Old 04-24-2007, 01:48 AM   #1
semperfidoordie
Fix It Till It's Broke
semperfidoordie's Avatar
Shimming a starter
So I was going to replace the old worn out starter today and when I took the old one out I realized it had a shim with it. I had yet to put the new one in because I didn't know or pay attention to how the old shim was in there...sorry if this is a stupid question but thanks for taking your time to answer it if you do
semperfidoordie is offline   Reply With Quote
Old 04-24-2007, 05:49 AM   #2
Re: Shimming a starter
The starter noses vary sometimes and the starter may need shimmed because of that or irregularities in the block. I would try the new one without the shim and see if it engages alright. If it grinds or seems to act weird, try the shim between the starter and where it mates up.
Rice-A-Roni, 2006 Nissan Frontier - DD
Board Vendors
Old 04-24-2007, 07:20 AM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
If the inspection cover is off you can check the clearance between the fllywheel and the starter shaft.
Here's a good article on it.
http://www.carcraft.com/howto/2988/index3.html
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 04-24-2007, 07:27 AM   #4
BobbyK
BobbyK's Avatar
Oh ya,make sure the rear support bracket is installed.It GREATLY prolongs the life of the starter.
Sorry no pic's of it on the truck.
Old 04-24-2007, 08:14 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
there should be 1/8" between the starter shaft and the teeth of the ring gear. I use a brazing rod with the flux scraped off as a gauge.
68C15 is offline   Reply With Quote
Old 04-24-2007, 09:25 AM   #6
krue
Designated A-hole!
krue's Avatar
Most new starters come with a set of shims and a rod to check the clearance. I've always heard of the brace, but I've never actually seen one.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-24-2007, 10:44 AM   #7
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Krue...me too...but I just found one on an old block and installed it on my new sb 400. Problem is that it just makes the terminals harder to access...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 04-24-2007, 11:31 AM   #8
BobbyK
BobbyK's Avatar
That's usually why they're never reinstalled.
Thing is once they ARE installed the need to access the wires becomes rare.
I'm going on 6 years with my starter.It's only a reman. from PepBoys.
Old 04-24-2007, 01:47 PM   #9
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
on my second one i used two shims, the first rebuilt starter i bought i didnt use any shims and it broke the nose of the housing from being too close to the gears. Had to replace the starter and flexplate This is very important to check!!!! Flexplates arent easy to replace!!! lol lesson learned.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 04-24-2007, 02:18 PM   #10
A.P.
Black 72 Chevy
A.P.'s Avatar
BobbyK
I installed a bracket like that on my starter for a 350 engine and that cured all my grinding problems.
A.P.
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 04-24-2007, 09:08 PM   #11
Ironhead
Ironhead's Avatar
I know the starter bracket is getting away from the shimming a starter question but, any idea where to get one of these brackets for a BB?
Ironhead Mike
'68 Panel 402BB
'84 Shortbox 4X4
'85 Blazer
'97 Silverado Ext. Cab
Ironhead is offline   Reply With Quote
Old 04-24-2007, 10:42 PM   #12
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Thumbs up Re: Shimming a starter
This is a great article. Easy read ..... lots of good info.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 04-25-2007, 01:41 AM   #13
pat
pat's Avatar
I need to do this too. My starter would only engage about 10 percent of the time, always 'spinning off' and not grabbing. Dont know if these means my starter is going bad or I need shims.
So I got some shims and started with 2 shims, it grabbed good once or twice then kept spinning. 4 shims were no better. Might take off my starter to have it checked.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 04-25-2007, 02:40 AM   #14
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
Pat,
Please keep me imformed on what you find out on your truck. My '62 is doing the exact same thing. I need to get this truck operational asap.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 04-25-2007, 02:50 AM   #15
BobbyK
BobbyK's Avatar
Check your local dealership,Should be around $10.00 for it.
That pic I posted was from Classic Industries catalog.
Here is the whole page.The prices have prob. gone up since my catalog is from 2000-2001.
Click the link for a full sized pic.
http://images23.fotki.com/v803/fileR...scan001001.jpg
Old 04-25-2007, 09:53 AM   #16
jhow66
jhow66's Avatar
Pat: you need to shim the outer bolt only. Cut the shim to fit under this bolt only. Start with 2. This will set the teeth deeper in the flywheel.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-25-2007, 09:40 PM   #17
Ironhead
Ironhead's Avatar
Starter noise during cranking can be caused by too much clearance between pinion and flywheel. If shimmed, try removing shim or only shim outer bolt only. A whining noise after engine fires / as key is released can be from pinion and dlywheel being too close. Try shimming both sides until noise stops. I check the clearance between the pinion and flywheel or flexplate by using a heavy wire with a hook on the end of it to reach in and pull out the starter clutch until it engages the flywheel. You need to rotate the flywheel so a pinion gear tooth is centered between two flywheel teeth. Use a .020" wire gage. Hope this is helpful.
Ironhead Mike
'68 Panel 402BB
'84 Shortbox 4X4
'85 Blazer
Old 05-03-2007, 11:46 AM   #18
pat
pat's Avatar
Originally Posted by Chevyboy1962 View Post
Pat,
David
I used a 1/16" shim on only the forwardmost bolt on the starter. Solved everything. Truck cranks and starts right away and it even decided to idle for me
Thanks guys!
Old 05-05-2007, 10:12 PM   #19
pat
pat's Avatar
Scratch that, the next day it wouldnt work. I played with shims for about an hour with no luck. I went to get my starter tested and it worked, but the guy there said he really couldnt make sure b/c he couldnt put it under a load to see if it was getting weak. He mentioned something about GM changing the bolts from a 3/8 to a 10mm or something, and said there was a possibility of that causing enough of a misalignment. Plus the bolts were supposed to fit snugly in the starter, mine were very loose. So I bought a new starter and 2 new bolts and it works perfectly, no shims either.
Old 05-05-2007, 11:14 PM   #20
eedgell
It's the air up here
eedgell's Avatar
Mostly GM starters work with no shims. The cheep after market starters some times need them, but ac/delco not often. GM squares and trues all mounting surfaces.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2023, vBulletin Solutions Inc.
