Old 05-13-2007, 02:19 PM   #1
dmsteele92831
Wiring a kill switch
I've tried to search this out but no one gives a complete wiring description for a kill switch for an electric fuel pump. The switch I bought has two prongs on the back. I connected a positive wire to one then tapped into the positive wire on the fuel pump. Then I connected a negative wire to one and grounded it. But it didn't kill the fuel pump when I turned the ignition key to "ON". Also I put in a 20 amp inline fuse and the switch I'm using is a 10 amp. Any ideas on this? Is it hooked up wrong?
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
dmsteele92831 is offline   Reply With Quote
Old 05-13-2007, 02:41 PM   #2
eedgell
It's the air up here
eedgell's Avatar
Re: Wiring a kill switch
I think your switch needs to be in the middle of the circuit not at the begining or the end. It must just be a "stop" in the line. Not a starting point or an ending point.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 05-13-2007, 03:33 PM   #3
Overkill67
Ok all you ned to do is put the switch somewhere in between the positive and the pump, no need to ground the switch. if you ground it (other than if it is one with a light) your going to burn the switch, and if your lucky thats all......
Like this + ------------ switch ---------------- fuel pump positive connection
Overkill67 is offline   Reply With Quote
Old 05-13-2007, 03:40 PM   #4
st1x10
st1x10's Avatar
Yes like that above. The switch opens and closes the circuit.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 05-13-2007, 03:44 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Is there a realy in your circuit too somewhere?
If so, then you need the switch in the relay circuit.
If no... then you really should.
Old 05-14-2007, 12:43 PM   #6
dmsteele92831
So what about the extra pin on the back? Is it of no use?
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
Old 05-14-2007, 05:22 PM   #7
dmsteele92831
I did the above, just running the switch on the positive wire, and nada. Do I need to run an alternate power source to the switch (like to the fuse box)?
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
Old 05-14-2007, 06:12 PM   #8
Don Brace
Active Member
The best place to do this would be right at the fuel pump. Connect the original wire that goes the the positive of the fuel pump to one pin on the switch. Connect the other pin of the switch to the positive connection on the fuel pump. This will allow the switch to turn the pump on and off. Make sure you tape up any of the bare connections.
Don Brace MN
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
61 Impala CVRT 409 4 SP
2- 71 Longhorns
Always looking for old toy trains, Juke boxes Pin ball and game machines.
Don Brace is offline   Reply With Quote
Old 05-14-2007, 07:15 PM   #9
dmsteele92831
Ahhh, I gotcha, Ill give that a try!
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
Old 05-14-2007, 07:49 PM   #10
jojotonka
jojotonka's Avatar
I just put a switch on the dash of my 72 Jimmy last month. I have a blue Holley pump. I put the switch IN LINE of your hot wire. NO ground is necessary. Holley only called for a 7 amp inline fuse. 20 amp could be to high.
jojotonka is offline   Reply With Quote
Old 05-15-2007, 02:43 PM   #11
dmsteele92831
So I should use a lower amp inline fuse? Also, should the fuse go in between the power source and the switch or in between the switch and the pump?
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
Old 05-15-2007, 05:40 PM   #12
Shyguy
Junior Member
Shyguy's Avatar
As close to the power source as possible, that way it protects the wire, the switch and the pump.
Danny -SEMO
Shyguy is offline   Reply With Quote
Old 05-15-2007, 05:42 PM   #13
dmsteele92831
What about the 20 amp fuse, is that ok?
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
Thread Tools
Display Modes
