Old 07-22-2007, 10:19 PM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
Gringoloco's Camaro tach install
Played around with the truck a little on Saturday- thought I would show you guys some pics.
This is what I've been staring at since I got the truck- BLAH. There was also a column mounted SunPro tach- very functional, but not the prettiest.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-22-2007, 10:24 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Gringoloco's Camaro tach install
I started out by tearing the Camaro tach out of the cluster I bought on eBay and started modfying the truck gauge tin to fit it. You can see here where the back tin must be clearanced for the black plastic insulator to fit through.
-Chris
Old 07-22-2007, 10:37 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Here you can see where I mounted the backing plate from the Camaro cluster to mount the tach to. Also note where the plate had to be trimmed for the right blinker bulb and the area that the dash connector was is flattened out.
The plate is marked for the input and 12V the upper middle stud is the ground. I just ran a nut down it and grounded the tach to the cluster. I ran a wire from the ammeter input to power it and a wire from the distributor for the signal. Dont forget all the plastic insulators on the studs!
-Chris
Old 07-22-2007, 10:46 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
You can see in the last pic I also replaced the ammeter with a voltmeter. Just personal preference. I used the guts from a $15 SunPro voltmeter. Basically just tore the gauge apart, trimmed the stock face plate to fit, and drilled two holes in the backing plate.
Again, I just grounded the voltmeter to the cluster and used one of the old ammeter leads to power it. Luckily the SunPro bucket is the same depth as the stocker, so it mounts right up
-Chris
Old 07-22-2007, 10:56 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Used some metal polish to take the lines off the inside of the tach lens and slapped it back together with a new bezel. I also used a spare fuel gauge needle on the tach so it would look like it belongs.
It all just kinda fell together(with a little trial-and-error) and looks tons better than before. Whatcha think?
-Chris
Old 07-22-2007, 11:36 PM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Excellent! Thanks for sharing!
And I just happen to have a Camaro tach laying around.....
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-23-2007, 12:59 AM   #7
GREASEMONKEY72
GREASEMONKEY72's Avatar
looks good, deffinitly better than nothing
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 07-23-2007, 07:14 AM   #8
c10crazy
Like a Rock!
c10crazy's Avatar
Beautiful job . I tried this once and the tach was not very accurate so I tried another Camaro tach and it still was reading high. They look great in there though. How in the world did you ever get that sunpro gauge to come apart? I tried to do that once and it was pressed together from the factory so tight I gave up on it. Please do tell
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 07-23-2007, 08:43 AM   #9
clos69
Its Topless Season!!!!
clos69's Avatar
That looks real nice Gringo....what year is the Camaro you got the tach from? That way I 'll know what to look for when I start hitting the junkyards....
clos69 is offline   Reply With Quote
Old 07-23-2007, 11:33 AM   #10
bryanw1968
bryanw1968's Avatar
That looks bad ass.
bryanw1968 is offline   Reply With Quote
Old 07-23-2007, 12:30 PM   #11
dave2953
Dave's not here, man
dave2953's Avatar
Looks great! I thought you had a 3 hole bezel w/ the quad 5" Autometers? Really nice job, though. I think this should be added to the FAQ.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 07-23-2007, 12:49 PM   #12
Frizzle Fry
Frizzle Fry's Avatar
That does look great. How does the back lighting work out at night?
Too bad you redline at 4700 RPM
Frizzle Fry is offline   Reply With Quote
Old 07-23-2007, 02:11 PM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
The pressed-on chrome trim ring comes off easily with a small screwdriver. Just pry around the edge a little at a time until it 'pops' off.
The eBay ad said '72-'78. I have heard anywhere from '70 to '81 will work. See pic below- I think I paid $30 for the whole cluster.
The Autometers are slated for my 2wd Blazer. These went in the truck as a quick solution to that UGLY cluster that was in there.
That's kinda the reason I did this. I thought the FAQ was lacking a little in the details of how to mount the tach- this could maybe be added to it?
Backlighting is perfect. The tach sits about 1/4" from the inner tin letting light in all the way around. I'll try to get a pic this eve.
Thanks guys for all the compliments. This really is very easy to do with a little time and a dremel.
-Chris
-Chris
Old 07-23-2007, 02:39 PM   #14
c10crazy
Like a Rock!
c10crazy's Avatar
-Chris
Thanks Chris!. You pry along the backside of the gauge right?
69 LWB
Old 07-23-2007, 06:18 PM   #15
gringoloco
A guy with a truck
gringoloco's Avatar
Yep, the chrome ring is very thin metal- very easy to do.
-Chris
Old 07-23-2007, 07:11 PM   #16
c10crazy
Like a Rock!
c10crazy's Avatar
Thank you sir!
69 LWB
Old 07-26-2007, 08:59 AM   #17
gringoloco
A guy with a truck
gringoloco's Avatar
Here's those nighttime pics I promised; anyone notice anything different about the second one?
-Chris
Old 07-26-2007, 09:31 AM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
Great work. The integration between the old and new is seamless. Now all you need is a clock to fill the blank spot.
Ok, I give up what the red light for? I don't think you "red-lined" at 0 rpm, so it must indicate something else.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-26-2007, 06:55 PM   #19
gringoloco
A guy with a truck
gringoloco's Avatar
What I noticed in most other people's Camaro tach install is that most people try to eliminate or hide the oil pressure warning light on the tach. I made it functional. Just looks more 'original' that way to me.
The reason I have the high beams on is to show the blue light as opposed to the factory red. It just never looked right to me, so I swapped out a blue filter from the Camaro cluster. Just a few subtle mods that contribute to the overall effect...
-Chris
Old 07-26-2007, 10:13 PM   #20
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
Ok how much do do mine like this?
Angelse68cal is offline   Reply With Quote
Old 07-26-2007, 11:10 PM   #21
RicksTrucks
RicksTrucks's Avatar
-Chris
I have a few of those clusters from 78-81 Camaro's, will have to put one away for a truck. Thanks for showing us how.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 07-27-2007, 03:12 AM   #22
gringoloco
A guy with a truck
gringoloco's Avatar
If you're serious, I'd do it for $50- you supply parts. PM me if interested.
-Chris
Old 07-27-2007, 10:18 AM   #23
Webrigs
Webrigs's Avatar
Great install & thanks for sharing the info on the post!
Just to confirm - it looks like you would have been able to reinstall the flat printed circuit on the back instead of one of the 'stepped-out' printed circuits that were used on the instrument clusters with factory tach's, correct?
1972 Cheyenne Super
Webrigs is offline   Reply With Quote
Old 07-27-2007, 01:52 PM   #24
gringoloco
A guy with a truck
gringoloco's Avatar
Yes, I used the standard flat circuit. I just trimmed the protruding studs flush with the nuts. A tach circuit would work perfectly though...
-Chris
Old 01-22-2008, 11:26 AM   #25
Critter
Future TOTM Winner
Critter's Avatar
I know this is an old thread but...
Correct me if I'm wrong but these Camaro tachs look basically the same from 70 - 81 but the Camaro got HEI in 75 (I think?) and the printed circuit is different. Does anyone know if the tach is different? I am planning on doing this conversion on my 72 Blazer but I converted it over to HEI. Basically I would hate to find a nice 73 tach in the junkyard and go through all that trouble and have it not work with my HEI.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Thread Tools
Display Modes
