Old 08-28-2007, 10:31 PM   #1
azfab
azfab's Avatar
How about some pics of bagged C-10's
lay it low.[IMG][/IMG]
azfab is offline   Reply With Quote
Old 08-30-2007, 10:57 AM   #2
bodydropped68
bodydropped68's Avatar
Re: post all bagged c10 here
here's one for you
bodydropped68 is offline   Reply With Quote
Old 08-30-2007, 01:52 PM   #3
Jcentsr6
Junior Member
Jcentsr6's Avatar
Here is mine
going to sell this one...looking for a SWB project next.
Jcentsr6 is offline   Reply With Quote
Old 08-30-2007, 06:52 PM   #4
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
my daily driver. 76 days and counting....
IvelDesigns is offline   Reply With Quote
Old 08-31-2007, 10:31 AM   #5
Rokcrln
Rokcrln's Avatar
Well here is my bagged 10 but it is comming apart as we speak to give life to two other vehicals.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 08-31-2007, 10:55 AM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Noooooooooo, don't take it apart that thing is sweeet !!!!
Heres mine, only bagged in the front but soon in the back
Just not low enough...
The 02 build
Sinister
Killer
Driver
Visit the Texas CGITC
Spray-Bomb is offline   Reply With Quote
Old 08-31-2007, 05:33 PM   #7
bodydropped68
Originally Posted by SCOTI View Post
Cool. Stats?
thanks scoti, Stats bagged,stock floor bodydrop, 4 link,4 wheel disc, 12 bolt posi 4.10 gears, two 3/4 hp compressors,four air tanks,FBSS, bed floor raised now 8 inches deep, crate 350/700r4,KMC SS 20x8.5 wheels,245 40 20 front 285 50 20 in the rear. that's some of it later, paul
Old 09-03-2007, 08:51 PM   #8
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 09-03-2007, 10:25 PM   #9
04 orange
04 orange's Avatar
Here's mine.
04 orange is offline   Reply With Quote
Old 09-03-2007, 11:42 PM   #10
shifty
I ♥ Zombies!
shifty's Avatar
more info on wheels and tires (and caps?), what arms and spindles you're using?
I'm probably still around lurking. Drop me a PM.
shifty is offline   Reply With Quote
Old 09-04-2007, 04:40 PM   #11
SCOTI
SCOTI's Avatar
I like it.... post up more pics if you have any.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 09-05-2007, 10:21 AM   #12
IvelDesigns
well, i was waiting to reply so i could go out and look to see what size tires i'm running, but i can roughly guess somewhere around a 245-70-15 for the tire. some cheap brand i'm pretty sure.
the wheels are your standard 15" steelies with baby moon hub caps and the thinner trim rings.
I'm running 2.5" drop spindles and factory arms. out back i have 2.5" blocks, and a notched frame, but the blocks are kinda pointless since the axle hits the frame long before the bag bottoms out.
Old 09-05-2007, 11:50 PM   #13
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Mikes truck
The 02 build
Sinister
Killer
Driver
Old 09-07-2007, 04:46 PM   #14
bodydropped68
heres some more pics
Old 09-07-2007, 05:12 PM   #15
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
I'm a late bloomer, here's a couple more of mine
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 09-07-2007, 05:33 PM   #16
Frizzle Fry
It's only metal
Frizzle Fry's Avatar
Still fine-tuning my levitation device...
Frizzle Fry is offline   Reply With Quote
Old 09-07-2007, 08:10 PM   #17
abadsvt
abadsvt's Avatar
Hey Frizzle that thing looks SICK!!!! I like it alot!
Here is my project but i am going to be swapping out the frame for a new one once i get it built because i am going to be using a complete c5 corvette supsension, motor and transaxle!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 09-12-2007, 12:18 PM   #18
camaro__thunder
Heres 2 more
My Project 69 SWB
Old 09-12-2007, 06:44 PM   #19
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Originally Posted by steveo10 View Post
spraybomb, what do you want to know or see? i have alot of pics but i never put any up for a build thread cause i just kinda did it and took pics along the way. i didn't really think i needed a buildup.
Well what all did you do to get it down & how far is you front rocker from the ground
A link to your photobucket will suffice
The 02 build
Sinister
Killer
Driver
Old 09-16-2007, 07:46 PM   #20
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
heres mine........................
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-17-2007, 12:44 PM   #21
steveo10
steveo10's Avatar
heres some pics of my rear set-up. just a kp notch and a suicide doors superlift 4 link.
steveo10 is offline   Reply With Quote
Old 09-17-2007, 01:23 PM   #22
FnLow69
FnLow69's Avatar
Heres mine so far.....
Heres the rear suspension... minus the air valves there going on the tanks..
FnLow69 is offline   Reply With Quote
Old 09-17-2007, 11:36 PM   #23
Film Guy
Junior Member
Film Guy's Avatar
Here's mine. Sorry no new pics. Truck is @ Stoked Out getting some mods done. I think N2TRUX may have a newer pic
Film Guy is offline   Reply With Quote
Old 09-17-2007, 11:40 PM   #24
steveo10
steveo10's Avatar
Originally Posted by Spray-Bomb View Post
What did you do to get the front down & does the rear go lower that the front @ dump ??? if so how much
Sorry to thread jack
the front is just the suicide doors front kit and i cut down the cups. i hate to say it but the front is all the way down and is sitting on the inside edge of the fender. i think i'm going to cut the fenders to see if it will go any lower.
Old 09-20-2007, 08:18 PM   #25
dan468
dan468's Avatar
Anyone else think it's funny that not too many of us have "complete" bagged C10s
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
