
U.S. Military Issue. These are replacement Fuel Tanks for Military Chevy Blazers. 27 gal. fuel capacity.
Measurements are 26 in. x 26 in. x 9 in.
Unused but weathered.
Made in the USA.
There will be an additional $5.00 added to shipping due to a no box fee.
Shane is offline
Old 04-04-2007, 09:16 PM   #8
nevada70chev
thanks for the info, looking to do the swap.
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat)
nevada70chev is offline
Old 04-04-2007, 11:09 PM   #9
72CSTC5
72CSTC5's Avatar
I already bought one for the price and will put it in my short bed.
72CSTC5 is offline
Old 04-04-2007, 11:30 PM   #10
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Looks like a good thread for the FAQ's section to me after it bounces around here for awhile of course. Very nice work and GR8 tech. Thank You much Frizzle Fry.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline
Old 04-04-2007, 11:33 PM   #11
SCOTI
SCOTI's Avatar
Should be able to find a blazer/burb gas tank in a wrecking yard & snag the sending unit out of that for cheap if you don't have the ability to weld on the 'new' tank.
67SWB-B.B.RetroRod
64SWB-Stella
74SWB-Driver/Tow Truck
All Fleetsides
http://www.hubgarage.com/mygarage/scoti
SCOTI is online now
Old 04-05-2007, 04:03 AM   #12
Mudder
Firefighter/First Responder
Mudder's Avatar
I got a Blazer tank from a salvage yard with the skid plate, cross members, fill tube, and straps for 60 bucks. I ran it completely empty one weekend (ran out of gas in the parking lot of a gas station, LOL) just to see how much it would hold. It went to 33 gallons. That was from an 85 Blazer. The skid plate is great and an added protection IMO, and also helps to hold the tank in place.
67 Stepside 4x4 (Red) 383 Stroker
02 ZR2 4x4 (Red)
Mudder is offline
Old 04-05-2007, 08:21 PM   #13
Frizzle Fry
It's only metal
Any Pics of that skid plate Mudder?
Old 04-05-2007, 09:30 PM   #14
DangerBoy
You guys just love helping me find ways to spend my rent money don't you...
Sand, primer, paint it black.
DangerBoy is offline
Old 04-06-2007, 03:28 AM   #15
Mudder
Mudder's Avatar
I have partial pics.
02 ZR2 4x4 (Red)
Mudder is offline
Old 04-06-2007, 11:41 AM   #16
70rs/ss
70rs/ss's Avatar
I just bought the Blazer tanks (2) so they have 8 left!!
70 RS/SS 4-speed Camaro w/AC
80 HD Sportster/Chopper
90 454 SS chevy truck
72 Burb 2wd now (w/68 clip!) but 4X4 soon!! Check it out, "The BIG Unit!!" http://67-72chevytrucks.com/vboard/s...d.php?t=347574 NOW it's a 4X4 build here! http://67-72chevytrucks.com/vboard/s...=1#post3444581
Life should not be a jouney to the grave with the intention of arriving safely in a well preserved body but rather sliding in, Goldschlagger shot in one hand, cell phone in the other, body thoughly used up and totally worn out screaming WoooooooooooHooooooooo WHAT A RIDE!!!!!!!!!!
70rs/ss is offline
Old 04-06-2007, 02:18 PM   #17
timcos
Chief Honcho In Charge
timcos's Avatar
I just ordered one....with 39 shipping to Utah.
Not bad and what a great project.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline
Old 04-06-2007, 06:12 PM   #18
jbboater
New Member
Got one $43 total shipped to RI. Nice information, thanks. I'm trying to do the whole project low budget without sacrificing quality. This fits the plan perfectly!
1968 SWB Fleetside
~In Progress~
Plans:
Disc Swap
454
Turbo 400
Lots of body work!!
2004 Victory Vegas Arlen Ness (My Bike)
I guess you could say this is my second childhood.
jbboater is offline
Old 04-06-2007, 08:54 PM   #19
krue
Designated A-hole!
krue's Avatar
Remind me to put this in FAQ after everyone has seen it.
Being stupid ain't illegal.
FAQ INDEX Thread
We're Debt Free Except for the House!!!
www.daveramsey.com
krue is offline
Old 04-06-2007, 09:34 PM   #20
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
just picked one up. thanks for the link!!
IvelDesigns is offline
Old 04-07-2007, 01:25 PM   #21
Frizzle Fry
It's only metal
Man, I should have posted this 2 years ago Glad you guys are getting some good use out of it! I wonder how many they have left. Now, when I go to buy one for a future project they'll be out.
Old 04-07-2007, 01:44 PM   #22
72CSTC5
72CSTC5's Avatar
Yeah that surplus store is going to wonder what the hell is going on huh?
72CSTC5 is offline
Old 04-07-2007, 11:37 PM   #23
drman929
drman929's Avatar
Haha, yeah..you know, it is the season for everyone to buy blazer tanks!
I grabbed one...
drman929 is offline
Old 04-11-2007, 12:11 AM   #24
Frizzle Fry
It's only metal
One more bump and then I'll ask Krue to put it in FAQ...
Old 04-11-2007, 12:31 PM   #25
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
nice....thanks for the info
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo
sixty8c10 is offline
Thread Tools
Display Modes
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
