Old 06-16-2007, 08:51 PM   #1
retro69
Help with rear axle code
Rear axle code on right passenger side says RHA W330 1; what is the rear axle ratio for this code???
1969 C10 Long Wheel Base
1985 Monte Carlo SS(Snake Charmer)
retro69 is offline   Reply With Quote
Old 06-17-2007, 11:00 AM   #2
Livrat
Member #1049
Livrat's Avatar
Location: 25 miles east of Arlington, Wa. 4 miles west of Darrington, Wa.
Re: Help with rear axle code
that is a 1972 3:07 ratio..
Here is a link.. srcoll down to axle codes and click on year
http://www.americanclassic.com/paint.htm?p1=axles
Livrat is offline   Reply With Quote
Old 07-14-2011, 08:16 AM   #3
m22muncie
m22muncie's Avatar
I need this info but the link is dead now....arrrgh!!!!!
m22muncie is offline   Reply With Quote
Old 07-14-2011, 08:21 AM   #4
cdowns
cdowns's Avatar
a code that was stamped 40years ago is not always what is inside now alot of times// a simple rear fluid change will give you a foolproof answer
Old 07-14-2011, 08:31 AM   #5
m22muncie
m22muncie's Avatar
True enough, I am pretty sure this is an unmolested truck though, as far as the rear axle. I plan to pull the cover soon and change gear oil but I have a lot to get done before I get around to it. I really would like to find a ratio code chart.
Old 07-14-2011, 11:31 AM   #6
Livrat
Member #1049
Livrat's Avatar
Yes that site is dead, I now have an interchange manual that lists the codes, post up your axle code and I can tell you what it originally was
Old 07-14-2011, 12:03 PM   #7
m22muncie
m22muncie's Avatar
Its a 70 pickup TDA. I found another post after I did a search that said it is a 3.73. Im guessing its an open (peg leg)
Old 07-14-2011, 12:26 PM   #8
DANTIP
DANTIP's Avatar
You are both correct, the GM parts manual says that is a 1072 3.07 (open) for CS/CE, and the same stamp was used in 1970 for a 3.73 (open). Therefore, if it is a 6-lug, it's probably the 3.73 and if it is a 5-lug it's probably a 3.07.
Good Luck!!
DANTIP is offline   Reply With Quote
Old 07-14-2011, 12:29 PM   #9
m22muncie
m22muncie's Avatar
It is a 6 lug, 3.73 should be nice with my overdrive. Thank you!
Old 07-14-2011, 10:12 PM   #10
Livrat
Member #1049
Livrat's Avatar
My Hollander interchange manual lists it as a 70 3:73 open.
Old 11-03-2011, 03:16 PM   #11
budnikguy
budnikguy's Avatar
any help with a 72 rearend stamped RHC W126 1 Thanks in advance...
budnikguy is offline   Reply With Quote
Old 11-03-2011, 03:29 PM   #12
Rich916
Rich916's Avatar
[QUOTE= a simple rear fluid change will give you a foolproof answer[/QUOTE]
Please explain, what would one look for?
71 Short Step Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=429946
Rich916 is offline   Reply With Quote
Old 11-03-2011, 03:33 PM   #13
DANTIP
DANTIP's Avatar
Book says 1972 3.73 open (non-posi).
Old 11-03-2011, 03:36 PM   #14
RenoKeene
Florida Edition
RenoKeene's Avatar
Here is what was stamped on mine...
It's a 3:07 Posi now
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 11-03-2011, 03:53 PM   #15
budnikguy
budnikguy's Avatar
Great thanks...just wanted an idea before I popped to take a look...
Old 04-08-2012, 01:10 PM   #16
darrylhopkins
Need a bit of help, have a 1970 C-10 that I have reason to believe was swapped to a 71 Frame, dash sheet says automatic & had to cut a bellhousing crossmember out that was riveted in, disc brakes, and rear lug studs for a 70 didn't fit but 71's did, as well as a 71 type grill, & am noticing looseness in the rear end, anyway it is 5 lug with coils and the number on pumpkin is 3896838 and code on tube is RHA W143 1
darrylhopkins is offline   Reply With Quote
Old 09-01-2012, 09:37 PM   #17
cjohnson6772
cjohnson6772's Avatar
Bump. I have a 72 with rha code. Hoping someone has a definitive source.
cjohnson6772 is offline   Reply With Quote
Old 09-01-2012, 10:08 PM   #18
Livrat
Member #1049
Livrat's Avatar
RHA= 1972, 3:07 ratio (Source: Hollander interchange manual)
Old 09-01-2012, 10:11 PM   #19
cjohnson6772
Thank you!!!
Old 09-02-2012, 02:53 AM   #20
SS Tim
SS Tim's Avatar
RHA, '72 CS/CE10 3.07:1 Chevrolet Parts Manual
SS Tim is offline   Reply With Quote
Old 09-28-2012, 02:11 PM   #21
JaxsDad
How about this one?
RA 0208 W2
JaxsDad is offline   Reply With Quote
Old 09-28-2012, 02:25 PM   #22
DANTIP
DANTIP's Avatar
Both 68 and 69 used RA for the 3.07 open for a Series 10.
Old 09-28-2012, 03:09 PM   #23
truckster
truckster's Avatar
On the edge of the ring gear there are going to be some numbers. There will be two numbers separated by a colon (. These numbers indicate the number of teeth on the pinion and the ring gear.
For example, mine is stamped 11:41. 41 divided by 11 equals 3.7272, so it's a 3.71:1 gear ration
truckster is offline   Reply With Quote
Old 09-28-2012, 10:22 PM   #24
SS Tim
SS Tim's Avatar
Originally Posted by JaxsDad View Post
How about this one?
RA 0208 W2
C10/G10 1968 or 69 open 3.07:1 ratio, February 8th, Warren Plant, 2nd shift.
Old 09-28-2012, 11:48 PM   #25
m22muncie
m22muncie's Avatar
Gmpartswiki.com will answer all your decoding questions.
70 Chevy Custom 10 400SB, Tremec TKO600, 3.73 posi. LWB hope to chop frame and have it short soon!
71 GMC LWB in the works of getting going for the first time since 1996
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
